嗨,我有一个简单的分段显示(8个SEG和4个公共),并且已经理解了语法和初始化可以用代码驱动分段显示。我从来没有用分段显示来实际构建一个设备UI……是否有人在你需要UPDDA的时间上有什么指针?为人眼展示屏幕?什么是时间方面的策略?我已经准备好如何展示显示角色的功能,但是很难掌握时间。任何帮助,都要感谢有人使用分段显示之前建造的东西。谢谢!
以上来自于百度翻译 以下为原文 Hi, I've got a simple segmented display (8 segs, and 4 commons) and have figured out the syntax and initilization can drive the segmented display in code. I've never actually built a device UI using a segmented display.... Does anyone have any pointers on the timing for how quickly you need to be updating the screen for the human eye? What is the strategy in terms of timing? I'm already noodling how to built out the functions to display the characters, but having a hard time grasping the timing. Any help, is much appreciated from someone who has built something using a segmented display before. Thanks! |
5个回答
30Hz是最小的,但可以检测到。更好的是,接近50或60可以与灯交互,所以你需要70Hz或以上才能不具有这种效果。
以上来自于百度翻译 以下为原文 30Hz is minimum, but detectable.. more is better. close to 50 or 60 may interact with lights, so you would need to be 70Hz or above to not have that effect |
大多数小型液晶显示器的响应时间非常慢,所以通常可以慢得多的刷新。
以上来自于百度翻译 以下为原文 Most small LCDs have very slow response times though, so you can usually get away with much slower refresh. |
液晶显示器?用PIC液晶驱动外围设备?100赫兹应该是好的。检查玻璃的数据表,看看什么是最佳的。靠近DC会使玻璃质量下降。
以上来自于百度翻译 以下为原文 LCD? with a PIC LCD Driver peripheral? 100Hz should be fine. Check the Data sheet for the Glass to see what is optimal for it. To close to DC can degrade the Glasss. |
哈哈,数据表?这些都像0.05美元的显示与自定义字符。我很幸运我得到了一个PIN…
以上来自于百度翻译 以下为原文 HAHA, datasheet? These are like $0.05USD displays with custom characters. I'm lucky I got a pin-out....! |
我建议以一个缓慢的刷新率开始,直到它看起来好为止;每一个玻璃(显示器)和驱动技术(复用)将有一个最佳的范围,并且可以很容易地通过观察来确定。更高的刷新率在LCD显示器上花费更多的功率,过高的速率会导致模糊的图像,而太慢会明显地闪烁或褪色并令人恼火。
以上来自于百度翻译 以下为原文 I suggest starting with a slow refresh rate and increasing it until it looks good; each glass (display) and drive technique (multiplexing) will have a range that is optimum and can easily be determined by observation. Higher refresh rates on LCD display take more power and too high a rate can lead to a blurred image while too slow will visibly blink or fade and be annoying. |
只有小组成员才能发言,加入小组>>
5195 浏览 9 评论
2013 浏览 8 评论
1937 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3185 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2240 浏览 5 评论
751浏览 1评论
637浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
522浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
648浏览 0评论
549浏览 0评论
GMT+8, 2024-12-2 18:15 , Processed in 1.347044 second(s), Total 88, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
