电子发烧友论坛|
你好,我有一个DSPIC板,不能让PLL工作。我对水晶很怀疑,所以我需要澄清我的代码没有任何问题。我的代码有问题吗??
以上来自于百度翻译 以下为原文 Hello, I have a board with that dspic and could not make pll work. I am suspicious about the crystal so i need to clarify that my code has not any problem. Is there any problem with my code?? #pragma config ICS = PGD2 // ICD Communication Channel Select bits (Communicate on PGEC2 and PGED2) #pragma config JTAGEN = OFF // JTAG Enable bit (JTAG is disabled) // FPOR #pragma config ALTI2C1 = ON // Alternate I2C1 pins (I2C1 mapped to ASDA1/ASCL1 pins) #pragma config ALTI2C2 = ON // Alternate I2C2 pins (I2C2 mapped to ASDA2/ASCL2 pins) #pragma config WDTWIN = WIN75 // Watchdog Window Select bits (WDT Window is 75% of WDT period) // FWDT #pragma config WDTPOST = PS32768 // Watchdog Timer Postscaler bits (1:32,768) #pragma config WDTPRE = PR128 // Watchdog Timer Prescaler bit (1:128) #pragma config PLLKEN = OFF // PLL Lock Enable bit (Clock switch will not wait for the PLL lock signal.) #pragma config WINDIS = OFF // Watchdog Timer Window Enable bit (Watchdog Timer in Non-Window mode) #pragma config FWDTEN = OFF // Watchdog Timer Enable bit (Watchdog timer enabled/disabled by user software) // FOSC #pragma config POSCMD = NONE // Primary Oscillator Mode Select bits (Primary Oscillator disabled) #pragma config OSCIOFNC = OFF // OSC2 Pin Function bit (OSC2 is clock output) #pragma config IOL1WAY = OFF // Peripheral pin select configuration (Allow multiple reconfigurations) #pragma config FCKSM = CSDCMD // Clock Switching Mode bits (Both Clock switching and Fail-safe Clock Monitor are disabled) // FOSCSEL #pragma config FNOSC = FRC // Oscillator Source Selection (Internal Fast RC (FRC)) #pragma config PWMLOCK = ON // PWM Lock Enable bit (Certain PWM registers may only be written after key sequence) #pragma config IESO = ON // Two-speed Oscillator Start-up Enable bit (Start up device with FRC, then switch to user-selected oscillator source) // FGS #pragma config GWRP = OFF // General Segment Write-Protect bit (General Segment may be written) #pragma config GCP = OFF // General Segment Code-Protect bit (General Segment Code protect is Disabled) #include #include "common.h" /* Main application */ int main(void) { // Configure PLL prescaler, PLL postscaler, PLL divisor PLLFBD=46; // M=48 CLKDIVbits.PLLPOST=0; // N2=2 CLKDIVbits.PLLPRE=0; // N1=2 // Initiate Clock Switch to Primary Oscillator with PLL (NOSC=0b011) __builtin_write_OSCCONH(0x03); __builtin_write_OSCCONL(OSCCON | 0x01); // Wait for Clock switch to occur while (OSCCONbits.COSC!= 0b011); // Wait for PLL to lock while (OSCCONbits.LOCK!= 1); TRISAbits.TRISA7 = OUTPUT; TRISAbits.TRISA10 = OUTPUT; while (1) { __delay_ms(500); LATAbits.LATA10 = 1; LATAbits.LATA7 = 1; __delay_ms(500); LATAbits.LATA10 = 0; LATAbits.LATA7 = 0; // Add your application code } } /*common.h*/ #define FCY 60000000UL #define OUTPUT 1 #define INPUT 0 #define MapLock() __builtin_write_OSCCONL(OSCCON | (1<<6)) #define MapUnLock() __builtin_write_OSCCONL(OSCCON & ~(1<<6)) |
11个回答
好的,我会改变的,试试看。还有其他问题吗?
