电子发烧友论坛|
我有一点时间将线性拟合应用于一小块数据(目标是提取vt,ala Baker 3rd Ed。p 293中显示的方法)。
我有一个gm vs Vgs的图,我尝试过类似于fit_line演示中显示的变换,但它似乎确实理解限制了特定范围值的拟合。 这是我的转换中的代码,试图从vgs值2.3到4.3 V的线性拟合gm数据:gm = DERIVAtiVE2(vg.m,id.m,1,-1)OVERRIDE_LIMITS =“Y”X_LOW = 2.3 X_HIGH = 4.3 fit = fit_line(vg.m,gm,1,-1)RETURN fit我也尝试在Setup Variables选项卡中定义X_LOW和X_HIGH,也没有运气。 我也尝试过linfit功能。 有什么建议么? 谢谢,Paul *编辑修复错别字*编辑:Paul Shepherd于2014年4月9日上午7:42 以上来自于谷歌翻译 以下为原文 I am having a heck of a time applying a linear fit to a small region of data (the goal is to extract vt, ala the method shown in Baker 3rd Ed. p 293). I have a plot of gm vs Vgs, and I have tried making transforms similar to the ones shown in the fit_line demo, but it just does seem to understand limiting the fit to a specific range of values. Here is my code in my transform to try to get a linear fit to the gm data from vgs values of 2.3 to 4.3 V: gm = DERIVATIVE2(vg.m, id.m, 1, -1) OVERRIDE_LIMITS = "Y" X_LOW=2.3 X_HIGH=4.3 fit = fit_line(vg.m , gm, 1, -1) RETURN fit I have tried defining X_LOW and X_HIGH in the Setup Variables tab as well, also with no luck. I have also tried the linfit function. Any suggestions? Thanks, Paul *edited to fix typos* Edited by: Paul Shepherd on Apr 9, 2014 7:42 AM |
1个回答
您好,如果您仍在寻找计算阈值电压(vt)的变换,我有一个PEL变换,它使用linfit函数将其作为数据的Y截距返回。
我很乐意寄给你一份。 最诚挚的问候,迈克 以上来自于谷歌翻译 以下为原文 Hello, If you are still looking for a transform to compute the threshold voltage (vt), I have a PEL transform that uses the linfit function to return it as the Y-intercept of the data. I will be happy to send you a copy. Best Regards, Mike |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:44 , Processed in 0.483785 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4126
