电子发烧友论坛|
嗨,
我非常有兴趣使用Qemu来启动从教程构建的图像,即wandboard教程: https://www.digikey.com/eewiki/d ... elandRootFileSystem 但是,当我尝试使用以下参数启动qemu时,没有任何反应。 qemu-system-ARM -M virt -m 1024 -kernel vmlinuz-4.15.17-armv7-x1 -drive if = none,file = hda.img,format = raw,id = hd -device virtio-blk-device,drive = hd -netdev用户,id = mynet -device virtio-net-device,netdev = mynet -nographic -no-reboot 你们碰巧知道我怎么能产生一个可以被qemu引导的图像? 最好的祝福, 以上来自于谷歌翻译 以下为原文 Hi, I would be very interested in using Qemu to boot an image built from your tutorials, namely the wandboard tutorial here: https://www.digikey.com/eewiki/d ... elandRootFileSystem However, when i try to boot qemu with the parameters below, nothing happens. qemu-system-arm -M virt -m 1024 -kernel vmlinuz-4.15.17-armv7-x1 -drive if=none,file=hda.img,format=raw,id=hd -device virtio-blk-device,drive=hd -netdev user,id=mynet -device virtio-net-device,netdev=mynet -nographic -no-reboot Do you guys happen to know how can i produce an image that would be bootable by qemu? Best Regards, |
2个回答
@SilverOne,您是否为“virt”目标配置了内核?
看这个清单: https://wiki.qemu.org/Documentation/Platforms/ARM sabrelite是内核配置的正常目标之一...... 问候, 以上来自于谷歌翻译 以下为原文 @SilverOne, did you configure the kernel for the “virt” target? looking at this list: https://wiki.qemu.org/Documentation/Platforms/ARM sabrelite is one of the normal targets that kernel is configured for… Regards, |
@RobertCNelson,
我没有为“virt”目标配置内核。 你碰巧知道我怎么能这样做吗? 我确实试过运行sabrelite机器,但是qemu崩溃了: qemu-system-arm:尝试在0x00018000处执行RAM或ROM外部的代码 尝试使用-kernel和-dtb imx6q-sabrelite.dtb也不起作用。 最好的祝福, 以上来自于谷歌翻译 以下为原文 @RobertCNelson, I did not configure the Kernel for the “virt” target. Do you happen to know how i can perform this? I did try to run the sabrelite machine, however qemu crashes with: qemu-system-arm: Trying to execute code outside RAM or ROM at 0x00018000 Trying to use -kernel and -dtb imx6q-sabrelite.dtb does not work either. Best Regards, |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 09:51 , Processed in 0.776449 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3019
