您好,我在哪里可以获得有关签证命令(labview)SCPI(如WAV; SOUR; PRE?)的手册,与DSO 7012B一样,有任何有用的文档可以理解这个命令。
谢谢 :) 以上来自于谷歌翻译 以下为原文 Hello, Where do i get a manual with the visa commands(labview) SCPI(such WAV;SOUR;PRE?) as for DSO 7012B ,there are any helpful document to understand this command . thank you :) |
1个回答
你可以做我完成的事情。
访问www.agilent.com,在右上方的搜索框中输入“DSO7012B”。 在出现的页面上选择“技术支持”,您可以访问:http://www.home.agilent.com/agilent/techSupport.jspx?pid = 1787286& pageMode = OV& cc = US& pl = 选择“手册”,“程序员指南”应在列表中。 您还可以尝试Command Expert,它将指导您完成正确获取命令和语法的过程,并导出应该执行您想要的操作的代码。 有关信息,请访问:http://www.home.agilent.com/en/pd-2036130-pn-E2300/command-expert-11?nid=-33002.992473&cc=US&lc=eng Al免责声明: 要获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 You could do exactly what I did. Go to www.agilent.com, and type "DSO7012B" in the search box in the upper right. Choose "Technical Support" on the page that comes up, and you should get here: http://www.home.agilent.com/agilent/techSupport.jspx?pid=1787286&pageMode=OV&cc=US&lc=eng Choose "Manuals", and the "Programmers Guide" should be in the list. You could also try Command Expert, which will guide you through the process of getting the commands and syntax right, and export code that should do what you want. Information on that is here: http://www.home.agilent.com/en/pd-2036130-pn-E2300/command-expert-11?nid=-33002.992473&cc=US&lc=eng Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1300 浏览 0 评论
2379 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1152浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
762浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
960浏览 0评论
1301浏览 0评论
GMT+8, 2024-12-31 03:27 , Processed in 1.311506 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
