您好,我们正在使用带有多功能模块34907A的Agilent 34972A,我们希望通过DAC输出通道控制电源。
问题是,输出通道的电压偏移约为10 mV。 因此,即使我们设置0 V的输出电压,我也可以用万用表测量10 mV的输出电压。 这是因为我们希望产生一个非常缓慢上升的电压斜坡,电源只接受0 ... 5 V的电压。我甚至不确定这个偏移是否恒定,因为在启动安捷伦之后 34972A我测得的偏差接近20 mV。 那么这是一个准确性的问题,还是可以在某处补偿这种偏移? 我已经尝试过恢复出厂设置,但是在输出通道04和05上仍然存在偏移。感谢您的问候。 以上来自于谷歌翻译 以下为原文 Hello, we are using an Agilent 34972A with the Multifunction Module 34907A and we want to control a Power Supply with the DAC output channel. The problem is, that the output channel has a voltage offset of about 10 mV. So even if we set an output voltage of 0 V, I can measure an output voltage of 10 mV with a multimeter. That is way to much because we want to generate a voltage ramp which rises very slowly and the Power Supply only accepts voltages from 0...5 V. I'm not even sure that this offset is constant, because right after starting the Agilent 34972A I measure an offset of almost 20 mV. So is this a question of accuracy or can I compensate this offset somewhere? I already tried a factory reset, but the offset still exists on both output channels 04 and 05. Thanks an best regards. |
2个回答
我担心你不能用34907A做得更好。
数据手册中的DAC精度规格为+/-(0.25%输出+ 20 mV)。 它不是为高精度而设计的。 您可以尝试34970A / 72A服务指南中的校准调整程序,而不是使用10.0V设置,使用1.0或3.0V,看看是否能获得更好的结果。 它是一个非常简单的线性DAC,只能在其输出范围内的1点进行校准。 以上来自于谷歌翻译 以下为原文 I'm afraid that you can't do any better with the 34907A. The DAC accuracy spec in the data sheet is +/-(0.25% output + 20 mV). It's not designed for high accuracy. You could try the calibration adjustment procedure in the 34970A/72A Service Guide and instead of using the 10.0V setting, use 1.0 or 3.0V and see if that gets you better results. It's a very simple linear DAC that can only be calibrated at 1 point in its output range. |
嗨Tomc,谢谢你的快速回答。
我想我们应该在购买之前告知我们更好的准确性。^ ^但我会尝试校准调整程序。 也许这有帮助。 最好的祝福 以上来自于谷歌翻译 以下为原文 Hi Tomc, thanks for the quick answer. I guess we should have informed us better about the accuracy before we bought ist ^^ But I will try the calibration adjustment procedure. Maybe that helps. best regards |
只有小组成员才能发言,加入小组>>
1271 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2943 浏览 3 评论
1083浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
744浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
903浏览 0评论
1271浏览 0评论
GMT+8, 2024-12-18 20:37 , Processed in 1.581473 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
