大家好,我的54820A示波器有问题。
有一天我来上班并打开了示波器,并且没有显示格子和输入信号。 除了显示刻度或输入信号外,图形和全屏界面似乎都工作正常。 对于输入信号,我将探头放在前面板方波输出上。 我尝试了快速测量,这很有效。 我已经使用Ctrl-Alt-Del重置了范围,但没有帮助。 有人有主意吗? 谢谢,Vorpal 以上来自于谷歌翻译 以下为原文 Hi All, I am having trouble with my 54820A scope. I came to work one day and turned on the scope and the graticule and input signal did not display. The graphical and full screen interfaces appear to both be working fine except neither displays a graticule or the input signal. For the input signal, I placed the probe on the front panel square wave output. I tried quick measure and that worked. I have reset the scope using Ctrl-Alt-Del and that didn't help. Anyone have any ideas? Thanks, Vorpal |
4个回答
不可思议但可能,显示器分辨率以某种方式改变了。
我相信它被认为是640x480,真彩色(24位)。 我可能是错的,所以在更改之前请注意这些问题。 要进入Windows,请使用Ctrl和Esc。 但很可能范围是在它的时代结束。 最初的Infiniiums是非常好的示波器,许多仍然运行良好,但时间对15年前的主板和计算机硬件造成了影响。 当然它也可能是采集硬件......尝试自我测试...... 以上来自于谷歌翻译 以下为原文 Unlikly but possible, the display resoluton got changed somehow. I believe it is suppsoed to be 640x480, true color (24 bit). I could be wrong, so take note of the ettings before changing them. To get into Windows, use Ctrl and Esc. But more than likely the scope is at the end of its days. The original Infiniiums were very nice scopes and many are still working well, but time takes its toll on 15 year old motherboards and computer hardware. Certainly it could also be the acquisition hardware... try a self test... |
谢谢(你的)信息。
我检查了显示信息,它被设置为640x480(真彩色,24位)。 看起来不错,我没有改变任何东西。 自我测试通过。 这可能不会出现任何问题,但我会运行扫描磁盘。 也许你是对的,范围已经过了好几天,时间到了! 我会继续研究这个问题。 看起来很奇怪,启动后FW成功运行到全屏界面出现的位置但是刻度没有。 再次感谢,道格 以上来自于谷歌翻译 以下为原文 Thanks for the info. I checked the display information and it was set to 640x480 (true color, 24 bit). That looks OK and I didn't change anything. The self test passes. This probably won't turn up anything but, I am going to run a scan disk. Maybe you are right, the scope has seen better days and its time is up! I will keep on looking into this. It just seems strange that after boot up the FW successfully runs to where the full screen interface appears but the graticule doesn't. Thanks again, Doug |
嗨,你也可以在“控制”或“设置”下拉菜单下进行默认设置或出厂默认设置吗? 在cahnnel菜单下,可能有一个“探测配置”按钮或类似的东西。 确保没有打开“用户定义的探测”或“外部缩放”。 (你可以告诉我在相当长的一段时间内没有见过吗?)假设上述两种方法都没有...这可能值得进行自我校准......这种情况也会报告任何失败...... 以上来自于谷歌翻译 以下为原文 hi, so did u do a default setup, or factory default setup, under the "control" or maybe "setup" drop down? under the cahnnel menu, there may be a "probe config" button or soemthing like that. make sure that there is nothing like "user defined probe" or "external scaling" turned on. (can u tell I have not seen one in quite some time?) assuming neither of the above fixes... it is likely worthwhiel to do a self calibration... that shud also report any hw failures.... |
嗨Doug,我有一个54820A与你的问题相同。
它启动很好,响应输入,基本上做所有事情除了显示一个经纬网和痕迹。 实际上,屏幕的打印预览显示了刻度和痕迹,只是它们没有显示在屏幕上! 服务手册说液晶显示系统由两个互连的PCI卡组成。 第一张卡与采集系统连接以获取跟踪数据点。 然后它将该数据提供给显示驱动卡(背面有VGA连接器的卡),生成所有其余的显示元素。 我将一个外接显示器连接到VGA连接器,其上的显示与内部VGA相同:除了刻度和迹线外,所有内容都显示出来。 我的工作假设是问题在于与接收系统接口的卡。 该卡有一个焊接的纽扣电池备用电池。 我没有测量过它,但是经过这么多年我不得不假设它已经死了,或者几乎已经死了。 除了更换它之外,我不知道除了从零件捐赠范围内找到另一张显示卡之外还能做什么。 你有没有弄清楚你的问题? 此致,斯坦 以上来自于谷歌翻译 以下为原文 Hi Doug, I have a 54820A that has the identical problem as yours. It boots fine, responds to inputs, and basically does everything except display a graticule and the traces. In fact, a print preview of the screen shows the graticule and traces, it's just that they aren't making it to the display! The service manual says that the LCD display system consists of two interconnected PCI cards. The first card interfaces to the acquisition system to get the trace data points. It then feeds that data to the display driver card (the one with the VGA connector on the back) that generates all of the rest of the display elements. I hooked up an external monitor to the VGA connector and the display on it is identical to the internal VGA: everything is displayed except the graticule and traces. My working assumption is that the problem is with the card that interfaces to the acquisition system. That card has a soldered-in coin cell backup battery. I have not measured it but I have to assume that it's dead, or nearly so, after all these years. Other than replacing it, I'm not sure what else I can do other than find another display card from a parts donor scope. Did you ever figure out the problem with yours? Regards, Stan |
只有小组成员才能发言,加入小组>>
1262 浏览 0 评论
2365 浏览 1 评论
2180 浏览 1 评论
2049 浏览 5 评论
2935 浏览 3 评论
1048浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
737浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
869浏览 0评论
1263浏览 0评论
GMT+8, 2024-12-12 23:47 , Processed in 1.581399 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
