你好,我想用一个LM4040作为ADC的2.5V参考。串联电阻是1K(所以极化电流应该是800 UA,10X是LM4040所需要的)阴极连接到RA10/VREF+,RA9/VREF-连接到GND。RA9和RA10都被配置为输入,两者都是模拟的。两个ADCsHAVE的引用,如果我采用一个LM4040,在测试配置中输出2.5V(电阻和参考,3.3V电源),并把它放在电路中(相同的事情,但是100N的上限到GND,然后直接到VREF+PIN),电压输出大约是800毫伏。焊接似乎是可以的,我可以。没有看到或测量短路到相邻引脚(VREF和AVDD)的事实,AVDD和VREF+1K之间的电阻(AVDD和K之间的电阻)AVSS和VREF之间的电阻:138kDo,你有什么建议吗?我错过了什么?(我不知道,目前的内部VREF+引脚是XX MA,这就是为什么下降…没有在数据表中捕捉到类似的信息
以上来自于百度翻译 以下为原文 Hi, i want to use a LM4040 as a 2.5V reference for the ADC. the series resistor is 1k (so polarizing current should be 800uA, 10x of what the LM4040 needs) Cathode is connected to RA10/Vref+, RA9/Vref- is connected to GND. Both RA9 and RA10 are configured as INPUTs, both ANALOG. Vref+ and - selected as references for both ADCs However, if i take a lm4040 that outputs 2.5V in a test configuration (resistor and reference only, 3.3V supply) and put it in the circuit (same thing, but with a 100n cap to gnd then direct to Vref+ Pin) the voltage output is around 800mV. The soldering seems to be OK, i can't see or measure shorts to the adjacent pins (Vref- and Avdd) infact, resistance between AVDD and Vref+: 1k (the resistor between AVDD and K) resistance between AVSS and Vref-: 13.8k do you have any suggestion? some gotcha i'm missing? (i don't know, current inside Vref+ pin is xx mA and that's why is dropping down.. didn's catch anything like that in the datasheet) |
4个回答
Hi-MeBeDead,我没有指定,但VREF-已经连接在AVSS电势
以上来自于百度翻译 以下为原文 Hi mbedder, i didn't specify but Vref- is already connected at AVss potential |
只有小组成员才能发言,加入小组>>
4829 浏览 9 评论
1834 浏览 8 评论
1752 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2959 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2063 浏览 5 评论
463浏览 1评论
1113浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
368浏览 0评论
265浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1806浏览 0评论
GMT+8, 2024-4-29 00:04 , Processed in 1.146961 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
