电子发烧友论坛扫一扫,分享给好友
Windows 10,尝试了三台机器,十几个不同的端口(直接,电源集线器,USB 2)。USB 3等),在编程或调试会话之后删除MPLAX 4.15的唯一方法是通过调试菜单中的硬件引导紧急启动固件恢复过程。我应该添加PIKIT 3、ICD 3、实际ICE和I。CD 4都在MPLAX X 4.15上进行枚举和工作。
以上来自于百度翻译 以下为原文 Windows 10, tried on three machines, a dozen different ports (direct, powered hub, USB 2.0. USB 3.0 etc), the only way I can get it to properly enumerate and be recognised by MPLAB X 4.15 after removing it following a programming or debug session is to go through the Hardware Boot Emergency Boot Firmware Recovery procedure in the Debug menu. I should add that PICkit 3, ICD 3, Real ICE and ICD 4 all enumerate and work as expected with MPLAB X 4.15 on these machines. |
5个回答
我有两个不同的PACTIT4S工作在3个不同的Windows 7机器。
以上来自于百度翻译 以下为原文 I have two different PICKit4s work on 3 different windows 7 Machines. |
嗨,我想出了皮卡4的问题。当你插入所提供的电缆微型B端时,它将插座上的D针短路到地上。没有电缆插入时没有短路。我通过移除USB插座来固定它,将一些小心切割的卡普顿胶带放在最靠近板边缘的五个SMD土地的大约1/3处,并替换了插座。我不知道这只是我的单位,还是其他人。当它工作时,要么是我使用的是不同的电缆,要么只是稍微不同的推送。http://www. evBoop.com /论坛/微控制器/WHO -微芯片- HIDES - FROM - Dave-后HIS-PICTI3-VIEO-YES-NeX-PICTIT4-)/MSG14564 21/μsMSG14564 21。
以上来自于百度翻译 以下为原文 Hi I figured out the PICkit 4 problem. When you inserted the supplied cable Micro B end, it was shorting the D- pin on the receptacle to ground. There was no short when no cable is inserted. I fixed it by removing the USB receptacle, placing some carefully cut Kapton tape over about 1/3 of the five SMD lands closest to the board edge, and replaced the receptacle. I don't know if this is just my unit, or if others suffered. When it worked, it turns out that either I was using a different cable, or it was just pushed in slightly differently. http://www.eevblog.com/forum/microcontrollers/what-microchip-hides-from-dave-after-his-pickit3-video-yes-new-pickit4-)/msg1456421/#msg1456421 |
霍华德,这不只是你的单位。大约2个月前收到我的,决定今天第一次使用它。不会枚举。尝试紧急恢复,它只是使它更糟。同样的问题与引脚短路电缆插入。我要把这个单元送回,但是找不到我的发票。无论如何,在把它焊接回去之前,把连接器拆下来,把卡普顿胶带粘在连接器下面。问题解决了。所提供的电缆非常紧配合。使用一些我的电话电缆,配合非常松散,摆动电缆从窗口掉落设备。
以上来自于百度翻译 以下为原文 Howard, It's not just your unit. Received mine about 2 months ago and decided to use it for the first time today. Would not enumerate. Tried the emergency recovery and it just made it worse. Same problem with the pins shorting with a cable plugged in. Was going to send the unit back but couldn't find my invoice. Anyway pulled off the connector and stuck the kapton tape to the underneath of the connector before soldering it back on. Problem solved. The supplied cable is a very tight fit. Using a few of my phone cables the fit is very loose and wiggling the cable drops the device from Windows. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 09:35 , Processed in 0.620258 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4909
