扫一扫,分享给好友
亲爱的,我有关于通过USB端口进行编程控制的问题,当我改变位置USB插件因软件显示错误因为位置USB indirec!请你从软件中获取关于修复端口的建议Best respectbadboy
以上来自于谷歌翻译 以下为原文 Dear all, I have problem about programming control through USB port, When I change position USB for plug in that the software show error because position USB indirec ! Could you please advice about fix port from software Best regard badboy |
1个回答
据我所知,如果您可以在连接专家中看到该设备,那么它应该是一个简单的修复,只需要给它适当的别名和/或配置来控制VEE。对于没有显示连接的设备
专家,每当您在不同的USB端口插入设备时,它应该安装或要求您安装驱动程序。 我有一个设备识别插入的USB端口,如果我将其插入另一个端口,它停止工作,并要求我安装驱动程序。 我做了之后,它的确有效。 也许这就是你的问题。 以上来自于谷歌翻译 以下为原文 As far as I know, if you can see the device in connection expert, then it should be an easy fix, just need to give it proper alias and/or configuration to control with VEE. For devices that doesn't show up in connection expert, it should install or asks you to install drivers whenever you plug in the device in a different USB port. I had a device that recognize the plugged in USB port, if I plug it in another port, it stopped working and asks me to install driver. After I did, it works. So maybe this is your problem. |
只有小组成员才能发言,加入小组>>
1272 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2944 浏览 3 评论
1089浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
745浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
910浏览 0评论
1273浏览 0评论
GMT+8, 2024-12-19 14:34 , Processed in 1.556487 second(s), Total 96, Slave 80 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
