电子发烧友论坛|
嗨,所有,试图安装任何版本的MPLAB和谐在惠普笔记本电脑上。产品编号D1E81UA-阿巴莫德尔No.2000 2C29 WMIT已经切换到Linux Ubuntu 16.04,64位。当“/OrthyVyV203BLINUXXUnter安装程序。Run”进入控制台时,什么都没有发生,没有错误,没有启动,只是去了。下一行。与V1.XX版本相同。想也许记忆不够?根据系统要求,12.04位64位需要4 GB,安装了一个4 GB的模块和一个附加的插槽,其中添加了另一个4 GB的模块。点击“关于这台计算机”,它仍然说3.5 GB可用。(可能是系统使用的4 GB -512K?)也许我应该在HP论坛上问如何添加4 GB的RAM?感谢您的任何帮助。
以上来自于百度翻译 以下为原文 Hi all, Trying to install any version of Mplab HARMony on an HP laptop. Product No. D1E81UA#ABA Model No. 2000-2c29WM It has been switched over to Linux Ubuntu 16.04, 64 bit. When "./harmony_v2_03b_linux_installer.run" is entered on the console, nothing happens, no error, no startup, it just goes to the next line. Same with versions of v1.xx. Thought maybe not enough memory? 4 GB is needed for 12.04 64 bit according to system requirements. There was a 4 GB module installed and an additional slot into which another 4 GB module was added. Click "About this Computer", it still says 3.5 GB available. (perhaps 4 GB - 512K used by system?) So maybe I should be on an HP forum asking how to add 4 GB of RAM? Thanks in advance for any help. |
7个回答
您好,如果您的计算机不识别附加内存模块,它可能有几个原因:*错误模块(频率、内存组织、延迟、CAS…)您仔细检查该模块是否与您的计算机的精确模型兼容?计算机很难操作,BIOS在内存模块上读取特定的E2PROM以查看它是否符合计算机的需要。我个人喜欢关键的网站,因为它能够测试你的计算机并推荐适合计算机的内存模块。
以上来自于百度翻译 以下为原文 Hi, If your computer does not recognize the additional memory module it may have several causes : * wrong module (frequency, memory organization, latency, CAS...) Did you carefully check that this module is compatible with the exact model of your computer ? Computer are tricky and BIOS read a specific E2PROM on the memory module to see if it matches the need of the computer. I personally like CRUCIAL website because it is able to test your computer and recommend a memory module which fits the computer. Regards |
谢谢,我从我的电脑技术员那里得到了DIMM。但是根据HP网站,推荐的编号是64 1369-00,惠普收费85.31美元。我在Amazon找到了一个相当于22美元的等价物。大约75%的人似乎对这个角色很满意。所以在某些情况下,它不起作用。
以上来自于百度翻译 以下为原文 Thanks, I got the DIMM from my computer tech guy. But according to the HP web site, the recommended part no. is 641369-001 for which HP charges $85.31. I found what looks like an equivalent on Amazon for $22.00. About 75% of the people seem to be happy with the part. So in some cases, it did not work. |
我怀疑你的记忆问题与你安装和谐的能力有关。经常添加模式文本将帮助Microchip的安装程序运行。
以上来自于百度翻译 以下为原文 I doubt your memory issues are related to your ability to install Harmony. Often adding --mode text will help Microchip's installers run. |
我在下载的文件上使用CHMOD+X,然后运行它
以上来自于百度翻译 以下为原文 I use chmod+x on the downloaded file and then run it |
您好,试试:SUDO APT get LIbC66:Ib66Lbx11-6:Ib66LbStdC++6:I38 6LbExpAT1:I38 6CHMOD+X OrthyyV2Y03BLILUXXUnter安装程序。如果需要安装编译器和IDE,请运行Run./OrthyyV2Y03BYLUXXUSTEnter。unpar下载MPLABX下载的FILCHMOD+X MPLABX V3.61-LIUX安装程序。UDO。/MPLABX V3.61-LIUX安装程序。SH(需要SUDO,因为安装在/opt/Microchip和典型用户没有访问)SUDO。/XC32-V1.43全安装Linux安装程序。希望它有帮助。
以上来自于百度翻译 以下为原文 Hi, try: sudo apt-get install libc6:i386 libx11-6:i386 libxext6:i386 libstdc++6:i386 libexpat1:i386 chmod +x harmony_v2_03b_linux_installer.run ./harmony_v2_03b_linux_installer.run if you need to install the compiler and the ide: untar the MPLABX downloaded file chmod +x MPLABX-v3.61-linux-installer.sh sudo ./MPLABX-v3.61-linux-installer.sh (need sudo because installs in /opt/microchip and typical user doesn´t have access) sudo ./xc32-v1.43-full-install-linux-installer.run Hope it helps. |
行:SUDO APT获得安装LICB6:I38 6 LIXX11-6:I38 6LbxExt6:I38 6 LISTSTDC + 6:I38 6LbExpAT1:I38 6看起来像它的伎俩。安装开始并运行正常。谢谢。
以上来自于百度翻译 以下为原文 The line: sudo apt-get install libc6:i386 libx11-6:i386 libxext6:i386 libstdc++6:i386 libexpat1:i386 seemed like it did the trick. Install started and ran OK. Thanks. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 10:13 , Processed in 0.876917 second(s), Total 54, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
396
