大家好,几年前,我为PIC18F42编写了一个代码,把它的.HEX文件作为项目的可交付文件。HEX文件的文件大小大约是20KB。现在我需要那个文件,当我得到那个文件时,它的大小大约是36MB。Y应用程序代码,这就是为什么它的大小被炸毁?或者是什么原因,现在它的大小这么大?任何帮助都会很棒。
以上来自于百度翻译 以下为原文 Hello everyone, Few years back i wrote a code for PIC18F452 and gave it's .Hex file as deliverable of the project. The file size of .Hex file was approx 20kB. I needed that file now and when i get that file its size is approx 36MB. Is it possible that some bootloader code is added in the .Hex file of my application code and thats why its size has blown up? Or what could be the reason that its size is so big now? Any help would be great. |
19个回答
36MB对于你的PIC来说真的太多了,但是如果你“输出”完整的图像而不仅仅是使用的Flash,那么你的代码可能会发生这样的事情。
以上来自于百度翻译 以下为原文 36MB sounds REALLY too much for your PIC, but something like that could happen if you "Export" the full image and not just the used Flash, as required by your Code. |
这意味着什么:“当我得到那份文件”?问问你自己从那时起你改变了什么。是否有源代码的版本控制?升级编译器了吗?
以上来自于百度翻译 以下为原文 What does this mean: "when I get that file" ? Ask yourself what you have changed since then. Do you have a version control of your source ? Did you upgrade your compiler ? |
RoDimSi意味着我把HEX文件交给了我做过工作的公司。那边有人每天用这个文件闪PIC18F42,但我不知道他们是如何使用PACKIT或通用程序员或串口/引导程序来闪现控制器的。在十六进制文件,我要求他们发送给我。我从他们那里收到的是36MB的大小。他们正在使用这个文件,他们说它的工作很好。你知道为什么HEX文件大小从20KB爆炸到36MB吗?
以上来自于百度翻译 以下为原文 @rodims I mean that i gave the .Hex file to the company for whom i did that work. There are people over there who are using this file daily to flash the PIC18F452, but i dont know how exactly they flash the controller, using PICKIT or universal programmer or serial port/bootloader etc. Now i needed that .Hex file and i asked them to send that to me. What i received from them is 36MB in size. They are using this file and they say its working fine. Any idea how come the .Hex file size blow up from 20kB to 36MB? |
可能是这样的。我如何确认呢?
以上来自于百度翻译 以下为原文 @cinziaG yes that possibly be the case.. how can i confirm that? |
我不知道,因为如果他们会给你任何东西,但他们的原始十六进制文件的生产,他们会开玩笑。检查文件的日期“他们的”HEX文件(它不证明任何东西,但可能是线索)。如果你没有“原始”的HEX文件,你没有什么比…还是可以建立比较小的HEX文件?
以上来自于百度翻译 以下为原文 I have no idea, because if they would give you anything back but their original HEX file for production, they would be kidding you. Check the file date of "their" HEX file (it does not prove anything, but could be a clue) . If you have no "original" hex file, you have nothing to compare to ... Or can you still build the small hex file for comparison ? |
也许你可以在文本编辑器中打开.HEX文件,看看是否有很多行的0xFF
以上来自于百度翻译 以下为原文 Maybe you could open the .hex file in a text editor and look to see if there are many lines of 0xff |
他们可能给了完整内存的导出文件。包括配置位。配置比特用于不在十六进制文件中。如果你没有你的原创,那是不可能的。
以上来自于百度翻译 以下为原文 They probably gave to an exported file of the Full Memory. Including the Config bits. The config bits used to not be in the Hex files. If you do not have your original it would be impossible to tell. |
如果我在记事本+ +中打开文件,那么我看到大多数文件中都有0xFF,我能用我的帖子把文件附加到你的视图中吗?
