大家好,我把我的版本升级到MPLAB-C18-UpGRADE-V3Y35.EXE。这对我来说已经很多年了。现在,我买了PIC-WEB;它需要MPLAB-C18-UpGeRAD-V3Y47.EXE。我发现升级版本改为MPLAB XC。编译器是PIC18的XC。它不承认我的旧版本。MCC18升级页面发生了什么?谁知道我在哪里可以得到MCC18升级?谢谢
以上来自于百度翻译 以下为原文 Hi All, I kept my version upgrade to MPLAB-C18-Upgrade-v3_35.exe. That was working for me for so many years. Now, I bought PIC-WEB; it requires MPLAB-C18-Upgrade-v3_47.exe. I found the upgraded versions changed to MPLAB XC. The compiler is XC for PIC18. It did not recognize my old version. What happened to MCC18 upgrade page. Anyone knows where can I get MCC18 upgrade. Thanks |
9个回答
嗨,Jtemples给了你正确的链接。请仔细检查长列表,你会发现C18编译器的档案如下:“MPLAB C编译器的PIC18”的问候
以上来自于百度翻译 以下为原文 Hi, Jtemples gave you the right link. Please check carefully the long list and you'll find C18 compilers archives under : "MPLAB C Compiler for PIC18" Regards |
最新的版本是:HTTP://www. MyCHIP.COM/DeavigoToSs/OpjtDebug?ASPX?PotoNo=SW06011,它绝对是C18,只需查看该页上的发行说明。
以上来自于百度翻译 以下为原文 The latest version is here: http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=SW006011 And it's definitely C18, just look at the release notes on that page. |
如果你在过去购买MCC18,你尝试用这个升级。它不会像过去那样期待MCC18安装升级。它会提示你没有原始版本升级。尽管我尝试将位置设置为c:MCC18。MCC18安装在C目录的根目录下。这个新的升级安装在C:程序文件(x86)中。试试看,让我知道。谢谢大家。
以上来自于百度翻译 以下为原文 If you purchased MCC18 in the past , and you try to upgrade with this one . It will not look for mcc18 installation to upgrade as used to be in the past. It will prompt that you don't have the original version to upgrade. Even though I tried to set the location to c:mcc18. mcc18 installed in the root directory of c drive. This new upgrade installs itself in c:Program Files(X86). Try it and let me know. Thanks for all. |
你好,我倾向于使用PIC18FJ60@ 40兆赫,因为它包括以太网。我在手册中看到外部振荡器输入必须总是有一个25 MHz的时钟源。当使用以太网应用时。我需要控制器运行@ 40MHz。解决方案是什么?谢谢
以上来自于百度翻译 以下为原文 Hi jtemples, I tend to use PIC18FJ60 @ 40 MHZ because it includes Ethernet. I read in the manual that the external oscillator input must always have a 25 MHZ clock source. when used Ethernet application. I need the controller to run @ 40MHZ. What's the solution? Thanks |
另一个晶体在ENC AM现在不确定,如果我真的尝试输出125MHz从EnC和喂养到PIC连同它的预分频器…50MHz!当然,超出规格。
以上来自于百度翻译 以下为原文 Another Crystal at the ENC Am not sure now if I did try outputting 12.5MHz from the ENC and feeding to the PIC along with its prescaler... 50MHz! Of course, out of spec... |
HI CinziaG,PIC18F97 J60是在以太网中构建的。我没有看到任何独立的输入源来运行以太网(@ 25MHz),这意味着我已经降低了速度(40MHz)。你有什么想法吗?
以上来自于百度翻译 以下为原文 Hi CinziaG, PIC18F97J60 is built in Ethernet. I didn't see any independent input source to run the Ethernet (@25Mhz).Which means I have to sacrifice the speed (40MHZ). Do you have any idea? |
25MHz晶体/振荡器,3预分频器和5锁相环提供41.667兆赫。你不能精确到40MHz。这是个问题吗?
以上来自于百度翻译 以下为原文 with 25MHz crystal/oscillator, /3 prescaler and *5 PLL gives 41.667MHz. You can't get 40MHz exactly. Is that a problem? |
哦,你说得对,对不起,我错过了那一部分。我不确定,我从来没有用过它,看起来你必须…
以上来自于百度翻译 以下为原文 Ooops, you're right, sorry I missed that part. I am not sure then, I've never used it and looks like you have to... |
谢谢你的夸夸其谈,你说得对。我在SEC 3.6-1看到了这个。我以前在以前的MCU中没有看到这个特性。
以上来自于百度翻译 以下为原文 Thanks mbrowning, you are right. I saw this in sec 3.6.1. I didn't see this feature in the previous MCU I used before. |
只有小组成员才能发言,加入小组>>
5160 浏览 9 评论
1998 浏览 8 评论
1927 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3170 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2225 浏览 5 评论
727浏览 1评论
612浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
501浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
626浏览 0评论
524浏览 0评论
GMT+8, 2024-11-22 03:22 , Processed in 1.949941 second(s), Total 93, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
