电子发烧友论坛|
有人要我调谐一个需要调谐460MHz频率的陷波双工器。
我不知道这个的设计,因为我还没有,但它很可能是某种类型的耦合谐振器滤波器。 我想知道Joel是否为他的博士学位所做的TDR工作。 如果我没有过滤器的数学模型,可以使用。 我注意到安捷伦曾经为此出售过一些软件,但我觉得需要一个过滤器模型才能开始使用,如果你从头开始设计它就没问题,但如果你有一个未知的设计则没那么有用 。 显然,一个3(或更多)端口VNA是这个的理想工具,但我只有一个2端口8720D,但它确实有TDR选项。 我想知道是否可以用它来帮助做到这一点。 戴夫 以上来自于谷歌翻译 以下为原文 Someone has asked me to tune a notch duplexer that needs tuning for frequencies around 460MHz. I don't know the design of this, as I don't have it yet, but it is likely to be a coupled resonator filter of some sort. I wonder if the TDR thing that Joel worked on for his Ph.D. can be used, if I do not have a mathematical model of the filter. I noted that Agilent used to sell some software for this, but I got the feeling that one needed a model of the filter to start with, which is fine if you have designed it from scratch, but not so useful if you have an unknown design. Clearly a 3 (or more) port VNA is the ideal tool for this, but I only have a 2-port 8720D, but it does have the TDR option. I am wondering if that can be used to help do this. Dave |
2个回答
当然,如果您只是调谐谐振器(固定耦合),则不需要模型。
应用笔记1287-8显示了详细信息。 以上来自于谷歌翻译 以下为原文 Sure, not model is needed if you are just tuning resonators (fixed coupling). app note 1287-8 shows the details. |
> {quote:title = Dr_joel写道:} {quote}>当然,如果你只是调整谐振器(固定耦合),则不需要模型。 应用笔记1287-8显示了详细信息。 谢谢Joel,我在http://cp.literature.agilent.com/litweb/pdf/5968-5328E.pdf上找到了应用笔记1287-8并将会看一下。 它比您的博士学位更容易阅读。 论文。 数学不是我最强的话题 - 因此我倾向于引导我的博士学位。 远离太多数学的东西。 戴夫 以上来自于谷歌翻译 以下为原文 > {quote:title=Dr_joel wrote:}{quote} > Sure, not model is needed if you are just tuning resonators (fixed coupling). app note 1287-8 shows the details. Thank you Joel, I found application note 1287-8 at http://cp.literature.agilent.com/litweb/pdf/5968-5328E.pdf and will take a look. It is a bit easier to read than your Ph.D. thesis. Maths is not my strongest topic - hence I tended to steer my Ph.D. away from too much mathematical stuff. Dave |
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1854浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-8 16:18 , Processed in 2.453374 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3097
