它可以解决或可以通过TCP/IP搭建的应用程序,我用PIC16F87A进行小型项目
以上来自于百度翻译 以下为原文 what application it can solve or can be build over tcp/ip i have use pic16f877a for small project |
皮卡3可以在不买其他套件的情况下建造THSI项目吗?
以上来自于百度翻译 以下为原文 can pickit 3 can build thsi project without buying any other kit? |
PIC16F87A上的TCP/IP?我不这么认为。。。。
以上来自于百度翻译 以下为原文 tcp/ip on a pic16f877a? I don't think so.... |
可以运行堆栈的最小PIC是PIC18。如果你想使用一个旧的PIC16,你需要一个外部设备,比如WiZNET模块或者一个内置的WiFi模块。
以上来自于百度翻译 以下为原文 The smallest PIC that can run a stack is a PIC18. If you want to use an old PIC16 you will need an external device like a wiznet module or a wifi module with a built in stack. |
堆栈是PIC18.是的,我可以移动到它,但是如何构建它呢?
以上来自于百度翻译 以下为原文 stack is a PIC18. yes i can move to it but how to build it? |
你有什么硬件或愿意购买?你有一个挑剔的程序员/调试器吗?至于开发环境,MPLABX和各种C编译器都是免费的,可以在Microchip上运行,可以在Windows、Mac OS和各种Linux环境下运行。但是,如果你问这个问题,那么我不确定你是否准备好开始使用IP栈。你需要建立起来,确保你对开发环境和工具集感到满意,然后(非常)基本的嵌入式编程(例如闪存LED),并逐步从那里。苏珊。
以上来自于百度翻译 以下为原文 What hardware do you have or are willing to buy? Do you have a PicKit programmer/debugger? As for the development environment, MPLABx and the various C compilers are available free from Microchip and can run on Windows, macOS and various Linux environments. However, if you are asking this question then I'm not sure that you are ready to start using the IP Stack. You need to build up to it by making sure that you are comfortable with the development environment and toolset, then (very) basic embedded programming (e.g. flash a LED) and step by step from there. Susan |
您好,我已经使用皮卡2,现在我想移动皮卡3,并做一些互联网嵌入式项目,它会像设计网页和控制它如何工作?它是如何工作的?IP堆栈
以上来自于百度翻译 以下为原文 hello i have used pickit 2 and now i want to move pickit 3 and make some internet embedded project how does it will work like design webpage and control from it how? how it work? waht is IP stack |
“IP堆栈”是连接到TCP/IP网络所需的所有代码。这不是一个简单的练习。从你问的问题来看,很显然,你还没有准备好在PIC上实现这类事情。
以上来自于百度翻译 以下为原文 "IP stack" is all the code required to interface to a TCP/IP network. This is not a simple exercise. From the questions you are asking, it is plain you are NOT ready to implement this sort of thing on a PIC. |
嗨,看起来你只是从编程开始,我建议你从简单的事情开始,比如LED闪烁……建立一个TCP/IP协议栈并不是新手友好的,因为需要大量的文件和一个坚实的C理解。即使是以太网硬件本身也很棘手,除非你准备好投资I。一个现成的板…你有没有编程任何微控制器?你以前使用过MPLAB还是MPLAB X?当做
以上来自于百度翻译 以下为原文 Hi, As it seems you're just starting with programming, I suggest you start with simple things like led blinking,... Building a TCP/IP stack is not beginner friendly becuase lots of files are needed and a solid C understanding. Even the ethernet hardware itself is tricky unless you're ready to invest in a ready made board... Have you ever programmed any microcontroller ? Have you used MPLAB or MPLAB X before ? Regards |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1749 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2956 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-26 18:06 , Processed in 1.251000 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
