扫一扫,分享给好友
我正在研究ADS,我从B1505 Agilent获得了GaAs HEMT的Id-Vd曲线测量。
我将结果导出为.CSV文件,我想在我的模拟中使用非线性模块(如SDD2P或SDD3P组件和数据访问组件(DAC))重现它。 不知怎的,我不能这样做。 在模拟之后,我能够仅为Vgs的一个值绘制特征曲线。 有没有办法可以以表的格式(如CSV格式)获取测量值并将其绘制为ADS? 你有任何示例文件显示如何完成它吗? 如果可能的话你可以寄给我吗? 谢谢, 以上来自于谷歌翻译 以下为原文 I am working on ADS, I took Id- Vd curve measurement for a GaAs HEMT from B1505 Agilent. I exported the results as .CSV file and I want to reproduce it in my simulation using non-linear blocks like SDD2P or SDD3P components and Data Access Components (DAC) . Somehow I cant get to do that. After simulation, I am able to plot the characteristic curve for one value of Vgs only. Is there a way that I can get the measured values in the format of a table(like a CSV format) and plot it ADS? Do you have any example file which shows how to get that done? If possible then can you send me? Thanks, |
1个回答
您好,如果您可以将csv文件转换为mdif格式,那么您可以通过原理图>数据文件实用程序>数据文件工具将该数据文件读入ADS数据集。
DAC可能很棘手,但是* .ds中的数据应该会有所帮助。 您可以发送电子邮件至eesof_support@agilent.com与该技术支持工程师合作。 此外,如果你谷歌'csv转mdif转换ADS'你会发现一些人已经完成了你所描述的事情,例如 从仪器开始.csv,将其转换为mdif,然后将数据读入ADS并链接到DAC。 希望有所帮助! 最好的问候Else 以上来自于谷歌翻译 以下为原文 Hello, It would be good, if you could convert the csv file into mdif format, so that then you can read that data file into an ADS dataset via the Schematic > Data File Utilities > Data File Tool. DAC can be tricky but having the data in *.ds should help. You could send an email to eesof_support@agilent.com to work with a Tech Support engineer on that. Also, if you google 'csv to mdif converter ADS' you will find some posts of people who have done the type of thing you are describing, e.g. starting with .csv from an instrument, converting it to mdif and then reading data into ADS and linking to DAC. Hope that helps! Best regards Else |
只有小组成员才能发言,加入小组>>
1298 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1140浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
760浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
950浏览 0评论
1298浏览 0评论
GMT+8, 2024-12-29 03:14 , Processed in 3.132631 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
