#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h" // DSP2833x Examples Include File // Determine when the shift to right justify the data takes place // Only one of these should be defined as 1. // The other two should be defined as 0. #define POST_SHIFT 0 // Shift results after the entire sample table is full #define INLINE_SHIFT 1 // Shift results as the data is taken from the results regsiter #define NO_SHIFT 0 // Do not shift the results // ADC start parameters #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz #endif #if (CPU_FRQ_100MHZ) #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz #endif #define ADC_CKPS 0x0 // ADC module clock = HSPCLK/1 = 25.5MHz/(1) = 25.0 MHz #define ADC_SHCLK 0x1 // S/H width in ADC module periods = 2 ADC cycle #define AVG 1000 // Average sample limit #define ZOFFSET 0x00 // Average Zero offset #define BUF_SIZE 2 // Sample buffer size // Global variable for this example volatile Uint16 SampleTable[BUF_SIZE]; volatile float adc0=0; main() { Uint16 i; // Uint16 adc=0; Uint16 array_index; InitSysCtrl(); EALLOW; SysCtrlRegs.HISPCP.all = ADC_MODCLK; // 系统外设时钟6分频,一般ADC就用6分频 // 这是因为ADC最高只能配置25MHz的频率 // 所以最快转换一次的时间使80ns EDIS; DINT; InitPieCtrl(); IER = 0x0000; IFR = 0x0000; InitPieVectTable(); InitAdc(); //这个初始化程序,必须添加DSP2833x_Adc.C文件 AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK; //ADC采样时间选择 AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS; //ADC内核分频 AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; //级联工作方式 AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x1; //设置CONV0 为第一个通道 AdcRegs.ADCTRL1.bit.CONT_RUN = 0; //连续运行模式 AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1; //完成排序后,排序器指针回到最初状态 AdcRegs.ADCCHSELSEQ1.all = 0x0; //初始化SEQ1排序寄存器 AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 0x0; // 设置一对转换,共16通道 // Clear SampleTable for (i=0; i { SampleTable = 0; } // Start SEQ1 AdcRegs.ADCTRL2.all = 0x2000; //软件启动转换功能 while(1) { if(array_index>2) array_index = 0; while(AdcRegs.ADCST.bit.INT_SEQ1 == 0); //等待ADC的中断位为1 AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1; //清楚排序器中断位 SampleTable[array_index++]= ( (AdcRegs.ADCRESULT0)>>4); //将结果寄存器16位的值转换位10进制数 adc0=(float)SampleTable[0] * 3.0 /4096.0; // 转换为我们读取的数据类型 // 数据类型转换另外一篇有说明 DELAY_US(100); } } //=========================================================================== // No more. //=========================================================================== |
1 个讨论
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
TMS320C6748 板卡设计中是否一定需要有SDRAM或者DDR
1958 浏览 0 评论
988 浏览 0 评论
3654 浏览 1 评论
【六岳微LY-F335开发板试用体验】epwm启动ADC并在OLED上显示结果
4493 浏览 0 评论
【六岳微LY-F335开发板试用体验】软件开发环境及调试下载
4541 浏览 0 评论
/9
GMT+8, 2025-12-2 21:03 , Processed in 0.699649 second(s), Total 40, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5958
