参考以太网启动器套件II(DM32000—4-2):1。启动器套件与D3302启动套件I/O扩展板兼容吗?2。以太网启动器套件II是否包含PIC套件(PKOB),或者在用户手册中引用的USB连接调试工具有什么不同吗?三。我可以通过连接到扩展板来使用皮卡3或ICD-3(DV164035)吗?(我想是这样)4。如果是这样,是否有任何跳线或其他动作来禁用在以太网启动器套件II上的星上调试?谢谢——我到处都找遍了,看到了很多误导性的信息。
以上来自于百度翻译 以下为原文 With reference to the Ethernet Starter Kit II (DM32000-4-2) : 1. Is the starter kit compatible with the DM320002 Starter Kit I/O Expansion Board? 2. Does the Ethernet Starter Kit II contain a Pic Kit On Board (PKOB), or is the USB-connected debugging tool referenced in the User Manual something different? 3. Can I use the PicKit 3 or ICD-3 (DV164035) via connection to the expansion board? (I think so) 4. If so, are there any jumpers or other actions necessary to disable the on-board debugging that is on the Ethernet Starter Kit II? Thanks--I have looked everywhere, and see a lot of misleading information. |
1个回答
对。我将它们与PICTROW PROTTO板一起使用,连接到三个UARTs和两个I2C通道和一个复位按钮。(下一个项目:一只梨树上的鹧鸪。)是的。它显示为PIC32-ESKII在“硬件工具:Microchip启动器工具包& GT;启动工具包(PKOB)”中,我刚刚从我的工作站插入USB电缆到ESKII上的迷你B连接器,就在那里!只是为了看看我能不能,我通过一个自制的适配器3编程的适配器电缆到JP1上的I/O扩展板(RJ-45型连接器)。我看不出PkIt使用PKOB连接有什么好处。我没有一个ICD-3来测试它,但是我认为如果你喜欢的话,那是值得的。请注意,我从来没有尝试过通过PigIt进行项目。对于这种设置,我发现我可以通过ESKII上的Mi-B连接器供电,或者通过I/O扩展板上的外部电源连接器提供9伏电源。不,它们只是工作。只要选择一个或另一个在MPLABX。至少它是如何为我工作的。我的设置:MPLABX版本3.55在我的32位CENTOS 6.8 Linux工作站。
以上来自于百度翻译 以下为原文 Yes. I use them together with a PICtail proto board for connecting to three UARTs and two I2C channels and a reset button. (Next project: a partridge in a pear tree.) Yes. It shows up as PIC32-ESKII under "Hardware Tool: Microchip Starter Kits->Starter Kits (PKOB)" I just plugged in a USB cable from my workstation to the mini-B connector on the ESKII, and there it was! Just to see if I could, I programmed with a PICkit 3 through a home-made adapter cable to JP1 on the I/O expansion board (the RJ-45 style connector). I don't see any advantage of the PICkit over using the PKOB connection. I don't have an ICD-3 to test it with, but I'm thinking that would be worthwhile if that's your cup of tea. Note that I never, ever try to power projects through the PICkit. For this setup I found that I can power it through the mini-B connector on the ESKII or with a 9 volt supply through the external power connector on the I/O expansion board. No. They just work. Just select one or the other in MPLABX. At least that how it works for me. My setup: MPLABX version 3.55 on my 32-bit Centos 6.8 Linux workstation. Regards, Dave |
只有小组成员才能发言,加入小组>>
5085 浏览 9 评论
1957 浏览 8 评论
1893 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3123 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2192 浏览 5 评论
641浏览 1评论
525浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
384浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
546浏览 0评论
451浏览 0评论
GMT+8, 2024-10-5 20:44 , Processed in 0.876564 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
