大家好,我发现,当试图在PIC32 MZ1024EFG100上执行闪存操作(擦除、写入等)时,只有和声调用工作(Drva Flash WordWrrWord等)。试图通过手动写入NVMCON寄存器等,使其永久性地等待WR位清除,或错误位设置。我使用一个由论坛用户提供的非协调闪存写的例子,该用户已知在PIC32 MZ2048 EFG100上工作。筹码之间有什么区别吗?我有部分的勘误表?日期代码是1545 5dq。谢谢。
以上来自于百度翻译 以下为原文 Hi folks, I have found that, when trying to perform flash operations (erase, write etc.) on a PIC32MZ1024EFG100, only the HARMony calls work (DRV_FLASH_WriteWord et al). Trying to do it manually by writing to NVMCON registers etc. leaves it either permanently stuck waiting for the WR bit to clear, or with the error bit set. I am using an example of non-harmony flash writing provided by a forum user that is known to work on a PIC32MZ2048EFG100. Is there some difference between the chips? Errata on the part I have? Date code is 15455DQ. Thanks. |
2个回答
只是一个快速跟进,这肯定是芯片依赖性-我买了一个DEV板与PIC32 MZ2048 EFG144上,它不遭受同样的问题。大概有一些未提及的错误在PIC32 MZ1024EFG100,和谐是默默地工作。
以上来自于百度翻译 以下为原文 Just a quick follow-up to this, it's definitely chip dependent - I bought a dev board with a PIC32MZ2048EFG144 on it and it doesn't suffer from the same problem. Presumably there's some unmentioned errata in the PIC32MZ1024EFG100 that Harmony is silently working around. |
你有没有尝试过看由和声产生的源代码?
以上来自于百度翻译 以下为原文 Have you tried just looking at the source code generated by Harmony? |
只有小组成员才能发言,加入小组>>
4983 浏览 9 评论
1899 浏览 8 评论
1834 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3049 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2127 浏览 5 评论
560浏览 1评论
408浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
460浏览 0评论
352浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
837浏览 0评论
GMT+8, 2024-8-8 20:14 , Processed in 1.090934 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
