电子发烧友论坛|
我想用PIC16F18313编写一个简单的I2C写程序,我参考了MCHP的指南,如何使用MCC来创建程序,并嵌入了EEPROMY12C应用程序代码,但是编译错误使我感到困惑,任何人都可以给我一些建议,我附上了源程序。没有实际的错误提示消息,但是最后编译失败了。
以上来自于百度翻译 以下为原文 I'm tring to creat a simple I2C write program with PIC16F18313, I have reference to MCHP' guider, how to use MCC to create the program, and embeded the eeprom_12C application code, but the compile error puzzled me, anyone can give me some advice, i have attach the source project. as following picture, there are no actual error hint message, but at last, compile is failed.sad: Attached Image(s) Attachment(s) PIC16F18313.zip (124.62 KB) - downloaded 33 times |
3个回答
您的zip文件将不会打开7zip。高亮的行只是说,输出十六进制文件生成失败。你必须看看上面的错误-未定义的符号“II2CYByTrWrand”,这可能意味着你应该使用I2C1YByToWrad。
以上来自于百度翻译 以下为原文 Your zip file won't open with 7-zip. The highlighted line just says that the output hex file generation failed. You have to look at the error above - undefined symbol "_I2C_ByteWrite" which probably means you should have used I2C1_ByteWrite instead. |
您好,谢谢您提醒我,我已经把I2C1BYTETHORD替换为i2CyByToWrad,但是错误仍然存在。我的项目大于500 K,大约670K,我不知道如何将它附加在这个帖子中,也许,你可以给我一封电子邮件,我会把这个项目发送给你的!多谢!
以上来自于百度翻译 以下为原文 hi caffeine thanks for you remind, i have replace I2C1_ByteWrite to I2C_ByteWrite, but the error is still exists my project is larger than 500k, about 670k, I don't know how to attach it in this post, maybe ,you can give a email add to me, I'll sent the project to you! many thanks! |
在EEPROMIFI2C C 52行上的警告称“I2C1YByTeWrad从来没有被调用”,而错误说“未定义的符号:II2CYByTrWrad”,如果您已经修复了,然后查找下一个错误。
以上来自于百度翻译 以下为原文 Well, the warning on eeprom_i2c.c line 52 says "_I2C1_ByteWrite is never called" while the error says "undefined symbol: _I2C_ByteWrite" If you've fixed that then look for the next error. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 00:37 , Processed in 0.964901 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2078