以上来自于百度翻译 以下为原文 if i open the file in Notepad++ then i see most of the file filled with 0xff in it. is there some way that i can attach the file here with my post for your view? |
如果芯片在大文件闪烁时工作,则使用它并快乐。如果没有原始的源代码来重新创建较小的文件,那么可能您没有创建原始文件。
以上来自于百度翻译 以下为原文 If the chip works when flashed with the large file then use it and be happy. If you do not have the original source code to recreate the smaller file then maybe you did not create the original. |
这对于18F45来说太大了,不管它们是如何出口的。他们把错误的文件寄给你了。
以上来自于百度翻译 以下为原文 It's way too big for an 18F452, regardless of how they exported it. They sent you the wrong file. |
引用协议。18F45具有32字节的程序存储器。甚至每个比特的导出的HEX文件也不应超过100 KB。
以上来自于百度翻译 以下为原文 Quoted for agreement. The 18F452 has 32 Kbytes of program memory. Even an exported hex file of every bits should take no more than 100 KB. |
如果包含诸如EEPROM初始化之类的东西,则18F42.bin文件可以是~16MB。
以上来自于百度翻译 以下为原文 An 18F452 .bin file can be ~16MB if it includes things like EEPROM initialization. |
如果不同意,如果18F42的闪存被哑程序员读取并保存,则HEX文件将包括包括片上存储器(0到0x8000)、未实现内存区域(0x800 2到0x2FFFFF)、配置比特区域(0x3000到0x30F06)的整个连续存储器映像,另一个非实现。NDD内存区域(0x3000到0x3ffffd),最后是DEVID区域(0x3ffffe到0x3fffff),它是4194304个字或8388608个二进制字节,这又容易产生上面提到的巨大的HEX文件。赋给一个.bin文件,然后转换成十六进制文件。
以上来自于百度翻译 以下为原文 Quoted to disagree. If the 18F452's flash was read and saved by the dumb programmer, the HEX file will include the entire contiguous memory image including the on-chip memory (0 to 0x8000), non-implemented memory area (0x8002 to 0x2FFFFF), config bits area (0x300000 to 0x300006), another non-implemented memory area (0x300007 to 0x3FFFFD) and finally the DEVID area (0x3FFFFE to 0x3FFFFF) which is 4,194,304 words or 8,388,608 binary bytes, which in turn easily produces the above mentioned huge HEX file. The similar situation could occur if the memory has been read as a contiguous binary image, saved to a .bin file and then converted to the HEX file. |
您忘记了0xF000的EEPROM,这是我上面指出的36MB HEX文件更有可能的来源。
以上来自于百度翻译 以下为原文 You forgot the EEPROM at 0xF00000 which is the more likely source of the 36MB hex file as I pointed out above. |
那是一个愚蠢的程序员!读取0x00万到0xFFFFFF(16 MB)加上开销,我想它可以是36兆字节。
以上来自于百度翻译 以下为原文 That is one dumb programmer! Reading 0x000000 to 0xFFFFFF (16 MB) plus overhead I suppose it can be 36 MB. |
用ScReCCAT转换成十六进制的全二进制图像是37359996字节。
以上来自于百度翻译 以下为原文 A full binary image converted to hex with srec_cat is 37,359,996 bytes. |
附加比较(但访问被拒绝)是从MPLAB8的INHX32格式导出的18F45 2,它的文件大小为90.8 KB(93031字节)。
以上来自于百度翻译 以下为原文 For comparison :020000040000FA :10000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :10003000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10005000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10007000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10008000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10009000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :1000A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :1000B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :1000C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :1000D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :1000E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1000F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :10010000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :10011000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :10012000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :10013000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :10014000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :10015000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10016000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10017000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10018000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10019000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :1001A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :1001B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :1001C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :1001D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :1001E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :1001F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :10020000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :10021000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :10022000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :10023000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :10024000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :10025000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10026000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10027000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10028000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10029000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :1002A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :1002B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :1002C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :1002D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :1002E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :1002F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :10030000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :10031000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :10032000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :10033000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :10034000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :10035000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10036000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10037000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10038000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10039000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :1003A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :1003B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :1003C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :1003D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :1003E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :1003F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :10040000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :10041000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :10042000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :10043000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :10044000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :10045000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10046000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10047000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10048000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10049000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :1004A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :1004B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :1004C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :1004D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :1004E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :1004F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :10050000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :10051000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :10052000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :10053000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :10054000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :10055000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10056000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10057000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10058000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10059000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :1005A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :1005B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :1005C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :1005D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :1005E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :1005F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :10060000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :10061000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :10062000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :10063000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :10064000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :10065000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10066000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10067000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10068000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10069000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :1006A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :1006B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :1006C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :1006D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :1006E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :1006F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :10070000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :10071000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :10072000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :10073000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :10074000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :10075000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10076000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10077000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10078000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10079000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :1007A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :1007B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :1007C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :1007D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :1007E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :1007F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :10080000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :10081000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :10082000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :10083000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :10084000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :10085000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10086000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10087000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10088000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10089000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :1008A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :1008B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :1008C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :1008D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :1008E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :1008F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :10090000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :10091000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :10092000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :10093000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :10094000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :10095000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :10096000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10097000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10098000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10099000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :1009A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :1009B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :1009C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :1009D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :1009E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :1009F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :100A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :100A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :100A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :100A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :100A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :100A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :100A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :100A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :100A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :100A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :100AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :100AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :100AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :100AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :100AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :100AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :100B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :100B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :100B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :100B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :100B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :100B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :100B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :100B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :100B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :100B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :100BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :100BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :100BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :100BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :100BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :100BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :100C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :100C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :100C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :100C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :100C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :100C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :100C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :100C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :100C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :100C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :100CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :100CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :100CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :100CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :100CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :100CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :100D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :100D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :100D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :100D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :100D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :100D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :100D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :100D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :100D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :100D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :100DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :100DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :100DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :100DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :100DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :100DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :100E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :100E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :100E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :100E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :100E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :100E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :100E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :100E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :100E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :100E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :100EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :100EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :100EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :100ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :100EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :100EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :100F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :100F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :100F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :100F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :100F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :100F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :100F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :100F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :100F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :100F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :100FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :100FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :100FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :100FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :100FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :100FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :10100000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :10101000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :10102000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10103000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10104000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10105000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10106000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10107000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10108000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10109000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :1010A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :1010B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :1010C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :1010D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1010E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :1010F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :10110000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :10111000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :10112000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :10113000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :10114000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10115000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10116000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10117000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10118000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10119000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :1011A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :1011B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :1011C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :1011D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :1011E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :1011F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :10120000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :10121000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :10122000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :10123000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :10124000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10125000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10126000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10127000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10128000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10129000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :1012A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :1012B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :1012C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :1012D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :1012E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :1012F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :10130000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :10131000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :10132000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :10133000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :10134000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10135000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10136000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10137000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10138000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10139000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :1013A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :1013B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :1013C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :1013D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :1013E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :1013F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :10140000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :10141000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :10142000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :10143000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :10144000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10145000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10146000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10147000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10148000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10149000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :1014A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :1014B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :1014C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :1014D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :1014E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :1014F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :10150000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :10151000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :10152000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :10153000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :10154000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10155000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10156000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10157000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10158000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10159000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :1015A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :1015B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :1015C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :1015D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :1015E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :1015F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :10160000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :10161000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :10162000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :10163000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :10164000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10165000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10166000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10167000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10168000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10169000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :1016A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :1016B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :1016C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :1016D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :1016E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :1016F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :10170000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :10171000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :10172000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :10173000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :10174000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10175000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10176000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10177000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10178000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10179000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :1017A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :1017B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :1017C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :1017D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :1017E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :1017F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :10180000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :10181000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :10182000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :10183000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :10184000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10185000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10186000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10187000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10188000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10189000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :1018A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :1018B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :1018C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :1018D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :1018E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :1018F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :10190000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :10191000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :10192000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :10193000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :10194000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :10195000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10196000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10197000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10198000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10199000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :1019A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :1019B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :1019C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :1019D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :1019E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :1019F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :101A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :101A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :101A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :101A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :101A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :101A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :101A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :101A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :101A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :101A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :101AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :101AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :101AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :101AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :101AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :101AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :101B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :101B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :101B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :101B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :101B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :101B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :101B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :101B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :101B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :101B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :101BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :101BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :101BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :101BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :101BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :101BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :101C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :101C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :101C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :101C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :101C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :101C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :101C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :101C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :101C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :101C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :101CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :101CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :101CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :101CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :101CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :101CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :101D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :101D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :101D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :101D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :101D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :101D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :101D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :101D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :101D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :101D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :101DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :101DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :101DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :101DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :101DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :101DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :101E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :101E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :101E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :101E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :101E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :101E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :101E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :101E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :101E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :101E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :101EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :101EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :101EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :101ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :101EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :101EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :101F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :101F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :101F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :101F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :101F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :101F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :101F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :101F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :101F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :101F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :101FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :101FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :101FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :101FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :101FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :101FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :10200000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :10201000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10202000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10203000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10204000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10205000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10206000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10207000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10208000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10209000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :1020A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :1020B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :1020C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1020D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :1020E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :1020F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :10210000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :10211000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :10212000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :10213000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10214000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10215000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10216000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10217000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10218000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :10219000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :1021A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :1021B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :1021C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :1021D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :1021E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :1021F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :10220000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :10221000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :10222000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :10223000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10224000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10225000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10226000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10227000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10228000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :10229000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :1022A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :1022B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :1022C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :1022D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :1022E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :1022F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :10230000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :10231000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :10232000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :10233000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10234000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10235000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10236000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10237000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10238000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :10239000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :1023A