如何将csv文件传输到PC笔记本电脑?
DataLink程序似乎只捕获屏幕,我想要数据。 它保存在microSD卡上,但我们似乎无法阅读使用Windows 7计算机。 有没有办法使用直接以太网连接或USB线? 以上来自于谷歌翻译 以下为原文 How can I tranfer a csv file to a PC laptop? The DataLink program seems to only capture the screen and I want the data. It is saved on a microSD card but we can't seem to read that using a Windows 7 computer. Is there a way using a direct ethernet connection or a USB cable? |
3个回答
使用DataLink,在“Instrument Connect”窗口中右键单击已配置的仪器,然后选择“Show Files”。
然后右键单击.csv文件,并选择“发送到PC”。 该文件将被发送到PC上的某个位置,该位置由Tools-> Options-> Paths下的设置决定。 默认为'My Documents FieldFox FFoxModel_FFoxSerialNum yourfile.csv - Wil 以上来自于谷歌翻译 以下为原文 Using DataLink, right click on your configured instrument in the "Instrument Connect" window, and choose 'Show Files'. Then right click on your .csv file, and choose 'Send To PC'. The file will be sent to a location on your PC determined by the settings under Tools->Options->Paths. The default is 'My DocumentsFieldFoxFFoxModel_FFoxSerialNumyourfile.csv - Wil |
我不确定为什么你不能用电脑读SD卡。
您可以将其保存在USB记忆棒上,然后从计算机上读取记忆棒。 这可能是最简单的方法。 在FieldFox上,按Save / Recall Device - 从inetrnal更改为USB保存文件类型为csv然后保存在u***棒上在计算机上读取该文件。 然后当然有Wil描述的数据链接。 或者,如果您熟悉ftp,则可以从“dos”提示符ftp到该框并“获取”文件。使用passwd作为匿名登录,这是一种电子邮件格式,如fieldfox@fieldfox.net问候,Afsi 以上来自于谷歌翻译 以下为原文 I'm not sure why you can't read the SD card with your computer. You can just save it on a USB stick and then read the stick from your computer. That's probably the simplest way. On FieldFox, press Save/Recall Device -- change from inetrnal to USB save file type to csv then save on the u*** stick Read that file on your computer. Then of course there is Data link which Wil described. Alternatively, if you're familiar with ftp, you can ftp to the box from a "dos" prompt and "get' the file. logon as anonymous with a passwd that is some email format, like fieldfox@fieldfox.net Regards, Afsi |
谢谢,我能够将PC连接到FieldFox,并在将数据从SD卡传输到内部存储器后,检索.csv文件
以上来自于谷歌翻译 以下为原文 Thanks, I was able to connect the PC to the FieldFox and, after transferring the data from the SD card to the internal memory, retrieve the .csv files |
只有小组成员才能发言,加入小组>>
1072 浏览 0 评论
2307 浏览 1 评论
2094 浏览 1 评论
1968 浏览 5 评论
2839 浏览 3 评论
841浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
716浏览 0评论
1398浏览 0评论
1072浏览 0评论
GMT+8, 2024-10-1 09:50 , Processed in 1.385879 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
