电子发烧友论坛|
嗨,首先是背景:-定制板与PIC32 MZ2064 DAG176-800 x480 WVGA显示与FT5316触摸面板连接。触摸面板连接到I2CYIDID1(RA14,RA15)。-INT连接到RD7(INT4)。我正尝试使用MTCH6301驱动端口FT5316作为参考,但现在我卡住了。这是行不通的。我认为一切都融入了和谐2.05,以产生所有的代码使用MHC。如果IN正在发生,它正在工作,但在I2C总线上什么都没有检查。附加的是驱动程序,如果您有自定义驱动程序,请小心,因为它覆盖SythOrthDealth.H和SysTouC.C.C.触摸板已经使用ARDUNO进行测试,并且工作完美。弗朗西斯科。
以上来自于百度翻译 以下为原文 Hi, first of all the background: - Custom board with PIC32MZ2064DAG176 - 800x480 WVGA display with FT5316 touch panel attached. - Touch panel connected to I2C_ID_1 (RA14, RA15). - INT connected to RD7 (INT4). I´m trying to port the FT5316 using the MTCH6301 driver as reference but now I´m stuck because it doesn´t work. I think everything is integrated into hARMony 2.05 to generate all code using MHC. Checked with scope if INT is happening and it´s working but nothing is on the I2C bus. Attached is the driver, beware if you have custom drivers because it overwrites system_definitions.h and sys_touch.c. The touch panel has been tested using an arduino and works perfect. Best regards. Francisco. Attached Image(s) Attachment(s) ft5316.zip (31.07 KB) - downloaded 120 times |
19个回答
在帮助客户支持显示安装FT5XX6系列的经验中,我们发现最好的方法是从MTCH6303(不是MTCH6301)的驱动程序开始,因为过程的要求非常相似:它需要首先对寄存器进行写操作,然后读取我。圣战在MTCH6301中只发送一条读取消息。另一件需要注意的是来自芯片的数据顺序。基本上,一旦您将数据指针更改为正确的数据,得到的结果应该非常容易。将FT53x6与MTCH6303:FT53X6MTCH6303See附件进行比较,两个附件从MTCH6303触控驱动程序开始,并修改一个例程,由一个定义为ftx支持的HACK启用。下面的示例是针对QVGA(3x230)支持的缩放,但是可以很容易地修改其他屏幕大小。Michael W. Mann主要应用工程师MCU32应用程序
以上来自于百度翻译 以下为原文 In our experience in helping customers support displays mounting FT5XX6 series we've found that the best way to get it working is to start from the driver of the MTCH6303 (not the MTCH6301) since the request of process is very similar: It requires first a write action to a register then the read message. In MTCH6301 only a read message is sent out. The other thing to be aware is the data order coming from the chip. Basically once you change the data pointers to the correct data to get the result should be very easy. Comparing the FT53x6 to the MTCH6303: FT53X6 MTCH6303 See Attachment One See Attachment Two Start out with the MTCH6303 touch driver and modify one routine with a hack enabled by a #define FT_SUPPORT. The example below is scaled for QVGA (320x230) support, but can be easily modified for other screen sizes. void _DRV_TOUCH_MTCH6303_BufferQueueTasks(DRV_TOUCH_MTCH6303_STATIC_OBJ * hDriver) { DRV_TOUCH_MTCH6303_BUFFER_OBJ * bufferObj = ( DRV_TOUCH_MTCH6303_BUFFER_OBJ * ) NULL; bufferObj = hDriver->queue; if( DRV_HANDLE_INVALID != hDriver->drvBusHandle && NULL != bufferObj ) { if( 0 == bufferObj->size ) { hDriver->queue = bufferObj->next; bufferObj->inUse = false; hDriver->queueSizeCurrent--; #ifdef FT_SUPPORT touch_x=(unsigned int)(hDriver->touchData.touch[0].X_M***)<<8; touch_y=(unsigned int)(hDriver->touchData.touch[0].Y_M***)<<8; touch_x=touch_x+(unsigned int)(hDriver->touchData.touch[0].X_L***); touch_y=touch_y+(unsigned int)(hDriver->touchData.touch[0].Y_L***); if( hDriver->touchData.status.nTouch != 0 && /*hDriver->touchData.touch[0].nibble_0.inRange != 0 &&*/ /*hDriver->touchData.touch[0].x*/ touch_x != 0 && /*hDriver->touchData.touch[0].y*/touch_y != 0 ) { // //Translate the touch data to X/Y coordinates