电子发烧友论坛|
你好,我正在使用DS30loader在我的PIC18F45 K80上启动引导程序,我需要在更新之前重新设置我的PIC。我需要确保在复位期间保持高电平的输出:PIN为我的主机供电,它将发送更新。有没有办法在复位期间锁定输出?谢谢你,莱欧
以上来自于百度翻译 以下为原文 Hi there, I'm using the ds30loader CAN bootloader on my PIC18F45K80 and I need to reset my PIC before an update. I need to be sure to keep an output at high level during reset: that pin powers up my host computer that will send the update. Is there a way to lock outputs during reset? Thanks, Léo |
4个回答
HI,不可能通过SW控制在复位期间引脚的状态。他们中的大多数被迫输入模式(模拟或数字),因此是浮动的。每个引脚在复位时的状态可以在每一位上面的寄存器描述中看到。我建议您在其上放置一个上拉电阻。
以上来自于百度翻译 以下为原文 Hi, It is impossible to control by SW the status of pins during RESET. Most of them are forced to input mode (analog or digital) and hence are floating. The status of each pin at reset can be seen in the registers description just above each bit. I would suggest that you put a pull-up resistor on that pin Regards |
HiFaAIK所有的引脚默认为复位上的输入。
以上来自于百度翻译 以下为原文 HI AFAIK all the pins default to inputs on a reset. Given so, an external resistor could be used as a pull-up. HIH Best regards Jorge |
谢谢RISC,JorgeF。这是不够的,在我的情况下,我想保持目前的潜力,而不是迫使产量高或低。
以上来自于百度翻译 以下为原文 Thanks RISC, JorgeF. That's not enough in my case, were I want to remain at the current potential and not force the output to be high or low. Léo |
你唯一可以确定的是复位将使引脚恢复为输入。因此,你必须使用一些外部硬件解决方案来保持外部电路状态。我会考虑一个R类的锁存电路或类似的东西。
以上来自于百度翻译 以下为原文 Hi The only thing you can be sure is that the RESET will revert the pins to inputs. So you have to use some external hardware solution to keep the external circuit state. I would consider a latching circuit of the R-S kind or something alike. Best regards Jorge |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 21:47 , Processed in 0.779970 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2133
