电子发烧友论坛|
使用插入34980中的34921A模块的34921T接线端子进行热电偶读数的接线要求是什么?
我在插槽6,7,8和9中有热电偶线。我是否遗漏了用户指南中未列出的内容,或者我是否忽略了用户指南中的内容? 谢谢 以上来自于谷歌翻译 以下为原文 What wiring requirements are there to make thermocouple readings using the 34921T terminal block plugged into a 34921A module in a 34980? I have thermocouple wires in slots 6, 7, 8, and 9. Am I missing something outside of that that is not listed in the user's guide, or am I overlooking something in the user's guide? Thanks |
1个回答
34921T没有“附加”热电偶接线要求。
只需确保+引线连接到Hi通道端子,并且 - 引线连接到Lo端子。 如果没有详细描述问题症状,我不确定你的问题是什么。 连接错误极性的TC导线肯定会超出读数范围,因为34980A会在通道上看到负电压。 另一件事,你需要知道的是确保你有正确的参考连接类型集。 您最有可能想要使用34921T上的内部参考接点。 默认类型是“FIXed”,如果您想要更高的准确度并且具有良好的冰浴或其他固定温度参考,那么您将使用该类型。 您需要发送的命令是[SENSe:] TEMPerature:TRANsducer:TCouple:RJUNction:TYPE [,(@)],其中source参数为“INTernal”。 以上来自于谷歌翻译 以下为原文 There are no "additional" thermocouple wiring requirement for the 34921T. Just make sure that the + lead is connected to the Hi channel terminal and the - lead is connected to the Lo terminal. I'm not sure what your problem might be without getting a full description of the of the problem symptoms. Connecting the TC wire with the wrong polarity will definitely give you out-of-range readings because the 34980A will be seeing a negative voltage on the channel. The other thing, you need to know is to be sure you have the correct reference junction type set. You most likely want to use the internal reference junction on the 34921T. The default type is "FIXed" which would be what you would use if you wanted higher accuracy and had a good ice bath or other fixed temperature reference. The command you need to sent is [SENSe:]TEMPerature:TRANsducer:TCouple:RJUNction:TYPE [, (@)], where the source parameter is "INTernal". |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 15:01 , Processed in 0.785745 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1352
