您好,背景:我想控制一个VS1053B突破板与一个DSPIC30F6011A(使用MPLAB V8)。我知道有两个突破板可以帮助,一个来自AdfRuIT,另一个来自GeTeCH,但是,我发现的例子是使用ARDUNO,18F,24F,30F4013(用户共享他们的发现的网站不再是UP),或者是一个3F.问题:我的主要问题是我是如何做到的?初始化SD卡并读取SD卡上的数据。有没有我可以指出的方向?我见过很多使用IoSt流但CC编译器不保存任何内置函数的例子。我错过什么了吗?谢谢你提供的任何信息
以上来自于百度翻译 以下为原文 Hello, Background: I am looking to control a vs1053b breakout board with a dspic30f6011A (using Mplab v8). I know there are a couple breakout boards that can be of assistance, one from Adafruit and the other from geetech, however, the examples I am finding use an Arduino, 18f, 24f, 30f4013 (the website where the user shared their findings is no longer up), or a 33f. Question: My main question is how do I initialize the sd card and read the data off of the sd card as well. Is there a direction I can be pointed to? lots of examples I've seen use iostream but CC Compiler does not hold any built-in functions to do so. Am I missing something? Thank you for any information Scott |
3个回答
你可以使用来自旧MLA(库)的微芯片FAT代码:我确信它们可以被编译成一个DSPIC30(可能与旧的COMPILR C30一起编译),但是在任何情况下,从Pic24或33移植都不难。
以上来自于百度翻译 以下为原文 You could use the Microchip FAT code from old MLA (Libraries): I am pretty sure they could be compiled for a dsPIC30 (maybe along with old compilr C30) but in any case a porting from PIC24 or 33 should not be that difficult. |
1。设置SPI2。下载SD卡规范PAR1Y410(初始化,命令,布线,它是参考,而不是初学者)3。Download WinHex用于窥视二进制文件。4。获得FAT16/32规格。5。了解群集、扇区、根扇区、长文件名。也就是说,如果你自己写的话,你不必使用FAT16/32.1,而2是必须的。
以上来自于百度翻译 以下为原文 1. Setup SPI 2. Download SDCARD SPECS part1_410 (Initialize, commands, wiring, it is reference, not for beginners) 3. Download WinHex for peeking into binary files. 4. Get the fat16/32 specs. 5. Understand clusters, sectors, root sectors, long filenames. That is if you are writing your own. You do not have to use fat16/32. 1 and 2 is a must. |
CinziaG:谢谢,我会查一下旧的MLA库,看看我是否需要其他编译器。GOTT2015:太棒了!我也会顺着这条路往下看,我的旅程还在继续!斯科特
以上来自于百度翻译 以下为原文 CinziaG: Thank you, I will look up the old MLA libraries and see if I need the other compilier. Gort2015: Great! I'll look down this path as well. My Journey continues! Scott |
只有小组成员才能发言,加入小组>>
5238 浏览 9 评论
2028 浏览 8 评论
1950 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3204 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2253 浏览 5 评论
777浏览 1评论
666浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
595浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
676浏览 0评论
576浏览 0评论
GMT+8, 2024-12-23 04:29 , Processed in 1.321669 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
