嗨,似乎有一个模拟器问题在MPLAB X 4.15,它没有出现在& lt=4.05 -见附件项目。当启动IDE并调试项目时,RA4和RAM5上的PWM输出可能是OK(在逻辑分析仪窗口中很容易看到)。然后,退出调试器并再次进入调试器- RA5上的PWM输出已经不存在了!除此之外,我很高兴看到我最近报告的bug(2个星期前)已经被固定在4.15,甚至更高兴的逻辑分析仪窗口中的新标记功能!我以前经常错过这个机会!谢谢!
以上来自于百度翻译 以下为原文 Hi there, seems that there is a Simulator problem in MPLAB X 4.15, which didn't show up in <= 4.05 - see attached project. When starting the IDE and debugging the project, the PWM output on RA4 & RA5 will be likely ok (easy to see in the logic analyzer window). Then, exit debugger and enter debugger again - PWM output on RA5 is gone! Apart from that, I was happy to see that my recently reported bug (2 weeks ago) has been already fixed in 4.15, and even more happy about the new markers-feature in the logic analyzer window! Very often I missed that before! Thanks! Attachment(s) PWMTest.zip (14.20 KB) - downloaded 47 times |
3个回答
甚至不想解释这里发生了什么问题。我们有一个修复应该在MPLAB X4.20。现在这里有一个奇怪的部分:我们强烈怀疑,如果你只是打开模拟器-&Gt;IOPin窗口,这个问题会为你走开。
以上来自于百度翻译 以下为原文 Not even going to try to explain what went wrong here. We have a fix which should be in MPLAB X 4.20. Now here's the weird part: We strongly suspect that if you simply open the Simulator->IOPin window that this problem will go away for you. |
是的,我可以证实这一点!刚刚添加了I/O引脚标签,即使没有任何内容,现在它的工作-这真的很奇怪!通过使用这个小的工作,现在是好的-谢谢你的帮助!我期待着4.20…
以上来自于百度翻译 以下为原文 Yes, I can confirm this! Just added the I/O Pins-tab, even without any content, and it now works - that's really weird! By using this little work-around it's ok for now - Thank You for your help! I'm looking forward to 4.20... |
必须是一些未初始化的变量,当打开该窗口时,初始化变量会被初始化:
以上来自于百度翻译 以下为原文 Must be some uninitialised variable that does get initialised when you open that window :) |
只有小组成员才能发言,加入小组>>
5243 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3208 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2258 浏览 5 评论
778浏览 1评论
669浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
597浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
679浏览 0评论
577浏览 0评论
GMT+8, 2024-12-24 07:45 , Processed in 1.698337 second(s), Total 81, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
