电子发烧友论坛|
嗨,我使用agilent signal studio生成LTE信号,我保存了我进入scp格式的波长,但是当我尝试在VSA上调用它时,我没有得到相同的参数。
例如,带宽不同,也是中心频率。 如何使用与signal studio相同的参数调用信号? 谢谢, 以上来自于谷歌翻译 以下为原文 Hi, I generate an LTE signal with agilent signal studio, I save the wavelength I get into to scp format, but when I try to recall it on VSA i didn't get the same parameters. for example the bandwith is not the same and the center frequency as well. How to recall a signal with the same parameters as signal studio? Thanks, |
3个回答
您使用的是哪种版本的Signal Studio?
您使用的是什么版本的VSA? 你能提供.scp文件吗? 以上来自于谷歌翻译 以下为原文 What version of Signal Studio are you using? What version of VSA are you using? Can you provide your .scp file? |
对于signal studio:11.1 VSA:16.2我想用它来进行LTE而不是LTE-A解调这是我的.scp文件谢谢
以上来自于谷歌翻译 以下为原文 For signal studio: 11.1 VSA: 16.2 I want to use that for LTE and not LTE-A demodulation Here is my .scp file Thank you 附件
嗨,我看到VSA支持导入使用Signal Studio为版本7.9到9.6创建的Agilent Signal Studio LTE波形设置文件。
所以我已经安装了Signal studio 9.5版,但它仍然无效。 我有一个VSA错误“错误调用文件”,当我使用11.1版本创建的文件时,我没有得到。 我真的不明白它是如何工作的? 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I see that VSA supports importing Agilent Signal Studio LTE waveform setup files created using Signal Studio for versions 7.9 to 9.6. So I have installed signal studio version 9.5, but still it doesn't work. I have a VSA error "Error recalling file", that I don't get when I use a file created with the 11.1 version. I really don't understand how it work ? Thank you |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:47 , Processed in 0.800375 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2700
