作为一个保守党坚持到底,我倾向于使用旧的和成熟的技术,以最大限度地重复使用。我很高兴的PIC32 MX系列的稳健性,并使用过程控制应用程序中的795和170。我想升级到174,但是在我使用的旧版本版本(V1.40)上不支持。我已经非常广泛地检查了这个编译器版本,而且对后来的版本也不确定(我也没有这些许可证),我也不想使用和声(我更喜欢我知道的魔鬼,它工作得很好,而且有怪癖——老的PLIB库)。在查看我是否能够找出如何导入旧文件中的174个文件(至今没有成功——任何建议都是受欢迎的),我看到了PIC32 MX175设备的引用,但是在这个论坛或互联网上找不到对这个设备的引用。它是否存在,它是什么?我很欣赏这是一个小问题,但工程师天生好奇……多谢,VJM。
以上来自于百度翻译 以下为原文 Being a conservative stick-in-the-mud, I tend to use older and proven technology to maximise re-use. I am very happy with the robustness of the PIC32MX series, and use the 795 and 170 routinely in process control applications. I wanted to upgrade to the 174, but this is not supported on the older compiler version that I use (V1.40). I have checked this compiler version quite extensively, and am not sure about later versions (nor do I have a licence for these), and I do not intend to use HARMony (I much prefer the devil I know that works well, and has known quirks - older plib libraries). In looking to see if I could figure out how to import the 174 files for use in the older compiler (so far no success - any advice would be welcome), I see references to the PIC32MX175 device, but can find no reference on this forum or the internet to this device. Does it exist, and what is it? I appreciate that this is a trivial question, but engineers are inherently curious... Many thanks, VJM |
12个回答
也许你指的是PIC32 MX174 OrPIC32 MX775?应该有NopIC32 MX175。
以上来自于百度翻译 以下为原文 Perhaps you mean PIC32MX174 or PIC32MX775? There should be no PIC32MX175. |
亲爱的SoBoTeCo,谢谢你的评论。不,我的意思是175——在XC32/V1.44/PIC32-LIbs/PRC和类似的目录中有完整的文件集。因此我的问题!
以上来自于百度翻译 以下为原文 Dear Sobottech, Thank you for your comment. No, I do mean 175 - there are full sets of files in the xc32/v1.44/pic32-libs/proc and similar directories in the distribution. Hence my question! |
事实上,搜索有点棘手,请参阅第2HTTP://WW1. Microchip .com /…EVICEDOC/6000 1404A.PDF
以上来自于百度翻译 以下为原文 Indeed the search is a bit tricky see page 2 http://ww1.microchip.com/...eviceDoc/60001404A.pdf |
您应该能够下载并安装可用最新编译器找到的修补文件。那应该做你想做的事。
以上来自于百度翻译 以下为原文 You should be able to download and install the patch file that can be found with the latest compiler. That should do what you want. |
谢谢-我应该看到这个。但是,我不确定这个设备是否可用。它不是在微芯片网站或互联网上引用的!所以这是174版本的一个VBAT版本。我有点恼火,因为我想我知道这个设备,但前一段时间。我被互联网搜索中的参考信息弄糊涂了。你知道有什么关于如何把174添加到更老的XC32编译器上的建议吗?还是我在这里鞭打一个死马?VJM
以上来自于百度翻译 以下为原文 Thank you - I should have spotted this. However, I am not sure if the device is available... It is not referred to on the Microchip site, or the Internet! So it is a VBat version of the 174. I am a little annoyed, as I think I knew of this device, but some time ago. I was (am) confused by the lack of reference in Internet searches. Are you aware of any advice on how to add the 174 to older XC32 compilers, or am I flogging a dead horse here? VJM |
谢谢-我还没有修补我的编译器一段时间(谨慎…)。我会研究这个……VJM
以上来自于百度翻译 以下为原文 Thank you - I have not patched my compiler for some time (cautious...). I will look into this... VJM |
谢谢-更新发现。我想知道是否是故意更新旧版本以最小化支持负载,但我接受这些文件将是相同的,无论编译器…问题解决了!
