你好,我是MPLABX IPE的新手。我是MPLAB V8. X.的一个长时间用户。我试图导出一个具有特定起始结束地址的十六进制文件。“允许出口十六进制”在生产设置中被启用。在内存设置中,“手动选择”和“程序内存”只被选择。无论我在“程序存储范围”文本框中输入什么。E导出的HEX文件似乎从0x00开始到设备的整个程序存储范围。在“查看”菜单下,内存设置总是显示完整的内存范围。我遗漏了什么吗?如何仅导出指定范围?(这是16位设备,如DSPIC30F6014A)使用IPE V3.60感谢任何反馈。
以上来自于百度翻译 以下为原文 Hello, I am new to MPLABX IPE. I am a long time user of MPLAB v8.x. I am trying to export a Hex file that has a specific start end end address. 'Allow Export Hex' is enabled in production settings. In Memory settings, 'Manual Select' and 'Program Memory' only selected. No matter what I enter in the 'Program Memory Range' text box the exported hex file seems to start at 0x00 through to the entire program memory range of the device. Under the 'View' menu the Memory settings always shows the full memory range. Am I missing something ? How do I export only a specified range ? (This is for 16bit devices such as DSPIC30F6014A) Using IPE v3.60 Thanks for any feedback. |
4个回答
您可以手动编辑完整的图像。这很简单。我想知道你为什么要这么做。
以上来自于百度翻译 以下为原文 You can manually edit the full image. It's simple. May I know why you need to do this. |
您可以手动编辑HEX文件。删除所有空行并不难。
以上来自于百度翻译 以下为原文 You can manually edit the hex file. It's not that hard to delete all the empty lines. |
你好,谢谢你的反馈。我一直手动编辑的HEX文件,但有点痛苦,我必须小心,因为边界(开始边界)不是明显的大空白部分。工作与MPLAB V8。X,只要输入开始和结束地址,它吐出来。这将是很好的,如果这个在以后的版本中实现。我用它来生成软件引导加载程序的HEX文件,所以我不需要引导代码部分和其他配置区域。(引导代码不是在Microchip中指定的“引导”区域。所有代码都被指定为“一般”区域。
以上来自于百度翻译 以下为原文 Hello, Thanks for the feedback. I have been manually editing the hex file but is a bit of a pain and I must take care because the borders (start border) are not obvious large blank sections. Works ok with MPLAB v8.x , just enter the start and end address and it spits it out. It would be good if this is implemented in later versions. I am using it to generate hex file for a software boot loader so I do not want the boot code section and other configuration areas. (Boot code is not in Microchip specifed 'boot' area. All code is specified as 'general' area.) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
490 浏览 0 评论
5806 浏览 9 评论
2346 浏览 8 评论
2234 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3541 浏览 3 评论
1145浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1114浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
883浏览 1评论
489浏览 0评论
/9
GMT+8, 2025-12-9 16:59 , Processed in 0.580160 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
542
