你好!与MplabX的版本发布和调试有什么不同吗?当我点击“清理和构建调试主项目”或“调试主项目”时,我的注册表就建立了,但是如果我点击“清理和构建主项目”或“运行主项目”,它就会失败。错误是:使[2 ]:**[构建/默认/生产/ 1360937237 / 1360937237 / main。p1]错误1]使:**[构建-错误2:使:***[构建IMPL]错误2(908)退出状态=1nbPosi/MaFaMeCurrase.MK:530:目标“构建/默认/生产/Ext/ 1360937237 /main”的配方。P1’FultEdvest[2 ]:离开目录'c:/Pyjkt/IpStudio/HuD/HUD.x'nbPosi/MaFaMeCurrase.MK:90:目标''.'FultEdf[[ 1 ] ]:离开目录'c:/Pyjkt/IpStudio/HuD/Hud .x'nbPosi/MaFix.IMP.MK:39:目标''.Buff-IMPL 'FrueBuffBug失败(退出值2,总时间:11s)的配方.我不知道从哪里开始查找.我不使用我的代码中的μ调试宏,所以这不应该是问题。项目是一个转换的C18到XC8编译器项目。我正在使用:XC8 V.1.34 MPLABX 4.01ICD4程序员。PIC18F26K20。
以上来自于百度翻译 以下为原文 Hi there! Is there any differences in building release and debug with MplabX? When I'm clicking on "clean and build for debugging main project" or "debug main project" then my prject builds but if I click "clean and build main project" or "Run main project" then it fails. The error is: make[2]: *** [build/default/production/_ext/1360937237/main.p1] Error 1 make[1]: *** [.build-conf] Error 2 make: *** [.build-impl] Error 2 (908) exit status = 1 nbproject/Makefile-default.mk:530: recipe for target 'build/default/production/_ext/1360937237/main.p1' failed make[2]: Leaving directory 'C:/Projekt/Interspiro/hud/Hud.X' nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed make[1]: Leaving directory 'C:/Projekt/Interspiro/hud/Hud.X' nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed BUILD FAILED (exit value 2, total time: 11s) I have no clue where to start looking. I do not use the __DEBUG macro in my code, so that should not be the problem. The project is a converted c18 to xc8 compiler project. I'm using: xc8 v.1.34 MplabX 4.01 ICD4 programmer. PIC18F26K20 |
3个回答
你能发布完整的构建日志吗?在你发布的部分之前应该有一些信息。
以上来自于百度翻译 以下为原文 Could you post the complete build log? There should be some message BEFORE the part you posted. |
简单的答案是“是”,因为调试和发布版本之间存在许多差异,但是它们应该在代码方面是透明的。因此,您确实需要向我们展示更多的项目,并在我们帮助您之前,告诉我们您正在做的更多的细节。还包括您正在使用的配置语句。苏珊
以上来自于百度翻译 以下为原文 The simple answer is 'yes' as there are a number of differences between a debug and a release build but they should mostly be transparent as far as your code is concerned. Therefore you really need to show us a lot more of your project and give us more details of what you are doing before we can help you. Also include the config statements you are using. Susan |
我不再在电脑上了,我明天将上传完整的输出(如果我可以,论坛没有让我早,帖子长了)我应该打开冗长的来得到所有可能的细节吗?除了配置字节和输出之外,还有什么可以使用的吗?
以上来自于百度翻译 以下为原文 I'm not at the computer anymore, I will upload the full output tomorrow (if I can, the forum didn't let me earlier, the post got to long) Should I turn on verbose as well to get all the possible details? Is there anything else than configuration bytes and output that could be of use? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
485 浏览 0 评论
5806 浏览 9 评论
2346 浏览 8 评论
2234 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3540 浏览 3 评论
1145浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1114浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
882浏览 1评论
487浏览 0评论
/9
GMT+8, 2025-12-9 02:27 , Processed in 0.556253 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1786