以上来自于百度翻译 以下为原文 Ok, i will change it and try that. Is there any other problem that you see? |
海伊
以上来自于百度翻译 以下为原文 heyy try this #pragma config PLLKEN = OFF // PLL Lock Enable bit (Clock switch will not wait for the PLL lock signal.) regards, |
仍然有问题
以上来自于百度翻译 以下为原文 Still having the problem #include #include "common.h" //#define OSC_INTERNAL // FICD #pragma config ICS = PGD2 // ICD Communication Channel Select bits (Communicate on PGEC2 and PGED2) #pragma config JTAGEN = OFF // JTAG Enable bit (JTAG is disabled) // FPOR #pragma config ALTI2C1 = ON // Alternate I2C1 pins (I2C1 mapped to ASDA1/ASCL1 pins) #pragma config ALTI2C2 = ON // Alternate I2C2 pins (I2C2 mapped to ASDA2/ASCL2 pins) #pragma config WDTWIN = WIN75 // Watchdog Window Select bits (WDT Window is 75% of WDT period) // FWDT #pragma config WDTPOST = PS32768 // Watchdog Timer Postscaler bits (1:32,768) #pragma config WDTPRE = PR128 // Watchdog Timer Prescaler bit (1:128) #pragma config PLLKEN = OFF // PLL Lock Enable bit (Clock switch will not wait for the PLL lock signal.) #pragma config WINDIS = OFF // Watchdog Timer Window Enable bit (Watchdog Timer in Non-Window mode) #pragma config FWDTEN = OFF // Watchdog Timer Enable bit (Watchdog timer enabled/disabled by user software) // FOSC #pragma config POSCMD = XT #pragma config FCKSM = CSECMD #pragma config OSCIOFNC = ON #pragma config IOL1WAY = OFF // FOSCSEL #pragma config FNOSC = FRC #pragma config PWMLOCK = ON #pragma config IESO = OFF // FGS #pragma config GWRP = OFF // General Segment Write-Protect bit (General Segment may be written) #pragma config GCP = OFF // General Segment Code-Protect bit (General Segment Code protect is Disabled) int main(void) { // Disable Watch Dog Timer RCONbits.SWDTEN = 0; // Configure PLL prescaler, PLL postscaler, PLL divisor PLLFBD = 46; // M=48 CLKDIVbits.PLLPOST = 0; // N2=2 CLKDIVbits.PLLPRE = 0; // N1=2 // Initiate Clock Switch to Primary Oscillator with PLL (NOSC=0b011) __builtin_write_OSCCONH(0x03); __builtin_write_OSCCONL(0x00); OSCCONbits.OSWEN = 1; // Wait for Clock switch to occur while (OSCCONbits.COSC != 0b011); // Wait for PLL to lock while (OSCCONbits.LOCK != 1); TRISAbits.TRISA7 = OUTPUT; TRISAbits.TRISA10 = OUTPUT; LATAbits.LATA10 = 1; while (1) { __delay_ms(500); LATAbits.LATA10 = 1; LATAbits.LATA7 = 1; __delay_ms(500); LATAbits.LATA10 = 1; LATAbits.LATA7 = 0; // Add your application code } } |
在另一个文件中尝试这一点,别忘了在My.C Prd2中的PGD2A* PrdA2 PrAgMac配置文件JTAGEN=OF//FPORα-PrimaMatlab配置文件BRONE==O.PrimaMac配置文件ALTI2C1= OffyApRiga配置文件ALTI2C2= OFF Prima配置文件WDMPON= WI25//FWDTπPracMA配置文件WDTPOS= PS327 68μPrimaA配置WDPRE=Pr128- Prima-FigdIn=Off-TracMig-COMFIG=OFFDTEN=OF//OFSC。GiiSO=O//FGSα-PrAPMA配置GWRP=Off-Tyraca配置GCP= OFF
以上来自于百度翻译 以下为原文 try this in another file ,and don't forget to include in main.c #pragma config ICS = PGD2 #pragma config JTAGEN = OFF // FPOR #pragma config BOREN = ON #pragma config ALTI2C1 = OFF #pragma config ALTI2C2 = OFF #pragma config WDTWIN = WIN25 // FWDT #pragma config WDTPOST = PS32768 #pragma config WDTPRE = PR128 #pragma config PLLKEN = ON #pragma config WINDIS = OFF #pragma config FWDTEN = OFF // FOSC #pragma config POSCMD = NONE #pragma config OSCIOFNC = OFF #pragma config IOL1WAY = ON #pragma config FCKSM = CSECMD // FOSCSEL #pragma config FNOSC = FRCDIVN #pragma config PWMLOCK = OFF #pragma config IESO = ON // FGS #pragma config GWRP = OFF #pragma config GCP = OFF |
FRC没有问题。我想,我的问题是水晶本身。无论如何,用这个代码改变我的水晶作品:
以上来自于百度翻译 以下为原文 There is no problem with the frc. I think, my problem is the crystal itself. Anyway, changing the crystal works for me with this code: // FICD #pragma config ICS = PGD2 // ICD Communication Channel Select bits (Communicate on PGEC2 and PGED2) #pragma config JTAGEN = OFF // JTAG Enable bit (JTAG is disabled) // FPOR #pragma config ALTI2C1 = OFF // Alternate I2C1 pins (I2C1 mapped to SDA1/SCL1 pins) #pragma config ALTI2C2 = OFF // Alternate I2C2 pins (I2C2 mapped to SDA2/SCL2 pins) #pragma config WDTWIN = WIN25 // Watchdog Window Select bits (WDT Window is 25% of WDT period) // FWDT #pragma config WDTPOST = PS32768 // Watchdog Timer Postscaler bits (1:32,768) #pragma config WDTPRE = PR128 // Watchdog Timer Prescaler bit (1:128) #pragma config PLLKEN = ON // PLL Lock Enable bit (Clock switch to PLL source will wait until the PLL lock signal is valid.) #pragma