我的程序里面用到cos函数进行计算,如果单纯的用math.c计算一次大概将近2ms,用arm_math.c可以提升到0.5ms,同时我用STM32f1测试,用math.c大概就0.115ms,请问一下差别真有这么大吗,或者是我自己那块搞错了...
6个回答
关键NUC支持DSP指令和浮点运算单元
你开启浮点运算了吗?是不是需要进行设置
一个就是系统初始化 再就是配置,计算结果是正确的 所以..........
你要调用DSP的库操作才行。
#include
#include "arm_math.h" /* ---------------------------------------------------------------------- * Defines each of the tests performed * ------------------------------------------------------------------- */ #define MAX_BLOCKSIZE 32 #define DELTA (0.000001f) /* ---------------------------------------------------------------------- * Test input data for Floating point sin_cos example for 32-blockSize * Generated by the MATLAB randn() function * ------------------------------------------------------------------- */ const float32_t testInput_f32[MAX_BLOCKSIZE] = { -1.244916875853235400, -4.793533929171324800, 0.360705030233248850, 0.827929644170887320, -3.299532218312426900, 3.427441903227623800, 3.422401784294607700, -0.108308165334010680, 0.941943896490312180, 0.502609575000365850, -0.537345278736373500, 2.088817392965764500, -1.693168684143455700, 6.283185307179590700, -0.392545884746175080, 0.327893095115825040, 3.070147440456292300, 0.170611405884662230, -0.275275082396073010, -2.395492805446796300, 0.847311163536506600, -3.845517018083148800, 2.055818378415868300, 4.672594161978930800, -1.990923030266425800, 2.469305197656249500, 3.609002606064021000, -4.586736582331667500, -4.147080139136136300, 1.643756718868359500, -1.150866392366494800, 1.985805026477433800 }; const float32_t testRefOutput_f32 = 1.000000000; /* ---------------------------------------------------------------------- * Declare Global variables * ------------------------------------------------------------------- */ uint32_t blockSize = 32; float32_t testOutput; float32_t cosOutput; float32_t sinOutput; float32_t cosSquareOutput; float32_t sinSquareOutput; /* ---------------------------------------------------------------------- * Max magnitude FFT Bin test * ------------------------------------------------------------------- */ arm_status status; int32_t main(void) { float32_t diff; uint32_t i; for(i=0; i< blockSize; i++) { cosOutput = arm_cos_f32(testInput_f32[i]); sinOutput = arm_sin_f32(testInput_f32[i]); arm_mult_f32(&cosOutput, &cosOutput, &cosSquareOutput, 1); arm_mult_f32(&sinOutput, &sinOutput, &sinSquareOutput, 1); arm_add_f32(&cosSquareOutput, &sinSquareOutput, &testOutput, 1); /* absolute value of difference between ref and test */ diff = fabsf(testRefOutput_f32 - testOutput); /* Comparison of sin_cos value with reference */ if(diff > DELTA) { status = ARM_MATH_TEST_FAILURE; } if( status == ARM_MATH_TEST_FAILURE) { while(1); } } while(1); /* main function does not return */ } /** endlink */ |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
112 浏览 0 评论
219 浏览 0 评论
721 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
702 浏览 0 评论
有人有STM8H1K08T连接TM1650的源码吗,可以直接使用的那种,我的代码在烧录之后数码管一直处于熄灭状态
1036 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16963 浏览 31 评论
/9
GMT+8, 2025-12-9 22:35 , Processed in 0.849817 second(s), Total 85, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2157
