嗨,我正在使用Agilent Technologies低配置模块化电源系统主机,N6700B带有直流电源模块N6732B。我的OV保护设置为7.5V。
电源设置为5V,电流= 0.5。当我将电源连接到电路时,显示OV故障。 使用另一个电源系统提供相同的V& A,电路正常运行而没有故障。 为什么有OV的迹象? 这意味着什么?谢谢。 -SY 以上来自于谷歌翻译 以下为原文 Hi, I am having Agilent Technologies Low-Profile Modular Power Systems mainframe, N6700B with DC power module N6732B. My OV protection is set as 7.5V. The voltage supply is set as 5V, current = 0.5A When I connect the power supply to my circuit, it shown OV failure. Using another power system to supply same V & A, the circuit is running fine without failure. Why is there indication of OV? What does it means? Thanks. -SY |
4个回答
嗨,OV表示过压保护,这意味着电源输出已超过7.5V。
这种行为可能有许多不同的原因。 让我们首先尝试理解这里的设置。 如果你不介意的话,只有几个问题可供我理解。 模块是局部还是遥感?2。 连接的电源是什么? 电阻负载? 你热切换? 基本上这意味着输出完全在你身上,然后将导线连接到DUT?让我知道,希望我们可以根据上述问题的答案找到原因.StevenAgilent Technologies 以上来自于谷歌翻译 以下为原文 Hi, OV means over-voltage protection which means the power supply output has exceeded 7.5V. There could a number of different reason for this behavior. Let's start by trying to understand the setup here. Just a few questions for my understanding if you dont mind 1. Is the moduels in local or remote sensing? 2. What is the power supply being connect to? Resistance load? 3. Are you hot switching? Basically that means with the output fully on you then connect the leads to the DUT? Let me know and hopefully we can find the reason based on the answers to the above questions. Steven Agilent Technologies |
嗨,史蒂文,我在昨天的其他试运行中得到了一些线索。
基本上,我将电源电压降至4V,电流降至0.08A,电路运行良好。 OVP发生在更高的电压/电流供应。 如果我没有弄错的话,负载引线会出现电压降(由于某些元件的电源电压过高),OVP检测到的电压因此高于负载调节的电压。 因此,系统触发OVP故障。 1.模块是局部还是遥感? 遥感2.连接的电源是什么? 电阻负载? 电阻负载3.您是否热切换? 基本上这意味着输出完全在你身上然后将引线连接到DUT? 是的,感谢您的意见。 谢谢。 -SY 以上来自于谷歌翻译 以下为原文 Hi Steven, I got some clue during other test runs yesterday. Basically, I reduce the supply voltage to 4V and current to 0.08A and the circuit is running fine. OVP happened on higher voltage / current supplied. If I am not mistaken, there is a voltage drop in the load leads (due to over-supply voltage to certain component, maybe), the voltage sensed by OVP thus higher than the voltage being regualted at the load. Thus, system trigger the OVP failure. 1. Is the moduels in local or remote sensing? Remote sensing 2. What is the power supply being connect to? Resistance load? Resistance load 3. Are you hot switching? Basically that means with the output fully on you then connect the leads to the DUT? Yes Aprreciate your comments. Thanks. -SY |
HI Steven,由于OVP,我将电源模块设置为CC模式时出现问题。
当电压增加/电阻减小时,电源模块触发OVP而不是改变为CC模式。 以下示例基于简单的仅电阻电路完成。例如:情况1:电压设置= 5V; 电流设置= 0.06A(最小电流设置),500欧姆电阻。 CV为0.01ATo的单位具有CC模式:情况2:电压设置= 5V; 电流设置= 0.06A,电阻为50欧姆。 该单元应进入CC模式,电压为0.06A,电压为3V。 电源模块触发OV,而不是进入CC模式。 适用于没有OV故障的单个50欧姆电阻器的最大电压为0.5V(电流设置= 0.06A)请您帮助解决此问题吗?谢谢。 -SY 以上来自于谷歌翻译 以下为原文 HI Steven, Due to the OVP, I am having problem to set the power module to CC mode. The power module trigger OVP instead of change to CC mode when the voltage is increase / resistance is decreased. Below examples is done based on simple resistor-only circuit. For example: Case 1: Voltage setting = 5V; Current setting = 0.06A (min current setting) with a 500 Ohm resistor. The unit in CV at 0.01A To have CC mode: Case 2: Voltage setting = 5V; Current setting = 0.06A with a 50 Ohm resistor. The unit should go into CC mode at 0.06A and the voltage is 3V. Instead of go into CC mode, the power module trigger OV. The maximum Voltage applicable to a single 50 Ohm resistor without OV failure is 0.5V (Current setting = 0.06A) Can you please help on this? Thanks. -SY |
嗨SY Lye,你能回答下面的问题1和3吗?
我对这两个问题仍然没有明确的答案。 模块是局部还是遥感?2。 连接的电源是什么? 电阻负载?3。 你热切换? 基本上这意味着输出完全在你身上然后将引线连接到DUT?你能给出一个你正在运行的过程的详细描述吗? 尽可能多的细节,包括你打开输出的顺序,并将电阻器物理连接到输出。你所描述的并不是我在正确设置下对功能电源所期望的。 所以问题是要么是有缺陷的电源,要么是不合适的设置。 我试图缩小范围,看看它可能是哪一个。试着 以上来自于谷歌翻译 以下为原文 Hi SY Lye, Can you answer questions 1 and 3 below? I still don't have a clear answer to those two questions. 1. Is the moduels in local or remote sensing? 2. What is the power supply being connect to? Resistance load? 3. Are you hot switching? Basically that means with the output fully on you then connect the leads to the DUT? Can you give m a detail description of process that you are running? As much detail as possible including the order which you turn on the output and physically connect the resistor to the output.. What you are described to me is not something that I would expect from a functional power supply under the proper setup. So the problem is either going to be a defective power supply or a improper setup here. I'm trying to narrow down to see which one it might be. Steven |
只有小组成员才能发言,加入小组>>
1262 浏览 0 评论
2365 浏览 1 评论
2180 浏览 1 评论
2049 浏览 5 评论
2935 浏览 3 评论
1038浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
735浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
862浏览 0评论
1262浏览 0评论
GMT+8, 2024-12-12 13:39 , Processed in 1.637070 second(s), Total 106, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