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :1023B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :1023C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :1023D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :1023E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :1023F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :10240000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :10241000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :10242000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :10243000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10244000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10245000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10246000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10247000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10248000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :10249000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :1024A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :1024B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :1024C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :1024D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :1024E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :1024F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :10250000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :10251000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :10252000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :10253000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10254000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10255000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10256000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10257000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10258000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :10259000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :1025A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :1025B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :1025C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :1025D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :1025E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :1025F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :10260000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :10261000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :10262000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :10263000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10264000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10265000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10266000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10267000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10268000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :10269000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :1026A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :1026B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :1026C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :1026D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :1026E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :1026F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :10270000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :10271000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :10272000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :10273000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10274000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10275000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10276000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10277000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10278000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :10279000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :1027A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :1027B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :1027C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :1027D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :1027E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :1027F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :10280000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :10281000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :10282000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :10283000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10284000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10285000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10286000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10287000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10288000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :10289000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :1028A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :1028B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :1028C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :1028D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :1028E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :1028F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :10290000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :10291000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :10292000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :10293000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :10294000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10295000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10296000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10297000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10298000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :10299000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :1029A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :1029B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :1029C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :1029D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :1029E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :1029F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :102A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :102A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :102A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :102A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :102A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :102A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :102A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :102A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :102A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :102A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :102AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :102AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :102AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :102AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :102AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :102AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :102B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :102B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :102B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :102B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :102B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :102B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :102B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :102B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :102B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :102B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :102BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :102BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :102BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :102BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :102BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :102BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :102C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :102C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :102C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :102C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :102C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :102C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :102C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :102C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :102C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :102C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :102CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :102CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :102CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :102CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :102CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :102CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :102D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :102D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :102D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :102D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :102D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :102D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :102D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :102D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :102D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :102D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :102DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :102DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :102DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :102DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :102DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :102DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :102E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :102E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :102E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :102E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :102E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :102E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :102E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :102E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :102E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :102E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :102EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :102EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :102EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :102ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :102EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :102EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :102F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :102F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :102F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :102F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :102F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :102F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :102F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :102F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :102F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :102F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :102FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :102FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :102FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :102FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :102FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :102FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :10300000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10301000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10302000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10303000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10304000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10305000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10306000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10307000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10308000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :10309000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :1030A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :1030B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1030C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :1030D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :1030E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :1030F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :10310000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :10311000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :10312000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10313000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10314000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10315000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10316000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10317000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :10318000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :10319000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :1031A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :1031B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :1031C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :1031D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :1031E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :1031F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :10320000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :10321000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :10322000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10323000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10324000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10325000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10326000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10327000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :10328000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :10329000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :1032A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :1032B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :1032C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :1032D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :1032E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :1032F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :10330000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :10331000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :10332000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10333000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10334000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10335000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10336000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10337000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :10338000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :10339000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :1033A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :1033B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :1033C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :1033D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :1033E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :1033F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :10340000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :10341000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :10342000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10343000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10344000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10345000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10346000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10347000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :10348000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :10349000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :1034A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :1034B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :1034C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :1034D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :1034E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :1034F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :10350000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :10351000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :10352000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10353000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10354000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10355000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10356000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10357000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :10358000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :10359000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :1035A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :1035B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :1035C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :1035D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :1035E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :1035F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :10360000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :10361000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :10362000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10363000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10364000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10365000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10366000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10367000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :10368000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :10369000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :1036