hDriver->mostRecentTouchX =touch_x;// (int16_t)DRV_TOUCH_MTCH6303_TouchInputMap(/*hDriver->touchData.touch[0].x*/ touch_x<<4 , 240); hDriver->mostRecentTouchY =touch_y;// (int16_t)DRV_TOUCH_MTCH6303_TouchInputMap(/*hDriver->touchData.touch[0].y*/touch_y<<4, 320); //Translate the touch data to X/Y coordinates // hDriver->mostRecentTouchX =touch_y;// (int16_t)DRV_TOUCH_MTCH6303_TouchInputMap(/*hDriver->touchData.touch[0].x*/ touch_x<<4 , 240); // hDriver->mostRecentTouchY =240-touch_x;// (int16_t)DRV_TOUCH_MTCH6303_TouchInputMap(/*hDriver->touchData.touch[0].y*/touch_y<<4, 320); } else { hDriver->mostRecentTouchX = -1; hDriver->mostRecentTouchY = -1; } #else if( hDriver->touchData.status.nTouch != 0 && hDriver->touchData.touch[0].nibble_0.inRange != 0 && hDriver->touchData.touch[0].x != 0 && hDriver->touchData.touch[0].y != 0 ) { //Translate the touch data to X/Y coordinates hDriver->mostRecentTouchX = (int16_t)DRV_TOUCH_MTCH6303_TouchInputMap(hDriver->touchData.touch[0].x, 240); hDriver->mostRecentTouchY = (int16_t)DRV_TOUCH_MTCH6303_TouchInputMap(hDriver->touchData.touch[0].y, 320); } else { hDriver->mostRecentTouchX = -1; hDriver->mostRecentTouchY = -1; } #endif hDriver->touchStatus = DRV_TOUCH_POSITION_SINGLE; if( NULL != hDriver->queue ) { bufferObj = hDriver->queue; switch( bufferObj->flags ) { case DRV_TOUCH_MTCH6303_BUFFER_OBJ_FLAG_REG_READ: { bufferObj->hBusBuffer = DRV_I2C_BufferAddWriteRead( hDriver->drvBusHandle, (uint8_t *)&hDriver->deviceAddress, ( void *)&bufferObj->regAddress, 1, ( void * )bufferObj->readBuffer, bufferObj->size, (void *)NULL ); break; } case DRV_TOUCH_MTCH6303_BUFFER_OBJ_FLAG_REG_WRITE: { bufferObj->hBusBuffer = DRV_I2C_BufferAddWrite( hDriver->drvBusHandle, (uint8_t *)&hDriver->deviceAddress, (uint8_t *)bufferObj->writeBuffer, bufferObj->size, (void *) NULL); break; } } } } } return; } Michael W. Mann Principal Applications Engineer MCU32 Applications Attached Image(s) |
非常感谢你,米迦勒,把它交上去。最好的是弗朗西斯科。
以上来自于百度翻译 以下为原文 Thank you so much Michael, gettings hands on it. Best regards.Francisco. |
嗨,弗朗西斯科(吉高利)!你有没有让你的FT5316司机工作?我想开始类似的AFT5306。谢谢!帕特里克
以上来自于百度翻译 以下为原文 Hi Francisco (Jiggoly)! Did you ever get your FT5316 driver working? I will be wanting to start something similar for a FT5306. Thanks! Patrick |
嗨,帕特里克,我用一个黑客从微芯片Michael W. Mann发布在另一个线程工作。我正在为所有FT5XX6系列创建一个自定义驱动程序,将在这里发布(如果它工作的话)。
以上来自于百度翻译 以下为原文 Hi Patrick, I got it working using a hack that Michael W. Mann from microchip posted in another thread. I'm creating a custom driver for all FT5xx6 series that will be posted here (if it works). |
我已经想出了一个教程,包括如何使用一些适配器板向EF初学者工具包添加Mikroe显示。Mikroe显示器使用一个SSD1963图形控制器和一个焦点技术FT5X06电容式触摸控制器。附上两个文件:1)创建AgRAPHICsAppA3rdPARTYDISPLAY.ZIP教程文档2)3RDYPARTYL DISPLAY.ZIP项目,应该安装在./app /示例中。
3RDY PARTYAL DISPARYPARTS.ZIP(174.40 KB)-下载111次 以上来自于百度翻译 以下为原文 I've come up with a tutorial that covers how to add a Mikroe display to an EF starter kit using some adapter boards. The Mikroe display uses a SSD1963 graphics controller and a Focal Tech FT5x06 capacitive touch controller. Attached are two files: 1) CreatingAGraphicsAppWithA3rdPartyDisplay.zip - tutorial documentation 2) 3rd_party_display.zip - resulting project , should be installed in ./apps/examples. Attachment(s) CreatingAGraphicsA...yDisplay_parts.zip (56.43 KB) - downloaded 89 times 3rd_Party_Display_parts.zip (174.40 KB) - downloaded 111 times |
