我花了太多的时间去弄清楚当我添加了一个比我学习和谐的新特征时,和声发生了什么变化…我很想看到一个“棒棒糖”的特性,例如,如果我对我的USET感到满意,并且已经把一个应用程序演示片段转换成工作代码,当我删除演示选择时,它将单独离开USAT……有这么多的相互关系,至少-初学者。就像我自己会受益于知道它想改变的设置。
以上来自于百度翻译 以下为原文 I have spent as much time figuring out what HARMony changed when I add a new feature than I have learning Harmony... I would love to see a "stick a pin in it" feature so that, for instance, if I am happy with my USARTS, and have converted an app demo snippet into working code, when I delete the demo selection it would LEAVE the USART alone, etc... There are just so many interrelations that - at least - a beginner like myself would benefir from knowing what settings it thinks it wants to change. |
2个回答
这正是我投入时间学习创建自己的板支持包的原因。如果你的配置因为测试而被粘起来了,没问题。只要重新启动和MHC,不要打开MHC文件时,提示,并简单地选择您的自定义BSP。它会立即填充到你设计中已知的工作状态。
以上来自于百度翻译 以下为原文 This is precisely why I invested time learning to create my own board support packages. If your configuration gets gummed up because of testing, no problem. Just restart and MHC, don't open an mhc file when prompted, and simply select your custom bsp. It will instantly populate everything to a known working state of your design. |
嗯,我为我的板创建了一个项目演示的配置,但是我没有使用BSP。和声不断改变它使用错误的调试器,使用FRC 8MHz代替我的24MHz XTAL…USB不太喜欢。我正在加载我的文件。它也是最坚持的,我需要配置我的处理器中不存在的端口,使我重新删除它们,并试图插入取消选择EF启动器工具包BSP…
以上来自于百度翻译 以下为原文 well, I created a configuration of a project demo for my board, but I did not use a BSP. Harmony keeps changing it to use the wrong debugger and to use FRC 8MHz instead of my 24MHz XTAL... USB does not like that much. I am loading my file. It's also most insistent that I need to config ports that don't exist in my processor, making me re-delete them, and trying to insert the deselected EF starter kit BSP... |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1749 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2958 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2061 浏览 5 评论
463浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
365浏览 0评论
265浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-27 15:33 , Processed in 1.041035 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
