STM32f030F4 20脚的MCU,GPIO不够,因此想把当晶振用的PF0 和PF1 也用了
看文档写的: Using the HSE or LSE oscillator pins as GPIOs When the HSE or LSE oscillator is switched OFF (default state after reset), the related oscillator pins can be used as normal GPIOs. When the HSE or LSE oscillator is switched ON (by setting the HSEON or LSEON bit in the RCC_CSR register) the oscillator takes control of its associated pins and the GPIO configuration of these pins has no effect. When the oscillator is configured in a user external clock mode, only the OSC_IN or OSC32_IN pin is reserved for clock input and the OSC_OUT or OSC32_OUT pin can still be used as normal GPIO. 已经: #define PLL_SOURCE_HSI // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source //#define PLL_SOURCE_HSE // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source //#define PLL_SOURCE_HSE_BYPASS // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock 选择为内部RC振荡器,但是PF0 还是不能用,有哪位大虾知道否? |
20个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1307 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
1234 浏览 3 评论
2313 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
1404 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
1834 浏览 1 评论
GMT+8, 2024-11-30 15:09 , Processed in 0.727692 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
