嗨,
我正在尝试使用Cosmic st8 32k编译器进行ST Visual Develop。我安装了所有东西并构建了项目。一切正常。当我尝试使用Swim ST-link使用调试器连接到Discovery板时,收到以下错误: 启动调试会话... - >仿真器重置(u***:// u***)...... **连接错误(u***:// u***):gdi-error [40201]:无法访问配置数据库 - >无法连接目标。 我尝试卸载并重新安装包括驱动程序在内的所有内容。我尝试过其他目标设置。唯一有效的是模拟器。 当我连接Discovery板时,我的电脑将其视为外置HD。我得到弹出窗口,可以查看存储在主板上的链接。我使用的是Windows 7 64位。 我还应该补充一点,在上面的错误消息之后会出现一个Windows 7弹出窗口,说明gdb7已经停止工作并且板上发出红色LED指示灯。 任何帮助,将不胜感激。 问候, 渣子 #stm8-discovery#i-also-get-same-error-so-please 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to use the ST Visual Develop with the Cosmic st8 32k compiler. I install everything and build the project. That all works fine. When I try to connect to the Discovery board with the debugger using Swim ST-link, I receive the following error: Starting debug session... -> Emulator reset (u***://u***)... ** Connection error (u***://u***): gdi-error [40201]: can't access configuration database -> Failed to connect target. I have tried uninstalling and re-installing everything including the drivers. I've tried other target settings. The only one that works is the simulator. When I connect the Discovery board, my computer sees it as an external HD. I get the pop-up window and can look at the links stored on the board. I'm using Windows 7 64bit. I should also add that after the above error message a windows 7 pop-up appears saying that gdb7 has stopped working and a red LED glows on the board. Any help would be appreciated. Regards, Marc #stm8-discovery #i-also-get-same-error-so-please |
24个回答
感谢SC的宝贵支持。
我在基于Windows 8.1 Pro的系统中也遇到了类似的问题。我使用管理员帐户安装了工具集,然后能够使用普通帐户登录进行调试。谢谢。 以上来自于谷歌翻译 以下为原文 Thanks SC for your valuable support. I also faced similar issue in Windows 8.1 Pro based system. I installed the toolset with a admin account and then was able to debug with a normal account login. thanks. |
非常感谢你!你的解决方案解决了我的问
我的系统:Win7 x64 以上来自于谷歌翻译 以下为原文 Thank you very much! Your solution solved my problem! My system: Win7 x64 |
我的操作系统是64位Windows 10,这个解决方案非常完美。非常感谢!
以上来自于谷歌翻译 以下为原文 My OS is 64 bit windows 10, and this solution worked perfectly. Thanks a lot! |
这解决了我的64位Windows 10系统上的问题。谢谢!!
以上来自于谷歌翻译 以下为原文 This solved the problem on my 64bit Windows 10 system. Thank you!! |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:53 , Processed in 0.629909 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1515
