电子发烧友论坛|
嗨,我正在尝试模拟一个VCO,它需要一个具有5 - 9V * * DC电压的斜坡发生器的输入,并输出* 2 - 4 GHz *。
我希望斜坡发生器*上升时间为10毫秒*。 1)我不确定如何设置Kv(VCO Hz / Volt的调谐灵敏度),以便提供结果。 我的理解是:调谐电压范围= 4V带宽= 2 GHz * Kv * = 2GHz / 4V = 500 MHz 2)在模拟中,如果我放大到Vosc_out,在某些时候有空格,振荡不会 看起来随着时间的增加而增加......? 3)是否可以获得振荡输出频率与调谐电压(V_ramp)图? 如何做呢? 否则,如何确定振荡频率,我不认为测量振荡周期的峰值是正确的,因为周期随时间不断变化...请参阅附件中的数字。 非常感谢你的帮助,编辑:Vivian于2014年6月10日下午12:17 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to simulate a VCO such that it takes an input from a ramp generator with a *DC voltage of 5 - 9V*, and outputs *2 - 4 GHz*. I want the ramp generator *rise time to be 10 msec*. 1) I'm not sure how to set the Kv (tuning sensitivity of the VCO Hz/Volt) such that it will provide the result. What I understand is: tuning voltage range = 4V bandwidth = 2 GHz *Kv*=2GHz/4V = 500 MHz 2) In the simulation, if I zoom in to the Vosc_out, there are spaces at certain times, the oscillation doesn't look like its increasing as time increases...? 3) Is it possible to get a oscillation output frequency versus tuning voltage (V_ramp) graph? How can it be done? Otherwise, how can the oscillation frequency be determined, I don't think measuring the peaks for the oscillation period is correct as the period is constantly changing across time... Please see attached file for figures. Thank you very much for your help, Edited by: Vivian on Jun 10, 2014 12:17 PM 附件
5个回答
您好Aehoward,非常感谢您的建议,非常有帮助。
模拟的目的是了解当使用混频器实现VCO相位噪声如何影响IF。 现在我正在尝试将相位噪声添加到VCO。 1)我不确定哪个模拟器是合适的。 据我所知,SSB相位噪声为dBc / Hz,因此可以在频谱中观察到,因此可以使用HB模拟器。 但是,信号是及时生成的,所以应该使用CE模拟器吗? 2)我使用PM_ModTuned添加了相位噪声,但模拟图形没有多大意义..(请参见附图)3)或者是否应该使用CE模拟器中的噪声选项添加相位噪声? 非常感谢您的帮助, 以上来自于谷歌翻译 以下为原文 Hi Aehoward, Thank you very much for your advice, it helped very much. The purpose of the simulation is to understand how VCO phase noise affects the IF when implemented with a mixer. Now I’m trying to add phase noise to the VCO. 1) I’m not sure which simulator is appropriate. What I understand is SSB phase noise is dBc/Hz so it's observed in the frequency spectrum, hence can use HB simulator. However, the signal is generated in time, so CE simulator should be used? 2) I have added phase noise using PM_ModTuned, but the simulated graph doesn’t quite make sense.. (Please see attached figure) 3) Or should the phase noise be added using the noise option in the CE simulator? Thank you very much for your help, 附件
***5 发表于 2019-1-30 17:55 谢谢你的建议。 还有一些事情不清楚,你能帮忙吗? 1)如何在DAC中设置自变量名称和值? 自变量名是否始终是访问行的索引值? 独立值* log(abs(freq)+ 1e-6)*表示什么? 为什么当我拿走* 1e-6 *时,模拟没有运行并说没有DC收敛。 2)如何平均模拟结果以获得体面的相位噪声图? 我可以使用X的参数扫描重复模拟,但是当我尝试:* average = sum(PMdemod)/(重复的模拟次数)*时,结果不正确... 3)当我改变Vtune电压时, VCO频谱不会转换到相应的频率:+ f0 = Vtune * kv = 1 * 1GHz = 1GHz + ..? 4)对于频域模拟,是通过用V_tone源代替HB和VCO的包络来完成的。 请参阅附图。 非常感谢你! 以上来自于谷歌翻译 以下为原文 Thank you for the advice. There are still some things that are unclear, could you please help? 1) How to set the independent variable name and value in the DAC? Is the independent variable name always an index value to access the rows? What does the independent value *log(abs(freq)+1e-6)* means? How come when I take away the *1e-6*, the simulation doesn’t run and says no DC convergence. 2) How to average the simulation results to get decent looking phase noise plots? I can repeat the simulation using a parametric sweep of X, but when I try to: *average=sum(PMdemod)/(repeated number of simulation)*, the results isn’t correct… 3) When I changed the Vtune voltage, the VCO spectrum does not shift to the corresponding frequency: +f0=Vtune*kv=1*1GHz=1GHz+..? 4) For simulating in frequency domain, is that done by replacing envelope with HB and VCO with a V_tone source..? Please see attached figures. Thank you very much! 附件
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1854浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-8 18:13 , Processed in 0.892139 second(s), Total 84, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2372
