电子发烧友论坛扫一扫,分享给好友
嗨,我是ADS的新手,在这个论坛上寻求帮助。
我已阅读有关测量表达式的用户手册。 我发现我可以用于模拟的一些表达式。 现在我可以使用max(out)来查找模拟数据的最大输出。 这里的问题是我不明白我是否可以返回图中单点的频率值。 示例:我想知道输出频率值何时为-3dB。 我不想手动从波德图中读取它。 可能吗 ? 此致,Victor007 以上来自于谷歌翻译 以下为原文 Hi, I am newbies in ADS and seraching for help in this forum. I have read the user manual on measurement expressions. I found that some of the expressions I can used for my simulation. Now I can use max(out) to find the maximum output of my simulation data. The problem here is I don't understand whether I can return the value of frequency for single point in the graph. Example: I wan to know when the frequency value when the output is -3dB. I don wan to manual read it from the bode plot. Is it possible ? Regards, Victor007 附件
2个回答
如何在输出端获得-3dB的频率来编写测量表达式?
我在交流分析中运行这个模拟。 测量表达式我使用的是gainmax = max(out); 这会返回最大输出值。 在3dB的频率我尝试使用find()但它不会工作。 以上来自于谷歌翻译 以下为原文 How to write the measurement expression in the way to get the frequency for -3dB at the output? I run this simulation in ac analysis. measurement expression I use is gainmax = max(out) ; this return the maximum values of output. frequency at 3dB i try to use find() but it wont work. |
你真的需要实际的频率,或者这只是一个步骤,使用max()函数来找到3dB带宽? 如果后者只使用bandwidth_func()测量方程并一次搜索3dB带宽。 +此函数返回过滤器响应的带宽。 带宽定义为幅度响应低于最大幅度的DesiredValue dB的上下频率之间的差值。 它使用迭代过程来找到带宽限制响应的非理想响应的带宽。+它适用于高通,低通,带通和带阻滤波器,因此:bw3dB = bandwidth_func(db(out),3,2)应该适用于 你的榜样。 以上来自于谷歌翻译 以下为原文 Do you really need the actual frequency or is this just a step, with the max() function, to find the 3dB bandwidth? If the latter just use the bandwidth_func() measurement equation and search for the 3dB bandwidth in one go. +This function returns the bandwidth of a filter response. Bandwidth is defined as the difference between the upper and lower frequency at which the amplitude response is DesiredValue dB below the maximum amplitude. It uses an iterative process to find the bandwidth on non-ideal responses for the band limited responses.+ It works for highpass, lowpass, bandpass and bandstop filters so: bw3dB = bandwidth_func(db(out), 3, 2) Should work for your example. |
只有小组成员才能发言,加入小组>>
1855 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3476 浏览 3 评论
1857浏览 0评论
429浏览 0评论
66浏览 0评论
/9
GMT+8, 2025-12-10 01:26 , Processed in 0.640963 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4327
