电子发烧友论坛|
该数据表表示,“RCXIF中断标志位是只读的,它不能被软件设置或清除”。我可以假设,虽然没有明确说明,通过清除SPEN重置EUSAT,然后断言SPEN确实会清除中断标志和RCXRG??
以上来自于百度翻译 以下为原文 The datsheet states, "The RCxIF interrupt flag bit is read-only, it cannot be set or cleared by software". Can I assume that although not explicitly stated, that resetting the eusart by clearing the SPEN and then asserting SPEN would indeed clear the interrupt flag and RCxREG ?? |
2个回答
好啊!我已经调整了生成的MCC代码,包括一个阅读,但我不知道我可以做你所做的。基本上我可以修剪进一步做你所做的,我希望。谢谢你的答复。
以上来自于百度翻译 以下为原文 OK! I have adjusted the MCC code that is generated to include a read but I didn't know I could just do what you've done. ... eusart2RxReadByte = RC2REG; eusart2RxReadByte = 0; RC2STAbits.SPEN = 0; // reset EUSART RC2STAbits.SPEN = 1; // assuming a reset eusart will not have RC2IF asserted ... ... Basically I can trim further to do what you've done I hope. Thanks for your reply. |
我们需要知道你使用的是哪一个PIC,但是我猜第一行就足够了,接下来的3个就是为了保证事情被搞乱。例如,你禁用并启用UART——如果它在接收下一个字符的中间会怎么样?它会放弃它接收到的任何东西,开始在一个字符的中间接收,当信号停止时,可能会产生一个帧错误。苏珊
以上来自于百度翻译 以下为原文 We need to know which PIC you are using but my guess is that the first line would be enough and the next 3 are simply there to guarantee things get messed up. For example, you disable and then enable the UART - what if it was in the middle of receiving the next character? It would drop whatever it had received, start receiving in the middle of a character and might generate a framing error when the signal stops. Susan |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:19 , Processed in 1.164866 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
471
