我在Windows 7上使用MPLAX 3.61的PIC32 ESK II,并且编程板每隔一段时间就一致地失败。我已经使用这个板几个月了,偶尔会有失败,但没有这样的事。我尝试了多个板,包括一个全新的。我已经尝试了不同的USB端口,在坞站和直接进入笔记本电脑。有一件事我没有尝试的是回到以前版本的MPLAB X.90%的时间,这就是我所看到的:偶尔它会包括一个消息,“程序内存不是空白”或“启动工具包上删除”。这是一个已知的问题吗?
以上来自于百度翻译 以下为原文 I'm using a PIC32 ESK II with MPLAB X 3.61 on Windows 7 and programming the board fails pretty consistently every other time. I've been using this board for months and have had occasional failures but nothing like this. I've tried multiple boards including a brand new one. I've tried different USB ports, both on the docking station and directly into the laptop. One thing I haven't tried is going back to a previous version of MPLAB X. 90% of the time, this is what I see: ***************************************************** Connecting to Starter Kit on Board... Currently loaded firmware on Starter Kit on Board Firmware Suite Version.....01.48.18 Firmware type..............PIC32MX Target voltage detected Target device PIC32MX795F512L found. Device ID Revision = 54300053 Device Erased... Programming... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x32fff boot config memory configuration memory Failed to program device Occasionally it will include a message that the "Program memory is not blank" or "Starter Kit on Board removed." Is this a known issue? |
1个回答
更新:我确实尝试回到以前的MPLAB X版本(3.60和3.55)。同样的结果。我开了一个支持案例。
以上来自于百度翻译 以下为原文 Update: I did try going back to previous MPLAB X versions (3.60 & 3.55). Same results. I've opened a support case. |
只有小组成员才能发言,加入小组>>
5238 浏览 9 评论
2028 浏览 8 评论
1950 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3204 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2253 浏览 5 评论
774浏览 1评论
664浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
592浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
674浏览 0评论
574浏览 0评论
GMT+8, 2024-12-22 17:20 , Processed in 1.304869 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