A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :1036B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :1036C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :1036D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :1036E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :1036F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :10370000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :10371000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :10372000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10373000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10374000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10375000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10376000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10377000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :10378000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :10379000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :1037A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :1037B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :1037C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :1037D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :1037E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :1037F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :10380000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :10381000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :10382000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10383000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10384000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10385000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10386000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10387000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :10388000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :10389000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :1038A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :1038B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :1038C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :1038D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :1038E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :1038F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :10390000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :10391000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :10392000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :10393000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10394000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10395000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10396000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10397000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :10398000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :10399000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :1039A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :1039B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :1039C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :1039D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :1039E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :1039F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :103A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :103A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :103A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :103A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :103A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :103A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :103A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :103A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :103A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :103A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :103AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :103AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :103AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :103AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :103AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :103AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :103B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :103B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :103B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :103B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :103B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :103B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :103B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :103B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :103B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :103B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :103BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :103BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :103BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :103BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :103BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :103BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :103C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :103C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :103C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :103C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :103C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :103C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :103C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :103C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :103C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :103C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :103CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :103CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :103CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :103CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :103CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :103CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :103D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :103D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :103D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :103D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :103D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :103D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :103D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :103D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :103D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :103D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :103DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :103DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :103DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :103DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :103DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :103DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :103E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :103E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :103E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :103E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :103E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :103E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :103E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :103E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :103E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :103E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :103EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :103EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :103EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :103ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :103EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :103EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :103F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :103F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :103F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :103F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :103F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :103F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :103F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :103F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :103F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :103F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :103FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :103FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :103FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :103FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :103FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :103FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :10400000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10401000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10402000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10403000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10404000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10405000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10406000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10407000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :10408000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :10409000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :1040A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1040B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :1040C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :1040D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :1040E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :1040F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10410000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :10411000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10412000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10413000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10414000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10415000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10416000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :10417000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :10418000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :10419000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :1041A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :1041B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :1041C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :1041D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :1041E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :1041F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :10420000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :10421000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10422000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10423000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10424000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10425000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10426000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :10427000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :10428000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :10429000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :1042A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :1042B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :1042C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :1042D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :1042E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :1042F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :10430000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :10431000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10432000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10433000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10434000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10435000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10436000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :10437000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :10438000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :10439000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :1043A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :1043B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :1043C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :1043D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :1043E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :1043F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :10440000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :10441000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10442000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10443000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10444000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10445000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10446000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :10447000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :10448000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :10449000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :1044A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :1044B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :1044C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :1044D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :1044E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :1044F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :10450000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :10451000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10452000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10453000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10454000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10455000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10456000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :10457000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :10458000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :10459000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :1045A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :1045B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :1045C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :1045D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :1045E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :1045F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :10460000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :10461000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10462000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10463000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10464000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10465000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10466000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :10467000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :10468000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :10469000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :1046A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :1046B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :1046C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :1046D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :1046E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :1046F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :10470000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :10471000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10472000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10473000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10474000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10475000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10476000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :10477000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :10478000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :10479000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :1047A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :1047B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :1047C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :1047D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :1047E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :1047F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :10480000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :10481000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10482000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10483000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10484000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10485000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10486000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :10487000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :10488000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :10489000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :1048A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :1048B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :1048C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :1048D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :1048E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :1048F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :10490000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :10491000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :10492000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10493000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10494000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10495000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10496000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :10497000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :10498000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :10499000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :1049A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :1049B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :1049C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :1049D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :1049E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :1049F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :104A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :104A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :104A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :104A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :104A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :104A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :104A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :104A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :104A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :104A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :104AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :104AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :104AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :104AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :104AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :104AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :104B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :104B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :104B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :104B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :104B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :104B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :104B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :104B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :104B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :104B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :104BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :104BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :104BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :104BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :104BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :104BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :104C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :104C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :104C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :104C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :104C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :104C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :104C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :104C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :104C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :104C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :104CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :104CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :104CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :104CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :104CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :104CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :104D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :104D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :104D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :104D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :104D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :104D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :104D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :104D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :104D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :104D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :104DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :104DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :104DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :104DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :104DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :104DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :104E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :104E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :104E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :104E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :104E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :104E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :104E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :104E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :104E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :104E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :104EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :104EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :104EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :104ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :104EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :104EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :104F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :104F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :104F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :104F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :104F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :104F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :104F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :104F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :104F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :104F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :104FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :104FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :104FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :104FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :104FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :104FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :10500000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10501000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10502000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10503000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10504000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10505000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10506000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :10507000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :10508000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :10509000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1050A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :1050B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :1050C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :1050D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :1050E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :1050F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10510000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10511000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10512000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10513000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10514000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10515000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :10516000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :10517000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :10518000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :10519000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :1051A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :1051B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :1051C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :1051D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :1051E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :1051F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :10520000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10521000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10522000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10523000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10524000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10525000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :10526000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :10527000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :10528000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :10529000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :1052A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :1052B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :1052C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :1052D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :1052E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :1052F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :10530000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10531000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10532000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10533000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10534000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10535000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :10536000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :10537000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :10538000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :10539000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :1053A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :1053B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :1053C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :1053D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :1053E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :1053F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :10540000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10541000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10542000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10543000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10544000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10545000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :10546000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :10547000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :10548000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :10549000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :1054A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :1054B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :1054C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :1054D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :1054E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :1054F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :10550000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10551000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10552000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10553000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10554000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10555000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :10556000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :10557000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :10558000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :10559000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :1055A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :1055B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :1055C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :1055D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :1055E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :1055F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :10560000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10561000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10562000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10563000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10564000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10565000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :10566000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :10567000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :10568000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :10569000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :1056A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :1056B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :1056C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :1056D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :1056E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :1056F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :10570000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10571000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10572000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10573000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10574000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10575000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :10576000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :10577000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :10578000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :10579000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :1057A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :1057B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :1057C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :1057D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :1057E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :1057F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :10580000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10581000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10582000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10583000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10584000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10585000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :10586000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :10587000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :10588000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :10589000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :1058A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :1058B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :1058C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :1058D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :1058E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :1058F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :10590000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :10591000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10592000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10593000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10594000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10595000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :10596000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :10597000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :10598000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :10599000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :1059A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :1059B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :1059C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :1059D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :1059E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :1059F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :105A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :105A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :105A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :105A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :105A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :105A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :105A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :105A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :105A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :105A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :105AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :105AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :105AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :105AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :105AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :105AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :105B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :105B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :105B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :105B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :105B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :105B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :105B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :105B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :105B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :105B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :105BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :105BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :105BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :105BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :105BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :105BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :105C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :105C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :105C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :105C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :105C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :105C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :105C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :105C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :105C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :105C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :105CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :105CