据我所知,安捷伦和其他T& M公司似乎可以根据SL261型号为AEMC的一种示波器电流探头进行OEM。
在比较物理形状因子和电气规格时,它们看起来几乎完全相同。 像往常一样,安捷伦在展示更多规格,图表以及更好的文档方面非常彻底......但我在操作,部件或规格本身中找不到太多差异(如果有的话)。 有人熟悉这些产品中的一种或两种吗? 一个区别可能是保修(安捷伦为3年)。 但内部的电子产品怎么样? 安捷伦是否指定了更好的组件,更严格的公差或更高的机械完整性? 我想购买一些这些探针,并希望了解其中的差异,如果有的话。 谢谢! 以上来自于谷歌翻译 以下为原文 As best as I can tell, it seems that Agilent and other T&M companies may OEM one of the scope current probes from AEMC based on the SL261 model. In comparing the physical form factor and the electrical specifications, they appear to be virtually identical. As usual, Agilent is very thorough in showing more specs, charts, along with better documentation...but I can't find much difference, if any, in the operation, part or spec itself. Is anyone familiar with either or both of these products? One difference may be the warranty (Agilent's is 3-years). But what about the electronics inside? Does Agilent specify better components, tighter tolerances or improved mechanical integrity? I'm looking to buy a couple of these probes and would like to understand the differences, if any. Thank you! |
1个回答
我怀疑是否有人愿意直接回答您对1146B电流探头内部问题的疑问。
我不知道价格差异是什么,如果有的话,但对用户的主要区别将是“更多的规格,图表,以及更好的文档...”,以及3年(可扩展到5) 保修,校准等。这一切都转化为支持。 如果支持对您很重要,您必须做出决定。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 I doubt that anyone would be willing to give you direct answers to the questions that you are asking about the internals in the 1146B Current Probe. I don't know what the price difference is, if any, but the major difference, to the user, will be "more specs, charts, along with better documentation...", along with the 3 year (extendable to 5) warranty, calibration, etc. This all translates to support. You have to make the decision if support is important to you. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1299 浏览 0 评论
2379 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1147浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
761浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
954浏览 0评论
1300浏览 0评论
GMT+8, 2024-12-30 03:30 , Processed in 1.467167 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
