问候语!我是一个编程PIC24设备的新手。目前,我一直在做的项目,我想调试。但是在调试设备的时候,它已经被识别出来了,但是在调试模式中它并没有进一步进入。我已经关掉了看门狗,也正确地选择了PGM AN。D PGC引脚。但我不明白为什么问题仍然存在。我也分享代码和配置位设置。请注意程序已经完成使用C30编译器。请成员请帮助我整理出这个问题,因为它非常迫切。
以上来自于百度翻译 以下为原文 Greetings! I am a novice in programming PIC24 devices. Currently, the project in which I have been working on, I wanted to debug. But while debugging the device is getting identified but it's not entering further in the debug mode. I have taken care of switching off the Watchdog and also rightly selecting the PGM and PGC pins. But I am not understanding why exactly the problem still persists. I am also sharing the code and configuration bit settings. Please note the program has been done using C30 compiler. Request the members to please help me in sorting out the issue as it's very urgent. Regards SKD Attached Image(s) Attachment(s) CCP2.c (0.88 KB) - downloaded 123 times |
4个回答
你的PIC真的在运行吗?以什么时钟速度?我注意到你已经禁用了主振荡器。
以上来自于百度翻译 以下为原文 Is your PIC actually running? At what clock speed? I note you have disabled the primary oscillator. |
我已经使用PIC做了PWM工作代码,所以PIC正在运行。我给出的时钟速度是8MHz内部。我不使用外部振荡器
以上来自于百度翻译 以下为原文 I have Done PWM Working Code using PIC, so PIC is running for sure. The clock speed I've given is 8Mhz internal. I am not using external oscillator |
这一个!转到调试器& gt;ICD3设置& gt;程序存储器&自动检查“成功构建后的程序”选项,此WordKelyDelp表示帮助:
以上来自于百度翻译 以下为原文 tryed this one! go to Debugger>ICD3 Settings>Program Memory>Automatically check the “Program after successful build” option and this worked Thanks for help :) |
嗨,如果你可以编程你的设备(身份识别),但它不能进入调试模式,它几乎肯定是由于错误的选择ICSP调试对,你有在配置位。你的屏幕截图显示,你选择了PGC1/PGD1检查你的示意图,如果你使用PGC2/PGD2或PGC3/PGD3必须相应地改变配置位ICS对
以上来自于百度翻译 以下为原文 Hi, If you can program your device (ID identified) but it fails to enter debug mode, it almost certainly is due to the wrong selection of the ICSP debug pair which you have in the configuration bits. Your screenshot shows that you have selected PGC1/PGD1. Check your schematic, if you use PGC2/PGD2 or PGC3/PGD3 you must change accordingly the configuration bits ICS pair Regards |
只有小组成员才能发言,加入小组>>
5079 浏览 9 评论
1954 浏览 8 评论
1888 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3115 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2186 浏览 5 评论
633浏览 1评论
506浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
370浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
535浏览 0评论
440浏览 0评论
GMT+8, 2024-9-28 22:16 , Processed in 1.301359 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
