扫一扫,分享给好友
我正在通过u***使用Intuilink Data Capture从MSO7054a获取数据。
无论我如何更改设置,实际上只能保存1000个点。 我怎样才能节省更多积分? 谢谢! 以上来自于谷歌翻译 以下为原文 I'm using Intuilink Data Capture via u*** to get data from MSO7054a. No matter how i change the setting, only 1000 points can be saved actually. How can i save more points? Thanks! |
3个回答
什么版本的Scope SW?
什么版本的Intuilink? 最新版本的Intuilink,V4.30,应该转移到示波器的全深度(8M)。 你可以在这里找到它:http://www.home.agilent.com/agilent/software.jspx?cc = US& cs = eng& ckey = 896758& nid = -32976.0.00& id = 889758 Al免责声明:对于 更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 What version of Scope SW? What version of Intuilink? The latest version of Intuilink, V4.30, should transfer up to the full depth (8M) of the scope. You can get it here: http://www.home.agilent.com/agilent/software.jspx?cc=US&lc=eng&ckey=896758&nid=-32976.0.00&id=896758 Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
nvywyerwer 发表于 2018-11-29 09:28 谢谢您的回复。 范围的系统版本是05.15.0001,而且intuilink数据捕获是最新的。 我还尝试使用USB闪存驱动器来获取数据,但范围上的软键“长度”限制为1000.我试图按“停止”,“单个”或保存为不同的格式,但它没有 工作。 以上来自于谷歌翻译 以下为原文 Thank you for your reply. The system version of scope is 05.15.0001, and the intuilink data capture is up to date. I also tried to use a u*** flash drive to get data, but the softkey "Length" on the scope is limited to 1000. I tried to press "stop", "single" or save to a different format, but it didn't work. |
更新:问题已经解决。
我不确定我最后采取了哪一步。 也许范围上的软键“长度”有助于解决这个问题。 以上来自于谷歌翻译 以下为原文 Update: The problem has been solved. I'm not sure which step i took finally worked. Maybe the softkey "length" on the scope helped solving this problem. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 08:19 , Processed in 0.604226 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1231