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :105CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :105CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :105CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :105CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :105D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :105D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :105D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :105D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :105D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :105D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :105D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :105D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :105D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :105D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :105DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :105DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :105DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :105DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :105DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :105DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :105E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :105E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :105E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :105E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :105E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :105E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :105E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :105E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :105E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :105E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :105EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :105EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :105EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :105ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :105EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :105EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :105F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :105F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :105F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :105F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :105F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :105F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :105F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :105F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :105F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :105F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :105FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :105FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :105FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :105FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :105FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :105FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :10600000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10601000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10602000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10603000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10604000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10605000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :10606000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :10607000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :10608000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :10609000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :1060A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :1060B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :1060C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :1060D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :1060E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :1060F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10610000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10611000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10612000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10613000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10614000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :10615000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :10616000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :10617000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :10618000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :10619000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :1061A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :1061B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :1061C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :1061D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :1061E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :1061F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :10620000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10621000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10622000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10623000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10624000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :10625000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :10626000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :10627000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :10628000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :10629000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :1062A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :1062B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :1062C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :1062D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :1062E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :1062F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :10630000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10631000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10632000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10633000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10634000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :10635000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :10636000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :10637000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :10638000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :10639000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :1063A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :1063B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :1063C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :1063D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :1063E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :1063F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :10640000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10641000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10642000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10643000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10644000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :10645000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :10646000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :10647000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :10648000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :10649000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :1064A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :1064B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :1064C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :1064D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :1064E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :1064F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :10650000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10651000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10652000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10653000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10654000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :10655000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :10656000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :10657000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :10658000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :10659000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :1065A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :1065B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :1065C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :1065D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :1065E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :1065F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :10660000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10661000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10662000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10663000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10664000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :10665000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :10666000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :10667000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :10668000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :10669000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :1066A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :1066B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :1066C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :1066D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :1066E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :1066F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :10670000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10671000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10672000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10673000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10674000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :10675000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :10676000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :10677000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :10678000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :10679000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :1067A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :1067B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :1067C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :1067D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :1067E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :1067F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :10680000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10681000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10682000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10683000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10684000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :10685000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :10686000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :10687000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :10688000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :10689000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :1068A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :1068B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :1068C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :1068D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :1068E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :1068F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :10690000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :10691000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10692000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10693000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10694000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :10695000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :10696000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :10697000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :10698000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :10699000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :1069A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :1069B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :1069C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :1069D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :1069E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :1069F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :106A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :106A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :106A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :106A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :106A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :106A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :106A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :106A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :106A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :106A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :106AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :106AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :106AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :106AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :106AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :106AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :106B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :106B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :106B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :106B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :106B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :106B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :106B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :106B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :106B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :106B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :106BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :106BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :106BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :106BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :106BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :106BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :106C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :106C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :106C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :106C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :106C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :106C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :106C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :106C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :106C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :106C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :106CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :106CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :106CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :106CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :106CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :106CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :106D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :106D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :106D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :106D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :106D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :106D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :106D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :106D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :106D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :106D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :106DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :106DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :106DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :106DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :106DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :106DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :106E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :106E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :106E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :106E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :106E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :106E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :106E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :106E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :106E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :106E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :106EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :106EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :106EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :106ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :106EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :106EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :106F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :106F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :106F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :106F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :106F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :106F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :106F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :106F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :106F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :106F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :106FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :106FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :106FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :106FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :106FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :106FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :10700000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10701000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10702000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :10703000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :10704000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :10705000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :10706000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :10707000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :10708000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :10709000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :1070A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :1070B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :1070C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :1070D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :1070E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :1070F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10710000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F :10711000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F :10712000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F :10713000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F :10714000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F :10715000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F :10716000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F :10717000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F :10718000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F :10719000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF :1071A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF :1071B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF :1071C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF :1071D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF :1071E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF :1071F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F :10720000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E :10721000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E :10722000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E :10723000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E :10724000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E :10725000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E :10726000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E :10727000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E :10728000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E :10729000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE :1072A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE :1072B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE :1072C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE :1072D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE :1072E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE :1072F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E :10730000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D :10731000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D :10732000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D :10733000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D :10734000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D :10735000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D :10736000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D :10737000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D :10738000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D :10739000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD :1073A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED :1073B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD :1073C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD :1073D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD :1073E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD :1073F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D :10740000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C :10741000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C :10742000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C :10743000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C :10744000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C :10745000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C :10746000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C :10747000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C :10748000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C :10749000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC :1074A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC :1074B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC :1074C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC :1074D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC :1074E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC :1074F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C :10750000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B :10751000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B :10752000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B :10753000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B :10754000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B :10755000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B :10756000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B :10757000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B :10758000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B :10759000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB :1075A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB :1075B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB :1075C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB :1075D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB :1075E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB :1075F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B :10760000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A :10761000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A :10762000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A :10763000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A :10764000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A :10765000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A :10766000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A :10767000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A :10768000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A :10769000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA :1076A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA :1076B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA :1076C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA :1076D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA :1076E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA :1076F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A :10770000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89 :10771000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79 :10772000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69 :10773000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59 :10774000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49 :10775000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39 :10776000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29 :10777000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19 :10778000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09 :10779000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9 :1077A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9 :1077B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9 :1077C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9 :1077D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9 :1077E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9 :1077F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99 :10780000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88 :10781000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78 :10782000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68 :10783000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58 :10784000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48 :10785000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38 :10786000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28 :10787000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18 :10788000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08 :10789000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8 :1078A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8 :1078B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8 :1078C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8 :1078D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8 :1078E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8 :1078F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98 :10790000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87 :10791000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77 :10792000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67 :10793000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57 :10794000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47 :10795000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37 :10796000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27 :10797000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17 :10798000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07 :10799000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7 :1079A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7 :1079B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7 :1079C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7 :1079D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7 :1079E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7 :1079F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97 :107A0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86 :107A1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76 :107A2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66 :107A3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56 :107A4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46 :107A5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36 :107A6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26 :107A7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16 :107A8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06 :107A9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6 :107AA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6 :107AB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6 :107AC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6 :107AD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6 :107AE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6 :107AF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96 :107B0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85 :107B1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75 :107B2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65 :107B3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55 :107B4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45 :107B5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35 :107B6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25 :107B7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15 :107B8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05 :107B9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5 :107BA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5 :107BB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5 :107BC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5 :107BD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5 :107BE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5 :107BF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95 :107C0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84 :107C1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74 :107C2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64 :107C3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54 :107C4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44 :107C5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34 :107C6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24 :107C7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14 :107C8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04 :107C9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4 :107CA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4 :107CB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4 :107CC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4 :107CD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4 :107CE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4 :107CF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94 :107D0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83 :107D1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73 :107D2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63 :107D3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53 :107D4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43 :107D5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33 :107D6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23 :107D7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13 :107D8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03 :107D9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3 :107DA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3 :107DB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3 :107DC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3 :107DD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3 :107DE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3 :107DF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93 :107E0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82 :107E1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72 :107E2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62 :107E3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52 :107E4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42 :107E5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32 :107E6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22 :107E7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12 :107E8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02 :107E9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2 :107EA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2 :107EB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2 :107EC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2 :107ED000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2 :107EE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2 :107EF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92 :107F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81 :107F1000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71 :107F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61 :107F3000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51 :107F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41 :107F5000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31 :107F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21 :107F7000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11 :107F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01 :107F9000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1 :107FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1 :107FB000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1 :107FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1 :107FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1 :107FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1 :107FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91 :0200000400F00A :10000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00 :10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0 :10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0 :10003000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0 :10004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0 :10005000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0 :10006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0 :10007000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90 :10008000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80 :10009000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70 :1000A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60 :1000B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50 :1000C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40 :1000D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30 :1000E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20 :1000F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10 :020000040030CA :0E00000000270F0F000185000FC00FE00F401A :020000040020DA :08000000FFFFFFFFFFFFFFFF00 :00000001FF |
显然,从上面的讨论中,你得到的不是你所交付的,而是可能已经从已经编程的设备中读取的东西。客户丢失了原始的HEX文件,或者有人懒惰地从设备中读取它,而不是定位原始F。伊勒?
以上来自于百度翻译 以下为原文 Plainly from the above discussion, what you are getting back is NOT what you delivered, but is probably something that has been read back from an already programmed device. Has the customer lost the original hex file, or has someone lazy just read it out of a device instead of locating the original file? |
只有小组成员才能发言,加入小组>>
5166 浏览 9 评论
2000 浏览 8 评论
1929 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3175 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2227 浏览 5 评论
736浏览 1评论
619浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
507浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
633浏览 0评论
530浏览 0评论
GMT+8, 2024-11-25 03:17 , Processed in 2.087327 second(s), Total 85, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
