我认为BearSSL可以很方便地被移植。我想我会很快尝试它。泛型IO看起来不太难管理。
以上来自于百度翻译 以下为原文 I think BearSSL could be ported quite handily. I think I am going to try it soon. The generic IO looks like it wouldn't be too hard to manage. https://bearssl.org/api1.html |
我会给WOFSSL一个尝试,阅读它,并且在构建期间可以选择不需要的所有特征。如果是这样,剩下的代码应该是小的和易于采用的。我只需要Sa1和RSA,都比较简单,但计算密集型。让我们知道BeaSSL是如何设计出来的!江户
以上来自于百度翻译 以下为原文 I'll give WolfSSL a try, read up on it and during build can opt out all features not required. If that so, the remaining code should be small and easy to adopt. I only need SHA1 and RSA, both relatively simple but calculation intensive. Let us know how did bearssl worked out! Edo |
WOLFSSL是GPL,除非你支付5000美元+许可证。
以上来自于百度翻译 以下为原文 WolfSSL is GPL unless you pay $5000+ for license. |
最后我用了保鲁夫所用的数学库……更清楚。
以上来自于百度翻译 以下为原文 I ended up using the Math library that was used by Wolf... ..much clearer. |
我能问一下和谐图书馆有什么问题吗?即使你不想使用完全和谐,它的大部分在那里。
以上来自于百度翻译 以下为原文 can i ask whats wrong with the harmony library? even if you did'nt want to use full blown harmony, most of its there. |
也许和睦现在不同了…IDK,半年前,它是一个半烤烂摊子混乱。好的意图是不够的,即使演示代码也不会运行,这是一个不好的标志。所有这些都从使用PIC32 MZ系列来看,我知道大多数MX和更早的/有点好。我相信有很多人喜欢和声,我不想争论。
以上来自于百度翻译 以下为原文 Maybe Harmony is different now... idk, half a year ago it was a half-baked bug-ridden mess. Good intentions are not enough, when even the demo code won't run that is a sign of something is not OK. All this in perspective of using the PIC32MZ series, i know most MX and earlier was/is somewhat ok. I'm sure there are many who like Harmony and i don't want to get into an argument about it. |
嗨,刚刚找到了MPETTLS端口到PIC32 MZ:HTTPS://Github. COM/Spjkytoo/MbDys/Bulb/Mask/Read M.描述:如何在MIC32芯片和声框架2.04上使用MPETTLS,在PIC32 MZ2048 EFH144以太网SARTETKIT上,在UART2上运行控制台接口(路由到MCP2221芯片)
以上来自于百度翻译 以下为原文 Hi, Just found mBedTLS port to Harmony v2.04 for PIC32MZ : https://github.com/sponkytoo/mbedTLS/blob/master/README.md Description : Shows how to use mbedTLS with Microchips Harmony Framework 2.04 on a PIC32MZ2048EFH144 Ethernet Starterkit with console interface on UART2 (routed to MCP2221 Chip) Regards |
只有小组成员才能发言,加入小组>>
5031 浏览 9 评论
1933 浏览 8 评论
1870 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3084 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2155 浏览 5 评论
594浏览 1评论
460浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
491浏览 0评论
390浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
871浏览 0评论
GMT+8, 2024-9-1 10:23 , Processed in 1.242988 second(s), Total 93, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
