你好,我们试着在PIC32 MZ2048启动套件(EF)上实现一个WebServer。虽然很容易使它与Orror 1.10一起工作,但我不能用新的Hydio 2.02b来做同样的事情。我想使用新的Orthor版本,因为它支持QSPI Flash SST6来存储网页。我为和谐1.10做了同样的程序。这意味着(1)新项目-在协调配置器中选择启动工具包,BSP已经被检查。3)我启用NVM驱动程序将其注册为文件系统4),使文件系统服务与25 SyMultAeNeAccess,Microchip文件系统,在NVM存储器6中启用TCP堆栈,没有DH。在我的NET7中选择一个有效的IP,使HTTP Serv8)选择正确的网页安装点。当我编译MPLAB报告服务器HTTP应用代码中的几个错误,因为它不能在BSP(正确启用)中找到设置LED和读开关的功能。好吧,我评论他们…编译成功。当我加载固件时,堆栈缝不起作用。没有对ping的响应,没有来自Web服务器的。是否有人可以尝试实现同一个项目并检查它是否有效?谢里桑德雷亚
以上来自于百度翻译 以下为原文 Hello, we are try to implement a webserver on a PIC32MZ2048 Starter Kit (EF). While it was pretty easy to make it works with hARMony 1.10 I can't doe the same with the new harmony 2.02b. I want to use the new version of harmony because it support QSPI flash SST6 to store the web pages. I just follow the same procedure that i did for the harmony 1.10. That means 1)new project -> select the starter kit as project template 2)In harmony configurator the BSP was already checked. 3)I enable the NVM driver registering it as file system 4)Enable file system service with 25 symultaneus access, microchip file system, in NVM memory 6)Enable TCP Stack, no DHCP, selected a valid ip in my net 7)Enable HTTP Server 8)Select the correct mounting point for the web pages. When i compile MPLAB report several error in the server http application code because it can't find in the BSP (that is correctly enabled) the functions to set the leds and read switches. Ok, i commented them out.... it compile successfully. When i load the firmware the stack seams not working. No response to the ping, nothing from the webserver. Is there someone that could try to implement the same project and check if it works? thanks Andrea |
1个回答
请确保您的SST26与PIC通信,因为我已经体验到与内置驱动程序的协调问题。顺便说一下,你不需要一个外部闪存来存储网页,你有一个NVM驱动程序和文件系统,适合于PIC的内部内存。
以上来自于百度翻译 以下为原文 make sure your SST26 is communicating with the PIC because I've experienced Harmony problems with the built in driver. By the way you don't need an external flash to store web pages you have an NVM driver and File system that fits into PIC's internal memory. |
只有小组成员才能发言,加入小组>>
5077 浏览 9 评论
1953 浏览 8 评论
1888 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3115 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2186 浏览 5 评论
633浏览 1评论
504浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
368浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
535浏览 0评论
440浏览 0评论
GMT+8, 2024-9-28 13:14 , Processed in 1.145344 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