以上来自于百度翻译 以下为原文 Thank you - updates found. I wondered if it was deliberate policy not to update older versions to minimise support load, but I accept that these files will be identical regardless of compiler... Problem solved! |
HTTP//WW1.MICCHIP.COM/DeLoSt/En/DeVICECD/OC6000 1404A.PDFSEE Page 2VBAT,应该在2018年6月准备好样品。
以上来自于百度翻译 以下为原文 http://ww1.microchip.com/downloads/en/DeviceDoc/60001404A.pdf see page 2 has Vbat and there should be samples ready in June 2018 |
事实上,MX175是174设备的VBATT版本。我们现在有硅验证,并且目标是在六月的时间框架内。这些基本上是PIC32 MX1XX系列设备,它们运行在更高的时钟频率(72MHz)上,但在不同的过程中,大约是现有MX设备的一半功率。除了几个寄存器之外,所有的代码都是兼容现有MX设计的100%代码。
以上来自于百度翻译 以下为原文 Hi Folks Yes - indeed - the MX175 is a VBATT version of the 174 device. We have silicon in validation right now and are aiming for availability in June timeframe. These are essentially PIC32MX1xx series devices that run at a higher clock frequency (72Mhz) but are on a different process so are about half the power of existing MX devices. Aside from a couple of registers, everything is 100% code compatible to existing MX designs. |
-亲爱的诺瓦克先生,谢谢你的评论-我将向你介绍另一个线程,我正在寻找支持174/175个家庭在旧的PLIB,因为我发现和睦到很大的变化,并使用较早的(和成功的)框架。这个XLP家族是有吸引力的,特别是当它运行在更高的频率上,并且提供一个缓存。你可能有点乐观地指出,差异只是一对寄存器,我不得不分析它,并且我已经在另一个线程中报告了我的观点。有很大的差异,图书馆需要一些修改,但我同意,这并不显得太糟糕,因为我通过它。我可以提供更多的细节,如果这有帮助,但我相信你完全知道这个位置。这将是非常,非常好,如果Microchip是更新这些老图书馆,以支持现有的用户,或使和谐代码更容易获得(我已经放弃试图找到相关的代码I)n这一实施-但这可能是我有限的理解)。如果它是简单的,正如你所建议的,那么它就不应该是一个强加。我对向后兼容性有点担心,因为寄存器中的一些位的功能已经改变了,但是在这个阶段我还没有详细地查看。谢谢你的澄清,以及你的兴趣。祝你好运。VJM
以上来自于百度翻译 以下为原文 - Dear Mr Novak, Thank you for your comment - I would refer you to another thread where I am looking at supporting the 174/175 family on older plibs, as I find Harmony to much of a change and use the earlier (and successful) framework. this XLP family is attractive, especially as it operates at higher frequencies, and offers a cache. You are perhaps being a little optimistic in stating that the difference is only a couple of registers; I have had to analyse this, and I have reported my views in the other thread. There are significant differences, and the libraries will require some modification, but I agree that this does not appear too bad as I work through it. I can provide more detail if this helps, but I am sure that you are fully aware of the position. It would be very, very nice if Microchip were to update these older libraries in support of existing users, or make Harmony code more readily available (I have given up trying to find the relevant code in this implementation - but that might be my limited understanding). If it is simple, as you suggest, then it should not be too much of an imposition. I am slightly concerned about backwards compatibility, as the function of some bits in registers has changed, but I have not looked in detail at this stage. Thank you for the clarification, and your interest. Best wishes, VJM |
有趣的是,“你可能有一点乐观地指出,差别仅仅是两个寄存器,我必须分析它,并且我已经在另一个线程中报告了我的观点。”你知道用户BNOKAKE不是用户而是管理员吗?所以我猜,他有背景信息,知道他在说什么吗?微笑:如果有人能说出关于未来产品的事情……
以上来自于百度翻译 以下为原文 Hm. Funny. "You are perhaps being a little optimistic in stating that the difference is only a couple of registers; I have had to analyse this, and I have reported my views in the other thread." You know the user BNowak is no user but Administrator? So I guess, he got background information and knows what he is talking about? Smile: If someone can tell something about future products ... |
谢谢你的评论。我想知道我是否恰当地表达了我的反应……我欣赏诺瓦克先生的立场,只是指出了一个分析寄存器配置的结果,我昨天感兴趣了(我有一点空闲时间)。我还指出了在一个单独的线程中的数据表中的PMP寄存器信息的一些不一致性,(这确实影响向后兼容性),一些需要管理的新功能(深度睡眠,看门狗,附加时钟源),以及全新的块,例如OSCIL。LaTor需要改变(但在MPLAB的PrimaMax窗口中得到了很好的管理)。我确信你已经意识到了这些,所以请原谅我指出了明显的地方,我在有更广泛的兴趣的情况下做出反应。我只是担心这些差异可能比诺瓦克先生暗示的要多一些。多谢,VJM。
以上来自于百度翻译 以下为原文 Thank you for your comment. I wondered if I had phrased my response appropriately... I had appreciated Mr Novak's position, and was just pointing out the results of an analysis of the register configuration, which I undertook out of interest yesterday (I had a bit of spare time). I have also pointed out some inconsistencies in the PMP register information in the data sheets in a separate thread, (which do affect backwards compatibility), some new functionality (deep sleep, watchdog, additional clock sources) that needs to be managed, and totally new blocks such as the oscillator which require change (but are well managed by the pragma window in MPLAB). I am sure you are aware of these, so please excuse my pointing out the obvious; I respond in case there is wider interest. I was just concerned that the differences are, perhaps, a little more substantial than Mr. Novak implied. Many thanks, VJM |
只有小组成员才能发言,加入小组>>
4848 浏览 9 评论
1846 浏览 8 评论
1764 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2974 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2076 浏览 5 评论
472浏览 1评论
316浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
376浏览 0评论
270浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1823浏览 0评论
GMT+8, 2024-5-16 13:24 , Processed in 1.414310 second(s), Total 101, Slave 83 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