以前帖子中的附件不好。我会把文件分开提供。
以上来自于百度翻译 以下为原文 The attachments in the prior post are bad. I'll provide the files in a separate post. |
米迦勒,我在Windows 10 MealEndIt中提取教程文档zip遇到了一些问题。
以上来自于百度翻译 以下为原文 Michael, I seem to be having some problems extracting the tutorial documentation zip on my windows 10 machine Edit: and so you noted. |
文件:3RDYPARTIGHOLID.zIP:12FCA2DA-6AE1-4C8C-A6AA3B4B433/SDZJBDXF8F5A20PUZ6HMW2创建AgRAPHICS AppAd3aRD PARTIAL显示:http://www-TrimigFiel.COM/F958B2FA-3E55-9A4E-B3CFB3E8F15A/FZWN-DGP8GRO7GRIWITEMW2WI下面是使用TigBigBy的两个链接NKS将在6/1/2018工作。之后,我将提供如何获取这些文件的附加说明。
以上来自于百度翻译 以下为原文 Here are two links using TransferBigFiles: 3rd_party_display.zip: https://www.transferbigfiles.com/12fca2da-6ae1-4c8c-a8dc-e6aa3b49b433/SdzujdbxF8F5A20puZ6HMw2 CreatingAGraphicsAppWithA3rdPartyDisplay: https://www.transferbigfiles.com/f958b2fa-3df5-4e55-9a4e-b3cfb3e8f15a/fZwn-DGp8GRo7GREiWtEmw2 These links will work through 6/1/2018. After that I will provide additional instructions on how to get these files. |
谢谢米迦勒,BTW为什么司机需要一个BITBUG I2C?
以上来自于百度翻译 以下为原文 Thanks Michael, BTW why does the driver need a bitbanged I2C? |
另外一个警告。示例项目将建立和运行,但它可能不会运行在MHC的和谐2.05.01,因为它是建立在一个原型的和谐2.06。试图重新配置它可能不起作用。
以上来自于百度翻译 以下为原文 One additional warning. The example project will build and run, but it probably won't run under the MHC in Harmony 2.05.01, since it was built under a prototype for Harmony 2.06. Attempting to reconfigure it will probably not work. |
我们使用一个有点冲击的I2C驱动程序与EF初学者工具包的所有版本兼容。
以上来自于百度翻译 以下为原文 We use a bit-banged I2C driver to be compatible with all versions of the EF starter kit. |
嗯,使用米迦勒提供的代码,我创建了一个独立的FT5XX6驱动程序。附加的是将驱动程序添加到触摸节下的MHC树配置文件的文件。只需配置参数并准备就绪。解压缩文件夹并覆盖到/Orthy/V2Y05Y001>。
以上来自于百度翻译 以下为原文 Well, using the code Michael provided I created a standalone FT5XX6 driver. Attached are the files that adds the driver to the MHC tree config under touch section. Just config the parameters and ready to go. Unzip folders and overwrite to /harmony/v2_05_01 Best regards. Francisco. Attachment(s) DRV_FT5XX6.zip (47.41 KB) - downloaded 100 times |
嗨,我还没有深入了解代码,但是我缺少了DrvouTouChyft5x66TouCHYBuffryEnviaHand定义。所以它没有编译
以上来自于百度翻译 以下为原文 Hi, I haven't had an in depth look at the code but I am missing the DRV_TOUCH_FT5XX6_TOUCH_BUFFER_EVENT_HANDLER definition. So it does not compile |
也许米迦勒在《邮报》13中的评论是相关的。
以上来自于百度翻译 以下为原文 maybe Michael's comments in post 13 are relevant |
我指的是吉格利的代码,但也许我今天晚些时候再看一下。
以上来自于百度翻译 以下为原文 I meant jiggoly's code, but maybe I'll take a look at it later today wink: |
伟大的!咧嘴笑:我希望对你有用。用和声2.05和2.05.01检查。
以上来自于百度翻译 以下为原文 Great!! grin: I hope it works for you. Checked it with Harmony 2.05 and 2.05.01. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
485 浏览 0 评论
5806 浏览 9 评论
2346 浏览 8 评论
2234 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3540 浏览 3 评论
1145浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1114浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
883浏览 1评论
488浏览 0评论
/9
GMT+8, 2025-12-9 07:32 , Processed in 1.262059 second(s), Total 110, Slave 93 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3689
