只是想知道是否有人能确认他们成功地用PICtiT3编程了PIC24FJ1024GB606和610?有两个64引脚GB606芯片(关于原型适配器)的问题,并决定尝试一个MPLICM PIM(基于GB610)。同样的问题出现在所有三个设备上。我尝试过MPLABX V3.26,它只显示“beta支持”,以及最新的V4.01(上周下载),它显示了完全支持。我所面临的问题是,所有三个设备(MPLABX的两个版本)都无法编程。TES并读取设备类型、硅修订版和“DEVSN0/1”,然后编程时用“红色”“编程设备失败”来回答。唯一的进一步信息是在Build选项卡上,上面写着“程序员不能启动:对目标设备编程失败”。N可以使用,但由于闪存的大小,我倾向于使用“手动选择内存区域”选项。任何建议或任何人都可以确认他们已经用一个拾取器3编程了上面的内容。我试过两个不同的P3S…Yorky
以上来自于百度翻译 以下为原文 Just wondering if somebody can confirm that they are successfully programming the PIC24FJ1024GB606 and 610 with a PICkit3? Have had issues with two 64pin GB606 chips (on prototyping adaptors) and decided to try a MChip PIM (based on the GB610). The same problem appears on all three devices. I have tried MPLabX V3.26, which only shows 'beta support', and the latest V4.01 (downloaded last week) which shows full support. The problem I am having is that all three devices, with both versions of MPLabX, is failing to program. The PICkit3 communicates and reads the device type, the silicon revision and the 'DEVSN0/1' Then when programming replies with a (RED) 'Failed to program device'. The only bit of further info is on the Build tab which says 'The programmer could not be started: Failed to program the target device'. The Read Device Memory can be used, but because of the size of the Flash I have tended to use the 'Manually select memory regions' option. Any advice or can anybody confirm they have programmed the above with a PICkit 3. I have tried two different P3s.. T Yorky |
8个回答
我也有同样的问题!未能编程设备。PIC24FJ1024GB610不再响应。试图激活双闪存页面模式。现在没有来回。有人知道,如何重新激活砖?悲伤:
以上来自于百度翻译 以下为原文 I have the same problem! 'Failed to program device'. The PIC24FJ1024GB610 doesn't respond anymore. Tried to activate the dual flash page mode. Now there is no back and forth. Does anyone know, how to reanimate the brick? sad: |
曼博特,谢谢你的回答,让我放心,不只是我。我已经成功地恢复了我拥有的所有三个设备,现在可以把它们回收。这对MPLabX来说似乎是个问题。你使用的是什么版本的MPLABX?我将尝试详细说明他们是如何恢复在一个单独的职位。T Yorky。
以上来自于百度翻译 以下为原文 manbert, Thanks for the answer, reassuring to know its not just me. I have managed to recover all three of the devices I have and can now prog them. It appears to be a problem with MPLabX. What version of MPLabX are you using? I will try and detail how they were recovered in a separate post. T Yorky. |
你好!对不起,我的第一个帖子-它甚至没有回答你的问题。但我只是被Buffic CPU惹恼了,你的问题听起来类似……我用MPLAB-X V4.01(Linux)和MPLAB-X V3.55(WIN7)使用ICD3。我真的很想知道,你是如何恢复的……谢谢!
以上来自于百度翻译 以下为原文 Hi! Sorry for my first post - it didn't even answer your question. But I was just pissed by the bricked CPUs and your problem sounded similar... Im using the ICD3 with MPLAB-X v4.01 (Linux) and MPLAB-X v3.55 (Win7). I'd really like to hear, how you recovered them... Thanx! |
你的Wi7V3.55显示出完全支持你的PIC24FJ芯片吗?也就是说,在项目属性中,程序员是用绿点或黄点(红点表示不支持)显示的吗?你也试过擦除芯片而不编程吗?这个选项正常地从菜单中删除。右键单击菜单栏的空部分。选择自定义。你会发现在“Project”下面有一个“擦除设备内存”。将此拖动到菜单栏上。当你使用这个程序时,MPLabX如何响应,而不试图闪动一个程序?T Yorky
以上来自于百度翻译 以下为原文 Does your win7 V3.55 show full support for you PIC24FJ chip? That is, in projects properties, is you programmer shown with a Green dot or a Yellow dot (Red dot means not supported)? Also have you tried erasing the chip without programming it? This option is normally missing off the menu. Do a right click on an empty part of the menu bar. Select customize. And you will find under 'project' there is a 'Erase Device Memory'. Drag this onto your menu bar. How does MPLabX respond when you use this, without trying to flash a program? T Yorky |
我能够用PICTIT3和IPE 3.26编程。它运行良好,但非常慢,超过10分钟,以完全编程的芯片,但没有错误和编程是正确的。从那时起我就没试过。
以上来自于百度翻译 以下为原文 I was able to program these with PICkit3 and IPE 3.26. It worked fine, but was insanely slow - over 10 minutes to fully program the chip, but there was no errors and programming was correct. I haven't tried since. |
是的,绿色的点是ICD3和PICTIT3。我试着用IPE擦除。我还要用IDE试试…
以上来自于百度翻译 以下为原文 Yes, green dots for ICD3 and PicKit3. And I tried erasing only, with the IPE. I'll have to try it with IDE also... |
我似乎也有同样的问题,当我第一次获得我的24FJ1024GB606的时候,他们编程没有问题,但是使用MPLABX中的配置工具来设置我所有的配置位,有很多错误需要修复。数据表中也有一些代码无法编译,所以我决定更新编译器。(我使用的是V1.25 Windows 7编译器),我把编译器更新到1.32(WIN7),所有的问题立即消失了。认为更新的编译器已经解决了这么多问题,我也不妨更新IDE,我确实这么做了。(到4先,然后到4.01)IDE似乎都很好,用了几天,然后开始出现编程问题,在那里它不会识别处理器,或者,它会识别它,但不能编程。2种不同的皮卡-3以相同的方式运行,但直到我试图对24FV16KM204进行编程,它才显示出完全相同的问题,我怀疑IDE。(事实上,我意识到我并没有试着用新的IDE烧一个程序)切换到3.40 IDE,从那以后就没有什么问题了。所以,问题似乎是IDE,而不是PICTIT3。
以上来自于百度翻译 以下为原文 I seem to have had the same problem, when I first obtained my 24FJ1024GB606's, they programmed with NO issues, but using the config tool in MPLABX to set all my config bits, there were a lot of errors that needed to be fixed. There was also some code straight out of the datasheet, that wouldn't compile, so, I decided to update the compiler. (I was using V1.25 Windows 7 compiler) I updated the compiler to 1.32B (Win7), and all my issues went away immediately. Thinking the updated compiler had fixed so many issues, I might as well update the IDE as well, I did. (to 4.00 first, then to 4.01) All seemed to be fine with the IDE, used it a few days, then started having problems with programming, where it would not recognize the processor, or, would recognize it OK, but would fail to program. 2 different PICKit-3's acted in the same manner, but, it wasn't until I tried to program a 24FV16KM204, & it exhibited the exact same issues, that I suspected the IDE. (After the fact, I realized that I hadn't tried burning a program with the new IDE) Switched back to 3.40 IDE, havn't had the slightest issue since. So, problem seems to be with the IDE, not the PICKit3. |
只有小组成员才能发言,加入小组>>
5160 浏览 9 评论
1998 浏览 8 评论
1927 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3170 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2225 浏览 5 评论
727浏览 1评论
612浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
501浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
626浏览 0评论
524浏览 0评论
GMT+8, 2024-11-22 07:35 , Processed in 1.521425 second(s), Total 95, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
