您好,我现在试图找到如何存储下面的字符串以便于ReTrIVALVY。然后,我将使用EththNes和NoTeNes 541945, 390467创建网格参考集41945 90467 i,可以分割数字以获得EAST和NoDest.1的第一个数字。1。如何在2D数组中正确存储?我已经尝试删除方括号,但我似乎无法从数组前缀[] 2得到任何数据。如果我需要构建一个包含OFF 41945 90467的字符串,那么我会使用STRCAT,前提是我创建一个13字符数组来存储字符串吗?谢谢你的时间。
以上来自于百度翻译 以下为原文 Hello, I'm now trying to find how to store the following strings for easy retrival.const unsigned char prefix[4][7]={["SV","SW","SX","SY","SZ","TV","TW"], ["SQ","SR","SS","ST","SU","TQ","TR"], ["SL","SM","SN","SO","SP","TL","TM"], ["SF","SG","SH","SJ","SK","TF","TG"]}; ["SA","SB","SC","SD","SE","TA","TB"], ["NV","NW","NX","NY","NZ","OV","OW"], ["NQ","NR","NS","NT","NU","OQ","OR"], ["NL","NM","NN","NO","NP","OL","OM"], ["NF","NG","NH","NJ","NK","OF","OG"], ["NA","NB","NC","ND","NE","OA","OB"], ["HV","HW","HX","HY","HZ","JV","JW"], ["HQ","HR","HS","HT","HU","JQ","JR"], ["HL","HM","HN","HO","HP","JL","JM"]}; I then will use the Eastings and Northings 541945, 390467 to create the Grid Reference TF 41945 90467 I can split the number to get the first digits of the Easting and Northing. 1. How do i store this correctly in a 2D array? I have tried to remove the square brackets but I can't seem to get any data from the array prefix[]. 2. If I need to build a string that consists of TF 41945 90467 would I then used STRCAT, provided I create an array of 13 chars to store the string? Thank you for your time. /StarKnight |
3个回答
尝试
以上来自于百度翻译 以下为原文 Try const char *prefix[][7] = { {"SV","SW","SX","SY","SZ","TV","TW"}, {"SQ","SR","SS","ST","SU","TQ","TR"}, {"SL","SM","SN","SO","SP","TL","TM"}, {"SF","SG","SH","SJ","SK","TF","TG"} }; |
你的第一次尝试是错误的,因为同样的原因是错误的。即试图将字符数组存储到单个字符变量中。为什么最初的数据在前四行之后有分号?这与第一维度中的[ 4 ]有关吗?那些空间是在绳子里吗?如果是,则有14个字符,并且需要一个15字符数组来允许终止空字符。
以上来自于百度翻译 以下为原文 Your first attempt was wrong for the same reason that const unsigned char str = "SV"; would be wrong. i.e. trying to store an array of characters into single character variable. Why did your initial data have a semicolon after the first four lines? Was this related to the [4] in the first dimension? Are those spaces meant to be in the string? If yes, you have 14 characters there, and need a 15 char array to allow for the terminating null character. |
只有小组成员才能发言,加入小组>>
5109 浏览 9 评论
1969 浏览 8 评论
1907 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3138 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2206 浏览 5 评论
679浏览 1评论
557浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
430浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
579浏览 0评论
477浏览 0评论
GMT+8, 2024-10-21 15:32 , Processed in 1.467868 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