config WINDIS = OFF // Watchdog Timer Window Enable bit (Watchdog Timer in Non-Window mode) #pragma config FWDTEN = OFF // Watchdog Timer Enable bit (Watchdog timer enabled/disabled by user software) // FOSC #pragma config POSCMD = XT // Primary Oscillator Mode Select bits (XT Crystal Oscillator Mode) #pragma config OSCIOFNC = OFF // OSC2 Pin Function bit (OSC2 is clock output) #pragma config IOL1WAY = OFF // Peripheral pin select configuration (Allow multiple reconfigurations) #pragma config FCKSM = CSECMD // Clock Switching Mode bits (Clock switching is enabled,Fail-safe Clock Monitor is disabled) // FOSCSEL #pragma config FNOSC = FRC // Oscillator Source Selection (Internal Fast RC (FRC)) #pragma config PWMLOCK = ON // PWM Lock Enable bit (Certain PWM registers may only be written after key sequence) #pragma config IESO = OFF // Two-speed Oscillator Start-up Enable bit (Start up with user-selected oscillator source) // FGS #pragma config GWRP = OFF // General Segment Write-Protect bit (General Segment may be written) #pragma config GCP = OFF // General Segment Code-Protect bit (General Segment Code protect is Disabled) // #pragma config statements should precede project file includes. // Use project enums instead of #define for ON and OFF. // #include "myGeneralDefines.h" int main(void) { // /**************************************************************************** * Setting the Output Latch SFR(s) ***************************************************************************/ LATA = 0x0000; LATB = 0x0000; LATC = 0x0000; /**************************************************************************** * Setting the GPIO Direction SFR(s) ***************************************************************************/ TRISA = 0x0317; TRISB = 0xFFFF; TRISC = 0x03FF; /**************************************************************************** * Setting the Weak Pull Up and Weak Pull Down SFR(s) ***************************************************************************/ CNPDA = 0x0000; CNPDB = 0x0000; CNPDC = 0x0000; CNPUA = 0x0000; CNPUB = 0x0000; CNPUC = 0x0000; /**************************************************************************** * Setting the Open Drain SFR(s) ***************************************************************************/ ODCA = 0x0000; ODCB = 0x0000; ODCC = 0x0000; /**************************************************************************** * Setting the Analog/Digital Configuration SFR(s) ***************************************************************************/ ANSELA = 0x0013; ANSELB = 0x010F; ANSELC = 0x0007; // // // Configure Oscillator to operate the device at 60Mhz // Fosc= Fin*M/(N1*N2), Fcy=Fosc/2 // Fosc= 8M*60/(2*2)=120Mhz for 8M input clock PLLFBD = 58; // M=60 CLKDIVbits.PLLPOST = 0; // N1=2 CLKDIVbits.PLLPRE = 0; // N2=2 OSCTUN = 0; // Tune FRC oscillator, if FRC is used // Disable Watch Dog Timer RCONbits.SWDTEN = 0; // Clock switching to incorporate PLL __builtin_write_OSCCONH(0x03); // Initiate Clock Switch to Primary // Oscillator with PLL (NOSC=0b011) __builtin_write_OSCCONL(OSCCON || 0x01); // Start clock switching while (OSCCONbits.COSC != 0b011); // Wait for Clock switch to occur // Wait for PLL to lock while (OSCCONbits.LOCK != 1) { }; // while (1) { LATAbits.LATA7 = 1; LATAbits.LATA10 = 1; __delay_ms(100); LATAbits.LATA7 = 0; LATAbits.LATA10 = 0; __delay_ms(100); } return 0; } |
嗨,你的配置位ALENOTHORIDE…如果你想选择一个外部XTAL(假设你在你的板上有一个),你必须使用下面的配置:
以上来自于百度翻译 以下为原文 Hi, your configuration bits are not correct... If you want to select an external XTAL (assuming you have one on your board) you must use the following configuration #pragma CONFIG FNOSC = PRI or #pragma CONFIG FNOSC = PRIPLL (if you want to use PLL with XT XTAL) Regards |
这也是一个特别的奖项:
以上来自于百度翻译 以下为原文 This one also deserves a special award: #define OUTPUT 1 #define INPUT 0 ... TRISAbits.TRISA7 = OUTPUT; TRISAbits.TRISA10 = OUTPUT; |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
483 浏览 0 评论
5804 浏览 9 评论
2344 浏览 8 评论
2233 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3538 浏览 3 评论
1143浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1114浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
882浏览 1评论
485浏览 0评论
/9
GMT+8, 2025-12-8 11:27 , Processed in 0.987109 second(s), Total 94, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6262
