电子发烧友论坛|
是否可以使用参考波形执行MATH功能?
我想看一下两个波形之间的区别,但是不可能同时查看两个波形,所以计划是捕获第一个并存储为参考,然后在第二个和第二个之间运行MATH函数 波形,但我不能让这个工作。 欢迎任何想法或建议。 以上来自于谷歌翻译 以下为原文 Is it possible to perform a MATH function using a reference waveform? I am wanting to look at the difference between two waveforms but it isn't possible to view both live at the same time so the plan was to capture the first and store as a reference and then run a MATH function between that and the second live waveform but I can't get this to work. Any ideas or suggestions welcomed. |
1个回答
从手册中,“数学运算符在模拟输入通道上执行算术运算(如加,减或乘)。”
数学在采集硬件中完成,因此无法访问任何参考波形。 其他更强大的安捷伦示波器,例如Infiniium系列,可以在“实时”和存储波形上执行更多操作。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 From the manual, "Math operators perform arithmetic operations (like add, subtract, or multiply) on analog input channels." The math is done in the acquisition HW, and, as such, doesn't have access to any reference waveforms. Other, more capable, Agilent scopes, such as the Infiniium families, can do many more operations on both 'live' and stored waveforms. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:20 , Processed in 0.602448 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
365
