电子发烧友论坛|
大家好。我正在编写PIC18F4685,但在与PICtiT2进行连接的那一刻,显示了“没有检测到设备”的信息。我已经测试了3个不同的图片相同的参考,问题仍然存在。我也做了故障排除测试,一切都井然有序。我的示意图如下:I也改变了电容器,最大到10uF,没有任何成功。
以上来自于百度翻译 以下为原文 Hi everyone. I am programming a PIC18F4685, but at the moment of making the connection with the pickit2 this shows the message: "No Device Detected". I have tested with 3 different PICs of the same reference and the problem persists. I also did the Troubleshoot Test and everything is in order. My schematic is as follows: http://i65.tinypic.com/30c0k2c.jpg I have also changed the capacitors up to a maximum of 10uf without getting any success. |
6个回答
离开电容器。皮特3指南说电阻器是的。电容器号是“裸”编程电路,建议是3。我看你有皮卡2,所以它可以工作,或者它可以煮你的皮卡2。
以上来自于百度翻译 以下为原文 Leave the capacitor out. PICKit 3 guide says resistors yes. Capacitors no. That's for 'bare' programming circuit. That advice is for PICKit 3. I see you have PICKit 2. So it may work or it may cook your PICKit 2. |
我现在看不到你的第一个帖子中的链接。我记得它显示了一些连接两个引脚的快捷方式。你能确认Vdd连接到Pin -11和Pin—32,VSS连接到Pin -12和Pin—31吗?
以上来自于百度翻译 以下为原文 I can't see the schematic via the link in your first post now. I remember it showed some shorthand for connecting power to two pins. Can you confirm that Vdd is connected to BOTH pin-11 and pin-32 and that Vss is connected to BOTH pin-12 and pin-31? |
我可以看到它。它显示的VDD引脚为“11/32”。你能确认这意味着你已经连接到两个引脚VDD?
以上来自于百度翻译 以下为原文 I can see it there. It shows the VDD pin as "11/32". Can you confirm that means you have connected VDD to both those pins? |
http://WW1.Microchip .com /下载/En/DeiceOC/4162B.PDF.这是一个挑剔的3用户指南。为皮卡2找到同样的东西。它应该有PigIt 2的接线图。这里是你的设备的数据表。http://W1.MicroChIP.COM/DeLoSs/En/DeViceDC/A/7761B.PDFFAT匹配PIN。
以上来自于百度翻译 以下为原文 http://ww1.microchip.com/downloads/en/DeviceDoc/41628B.pdf That's a PICKit 3 User Guide. Find the same thing for PICKit 2. It should have wiring diagram for PICKit 2. Here's datasheet for your device. http://ww1.microchip.com/downloads/en/DeviceDoc/39761b.pdf Just match up the pins. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:17 , Processed in 0.833254 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1079
