电子发烧友论坛|
我在汇编中有一些项目可能永远不会切换到“C”。我们仍然定期添加特征/进行维护。MPLAX X有足够的优势,现在我不再在MPLAB 8的这些项目上工作,但有两件事我错过了。我知道他们在名单上可能不高,但我想知道他们到底是不是在名单上?汇编完成代码。似乎很容易做到。只需使用.map文件标签和.Inc文件标签即可创建List.AutoIndInter,MPLAB 8方式。在MPLAX中自动缩进汇编文件是没有帮助的,我把它关掉了。使缩进级别与前一行缩进级别匹配最有帮助。请把这些放在MPLAB X要做的列表上好吗?
以上来自于百度翻译 以下为原文 I have a few projects in assembly that will probably never get switched to 'C'. We are regularly still adding features / doing maintenance. MPLAB X has enough advantages now that I no longer work on these projects in MPLAB 8, but there are two things that I miss. I know they are probably not high on the list to do, but I was wondering if they were even on the list at all?
4个回答
我不认为1真的是一个选项,没有代码完成。不,2,我觉得最好是点击Tab.Tab助记符和TAB到操作数/s。毕竟它是低级编码。
以上来自于百度翻译 以下为原文 I don't think 1 is really an option, no code to complete. No. 2, I find it better to just hit tab. tab mnemonic and tab to operand/s. It is low level coding after all. |
没有完成代码吗?数以百计的RAM数据标签,还是数以千计的程序标签?MPLAB 8做得相当成功。标签只是一个击键保护程序…称之为懒惰。但这不是工程的主要内容吗?再次,MPLAB 8做到了这一点。
以上来自于百度翻译 以下为原文 No code to complete? How about hundreds of RAM data labels, or thousands of program labels? MPLAB 8 did it fairly successfully. The tab is just a keystroke saver... call it laziness. But isn't that what much of engineering is about? Again, MPLAB 8 did it. |
汇编编辑速度很快,添加C型自动完成会使它慢下来。在一个程序中,你将如何拥有1000个标签和100个变量。更多的人使用C而不是ASM,所以我不认为Microchip改变了这一点。
以上来自于百度翻译 以下为原文 Assembly editing is fast, adding c type auto-complete would slow it down. How would you have 1000's of labels and 100's of variables in a single program. With that many auto-complete would grind to a halt. I'd rather it stayed as it is. More people use C than asm so I don't see Microchip changing that. |
我同意Gort,AutoTebug是缓慢的,即使在MPLAB 8中,它被激活了& lt;ctrl& gt;+& lt;空间& gt;然后从列表中选择。我打字比那个快。)MPLAB X自动缩进,它也与前一行的缩进水平匹配。
以上来自于百度翻译 以下为原文 I agreed with Gort that Autocomplete is slow, even in MPLAB 8 where it's activated with MPLAB X does Auto-indent -- it matches the indent level of the previous line too. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 07:15 , Processed in 0.819477 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1510
