我需要在我的PIC32 MZEFH144上创建一个静态计时器。我需要这是一个静态定时器,因为它应该运行大约200千赫,有一个最小的1毫秒动态定时器周期。在这个芯片上,我也运行和谐TCP,使用系统计时器,并已阅读,这排除使用静态定时器。我正在考虑手动配置。G为我的200千赫“定时器中断”,并保持和谐系统定时器为TCP & C;C对此方法的任何意见或建议的替代品将得到赞赏。谢谢。
以上来自于百度翻译 以下为原文 I need to create a static timer on my PIC32MZEFH144. I need this to be a static timer because it should run around 200 kHz and there is a minimum 1 ms period for the dynamic timers. On this chip I am also running HARMony TCP which uses the system timer, and have read that this precludes the use of static timers. I was thinking about manually configuring a timer for my 200 kHz" interrupt, and keeping the harmony system timer for TCP &c. Any opinions on this method or recommendations on alternatives would be appreciated. Thanks. |
5个回答
在你正在使用的芯片上有多个和谐计时器驱动程序实例。其中一个(TimeService 0,TimeReId1)必须被TCPIP的计时器系统服务所使用,但是您可以使用其余的任何一个为您的目的。只要进入MHC选项-& GT;驱动程序& GT;Time& GT;实例数选项,选择实例数为“2”,并根据您的请求配置第二个实例。修复。
以上来自于百度翻译 以下为原文 there are multiple harmony timer driver instances on the chip you are using. one of them (instamce 0, Timer_ID_1) must be getting used by Timer system service for TCPIP, but you can use any of the rest for your purpose. just go in MHC options->Driver->timer->number of instances option, select number of instance as "2" and configure the 2nd instance as per your requirement. |
这个动态的“实例2”能生成ISR @ 200 kHz吗?我的理解是动态定时器驱动器的最小周期为1毫秒。
以上来自于百度翻译 以下为原文 Can this dynamic "instance 2" generate an ISR @ 200 kHz? It is my understanding that dynamic timer drivers have a minimum period of 1 ms. |
HII从未读过这个限制。它在文档里吗?当做
以上来自于百度翻译 以下为原文 Hi I never read about this limitation. Is it in the documentation ? Regards |
您可以自己直接设置硬件计时器。不需要使用和声驱动程序。
以上来自于百度翻译 以下为原文 You can directly setup a Hardware timer yourself. You are not required to use the Harmony Drivers. |
我不认为TMRYIDID2有这样的限制,我能在美国范围内产生嘀嗒声。
以上来自于百度翻译 以下为原文 I do not think there is any such restriction over TMR_ID_2. I was able to generate a tick in us range. |
只有小组成员才能发言,加入小组>>
5234 浏览 9 评论
2026 浏览 8 评论
1950 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3200 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2253 浏览 5 评论
771浏览 1评论
659浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
588浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
669浏览 0评论
571浏览 0评论
GMT+8, 2024-12-19 19:53 , Processed in 1.350016 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
